Is RoHS issued only by self declaration process?
N
nasimsobh
Hi everyone
We are some ink producer and wanted to get RoHS for our products.
A compny is going to helps us as consultant, doing this and they are emphasizing that there's no auditions necessary for the certificate.
I was not sure about their claim, and I started searching for some audited certificates.
Is there any refrence or any of the members familiar with the topic??
Thnx in Advances.
tamale
Nasimsobh,
What you need at most is an independent lab certificate stating the absence of the listed contaminants in your ink.
I am including a letter the substance of witch will be able to guide you.
You will note that ink is not an electrical component.
Beware of hungry consultants!
Tamale
Mikishots
Nasimsobh,
Tamale
Not sure what you're getting at there - RoHS most certainly does not restrict itself to electrical components; it applies to raw materials, plating, packaging, inks...many varying items.
To address the OP, you would need one of two things; either an independent lab to ascertain if your ink (as a homogenous mixture) contains any of the six banned substances, and if it does, the quantities of said substances OR a certificate of compliance from the manufacturer of the components of your ink. In short, yes, it's self-declared, but you better make sure that either your company or your component suppliers have proof that it was checked and verified, in case your inks are pulled aside for a compliancy exam.
RobCarl
Agree that RoHS applies to packaging.
I'm a little concerned about the recommendations for lab certificates. There is a time and place for testing, but if a supplier sends me a certificate from a lab and claims to be RoHS compliant based on the single test of one item, I simply cannot accept that.
You need to have a SYSTEM in place to ensure your products will continue to be compliant. Testing is a part of that, but you certainly don't have to test every unit that goes out.
You need a system that evaluates what you suppliers are sending you, usually some sort of risk assessment. We do this through a qualification process. Then you should have (need to have?) some sort of monitoring process to ensure continued compliance. Of course, this implies that you have corrective action and containment processes that you can use to address any violations you uncover during randon sampling.
We only ocassionally send items out to a lab. More frequently, we monitor using an xRF analyzer. These have their limitations (can't tell Hex from non Hex Chrome, or the source of Br, etc., since it's an elemental analyzer), but are good for risk assessment. If anything turns up suscpicious, the supplier needs to provide a reasonable explanation (and evidence if appropriate).
Sorry for a long winded answer, but it's kind of an involved topic. The simple answer is yes, there is only self certification and audits are not required by the letter of the law. All that matters is if the parts are compliant or not when your ink gets checked at customs.
You are not required to "audit", but a strong program (and hence low risk) will include either auditing or monitoring. If you are found to be non-compliant during a customs inspection, it will matter if you performed due diligence or not. It will be difficult to show due diligence if you aren't checking (read auditing/monitoring) periodically to ensure your compliance system is working.
Hope that helps.
M Find updates to REACH and Rohs regulations REACH and RoHS Conversations 1
I When is necessary to have RoHS declaration on non-electrical parts? REACH and RoHS Conversations 1
T Training recommendations? Bringing our RoHS and REACH compliance efforts in-house REACH and RoHS Conversations 2
G RoHS Procedure REACH and RoHS Conversations 2
Marcel DS How do I know if my product is required be RoHS certified? REACH and RoHS Conversations 6
C Difficulties getting RoHS/REACH for cheap parts RoHS, REACH, ELV, IMDS and Restricted Substances 1
M Informational RoHS Standard - EN 63000:2018 to replace EN 50581:2012 Medical Device and FDA Regulations and Standards News 11
R ROHS Exemption Declarations REACH and RoHS Conversations 5
M ROHS : Applicability for AIMDs RoHS, REACH, ELV, IMDS and Restricted Substances 2
J Where can I find the latest update to Reach and ROHS? REACH and RoHS Conversations 9
padraick63 REACH and ROHS Requirement for a Molded Part REACH and RoHS Conversations 1
R Certificate of compliance to RoHS/REACH/WEEE - any such animal? REACH and RoHS Conversations 18
T China ROHS exemptions - Are there any exemptions for ROHS 2 China? REACH and RoHS Conversations 0
D The Status of ROHS for Medical Devices - April 2019 REACH and RoHS Conversations 3
Ed Panek CE REP questions about our devices ROHS compliance REACH and RoHS Conversations 1
R REACH and ROHS compliance for hundreds of parts made over 25 years REACH and RoHS Conversations 3
S Prop 65 and RoHS statement REACH and RoHS Conversations 6
J What my companies RoHS declaration should say 2011/65/EU, 2015/863, or 2017/2102 REACH and RoHS Conversations 3
bio_subbu EU Publishes New DIRECTIVE (EU) 2017/2102 AMENDING 2011/65/EU ON ROHS-2 REACH and RoHS Conversations 0
T CE Marking & Compliance to MDD, EMC, RoHS, and GPSD REACH and RoHS Conversations 4
D How do I show compliance to RoHS, REACH and Conflict Minerals? REACH and RoHS Conversations 6
J RoHS, WEEE and REACH Consulting Expertise Needed REACH and RoHS Conversations 4
P Necessary Compliance Documentation for RoHS and REACH REACH and RoHS Conversations 5
Q Guidance regarding Legally Refurbishing a Non-RoHS Instrument in the EU REACH and RoHS Conversations 1
M ROHS & REACH in TEFLON Material - NABL Testing Laboratories REACH and RoHS Conversations 1
S Sell a Non-RoHS device, manufactured before RoHs regulations became effective? EU Medical Device Regulations 2
Q EU ROHS and GUI Usability Trial Requirements EU Medical Device Regulations 10
M RoHS Directive - Supplier Compliance - Declaration of Conformance CE Marking (Conformité Européene) / CB Scheme 12
dubrizo Who handles Your Reach, RoHS, 3TG Compliance RoHS, REACH, ELV, IMDS and Restricted Substances 9
smryan Compliance Officer Outsourcing? RoHS, REACH, ELV, GADSL, IECSC Other ISO and International Standards and European Regulations 5
B RoHS Directive 2014/5/EU Leaded Solder Exemption RoHS, REACH, ELV, IMDS and Restricted Substances 2
bio_subbu Official Journal of EU published two new RoHS Exemptions EU Medical Device Regulations 1
A RoHS compliance - Our market is non EU countries only ISO 13485:2016 - Medical Device Quality Management Systems 4
D Will A Few Failed Solder Joints Make Me RoHS Non Compliant? RoHS, REACH, ELV, IMDS and Restricted Substances 9
L IOS-MAT-0010 vs REACH/ROHS RoHS, REACH, ELV, IMDS and Restricted Substances 2
P Must all parts of a product be RoHS compliant? EU Medical Device Regulations 5
N RoHS Compliance requirement for Hexavalent Chromium RoHS, REACH, ELV, IMDS and Restricted Substances 6
R RoHS Compliance Problem with One Component RoHS, REACH, ELV, IMDS and Restricted Substances 5
J RoHS Components with Lead Exemptions (Capacitors on a PCB) RoHS, REACH, ELV, IMDS and Restricted Substances 11
B Query on Medical Device Electronics RoHS Certificate Statement RoHS, REACH, ELV, IMDS and Restricted Substances 3
R RoHS Medical Devices: Application to Accessories, Components and Non-EE parts CE Marking (Conformité Européene) / CB Scheme 10
M Finding a hardware supplier/distributor compliant with RoHS RoHS, REACH, ELV, IMDS and Restricted Substances 1
D ROHS 2 - Medical Device: Placing vs Making Available on the market EU Medical Device Regulations 3
R RoHS and placing on the market in Non EU countries RoHS, REACH, ELV, IMDS and Restricted Substances 3
S RoHS Conformity Risk Assessment - Medical Devices RoHS, REACH, ELV, IMDS and Restricted Substances 2
S RoHS Directive 2011/65/EU Revision ? Medical Devices - 22nd July 2014 CE Marking (Conformité Européene) / CB Scheme 30
J RoHS-Non RoHS Multifunctional Workbench RoHS, REACH, ELV, IMDS and Restricted Substances 1
M RoHS CE Mark - Medical Devices built for US before 22 July 2014 ISO 13485:2016 - Medical Device Quality Management Systems 3
L What needs to be done to prove compliance with RoHS and WEEE EU Medical Device Regulations 5
A Start Compliance to RoHS, SCHV and REACH RoHS, REACH, ELV, IMDS and Restricted Substances 10
