Is the RPN (risk priority number) in the PFMEA really a RPN without the detectability
W
wardar90
Hi all. I am working in a company in the medical field. The company is located on two continents. The one I am working for is the contract manufacturer, the other is the distributor. Some time ago our colleagues from abroad were audited. No critical remarks were found during the audit but the auditing team stated that we (both companies) are not assessing the risk correctly due to the fact that we haven't updated a particular document in a while. They also suggested that the Detectability value in the PFMEA should be removed. I think this was not something that should have been changed at all. Anyhow... Due to the fact that we are two companies with unique quality management systems they decided to change the numbering convention for the RPN without informing us. That triggered a number of actions and now we have to change our numbering convention. Which as you know will take some time. So my questions are: Can a RPN be a RPN without the detectability value when we are addressing the PFMEA? The other company is still treating the new risk value as a RPN. Shouldn't be a critical number now without the detectability value? And also should the detectability value be even removed from the PFMEA in the first place when there are already established controls in place that are justifying the control of the risk? Should we update an already established PFMEA and treat it as if it is a new one? Because removing the detectability means exactly that. Can the auditing company be wrong? I am a bit confused and if someone can explain this to me that will be great. Thanks.
John C. Abnet
Teacher, sensei, kennari
Re: Is the RPN (risk priority number) in the PFMEA really a RPN without the detectabi
Good day @wardar90.
My first concern is that the "auditing team...suggested..."
I am inferring from your message that the "auditing team" is a 3rd party auditor. If that is the case, they are not to be consultants, but simply auditors.
Also, as you have eluded to, the RPN value is indeed, by definition, a calculation obtained by multiplying SEVERITY * OCCURRENCE * DETECTION. Even though the RPN value itself is dependent on numerous considerations (and likewise a "value" COULD be obtained by leaving out the "detection" value) and not necessarily the best tool for purposes of prioritization, it is nonetheless the method used by a PFMEA.
My last comment is actually a question. If your organization has utilized the PFMEA including the "detectability" value to identify and trigger the establishment of "DETECTION" controls, then it sounds as if the PFMEA, designed as intended which includes "DETECTION", is providing a benefit to your organization. My question, therefore, is -
why would your organization undue something that is established and providing benefit?
Summary: Do what is best for your organization (while meeting the requirements of the governing standards.
Hope this helps.
Be well.
yodon
To add on to John Abnet's excellent post, I personally think the detection parameter in a pFMEA is QUITE useful. It clearly, to me, helps characterize the likelihood of a failure escaping.
(I don't use detection for product-related FMEAs since if we can detect it, we should design to manage it.)
qualprod
Since 9001, doesn't require a method, you may apply a correction to your method, to say that is not fmea, and leave it as it is.
Say that you evaluate risk by multiplying severity x occurrence and you get the risk value and is that easy.
Remember, risk method is not required.
Instead you "patch" all your analysis, modify your method.
It's simpler.
Hope this helps
Marcelo
Question - why did you put this discussion in the ISO 14971 forum?
Your concerns have nothing to do with ISO 14971, and if you talking about ISO 14971, you may have a lot more problems.
Moncia Recalculating RPN (FMEA Risk Priority Number) - Customer Request APQP and PPAP 10
I PFMEA RPN Numbers Medical Device Risk Management FMEA and Control Plans 1
K Do you have to use RPN in Medical Device Risk Analysis? Identification of Hazards ISO 14971 - Medical Device Risk Management 6
T RPN Thresholds and How Detection Fits In ISO 14971 - Medical Device Risk Management 5
N Timing for Closing High FMEA RPN Items FMEA and Control Plans 4
M Requiring action on factors alone of RPN in FMEA APQP and PPAP 7
C PFMEA RPN - Feedback regarding adjusted RPN FMEA and Control Plans 3
N How to reduce RPN of Visual Inspection Process FMEA and Control Plans 6
S PFMEA RPN - At what RPN level do you take actions in the FMEA? APQP and PPAP 4
C How to handle Action Results in a new FMEA Review once we have a new RPN? FMEA and Control Plans 1
L FMEA - Calculating RPN = S*O*D FMEA and Control Plans 3
I RPN without Recommendation neither corrective actions FMEA and Control Plans 2
Q Why is the FMEA RPN = S*O*D? FMEA and Control Plans 10
G Determining the "Detection" Number Component of the FMEA RPN FMEA and Control Plans 5
K How do you determine what is acceptable base on an FMEA RPN FMEA and Control Plans 6
M Changing PFMEA (Process FMEA) RPN Values based on a Rejection FMEA and Control Plans 5
A PFMEA (Process FMEA) Detection Rating - Actions to Reduce RPN FMEA and Control Plans 3
R When to take action if an FMEA RPN number is high? FMEA and Control Plans 43
G Relation b/n Process Failure Mode RPN Value and the associated Process Failure Cost FMEA and Control Plans 3
B Formula to calculate the Process Sigma from an RPN Six Sigma 17
E FMEA Action Plan Threshold (RPN) - Auditor says Action Plan for an RPN > 84 IATF 16949 - Automotive Quality Systems Standard 21
Howard Atkins FMEA RPN Reduction Process FMEA and Control Plans 4
M FMEA RPN Recalculation after Actions are (or are not) Taken FMEA and Control Plans 6
C PFMEA RPN rankings - Preventative action must be opened if RPN over 100 ISO 14971 - Medical Device Risk Management 9
R If two processes have same RPN NUMBER - which should have priority over the other? FMEA and Control Plans 3
T RPN of Action Results per the AIAG FMEA manual FMEA and Control Plans 5
N How to Calculate RPN in Design FMEA (DFMEA) vs. Process FMEA (PFMEA) FMEA and Control Plans 9
F What is a usual RPN level for requiring actions? FMEA and Control Plans 4
V Emphasizing Severity more than Occurrence and Detection vs. Overall RPN FMEA and Control Plans 20
L PFMEA (Process FMEA) issue about lower RPN - AIAG 3rd edition page 55 FMEA and Control Plans 13
B Corrective Actions Priority - Process FMEA (PFMEA) RPN Limits - Recommended Actions FMEA and Control Plans 20
R FMEA review, RPN reduction - Any "rule of thumb" as to what makes an RPN too high? FMEA and Control Plans 12
K RPN reduction - Occurrance Reduction - Reducing occurance of defect on line FMEA and Control Plans 1
A Does anyone actually do a Pareto of the Top 5 (highest) RPN's of PFMEA? FMEA and Control Plans 8
A Is there an established RPN number or score for a DFMEA? FMEA and Control Plans 1
S RPN Ranking - Put a formula in an access database or Excel .xls spreadsheet Excel .xls Spreadsheet Templates and Tools 12
G Assignation of RPN rating (Detection) on Visual Inspection where subsequent operation FMEA and Control Plans 18
D Ranking Audit Effectiveness with RPN General Auditing Discussions 3
R PFMEA - RPN - Severity, Occurrence and Detection - Which one does not change? FMEA and Control Plans 67
A Quick question about RPNs - Any RPN over 100 should be actioned? FMEA and Control Plans 9
J FMEA RPN Number and When to Recommend to Take Action FMEA and Control Plans 3
T Process FMEA (Failure Modes Effects Analysis) Severity Rating and RPN IATF 16949 - Automotive Quality Systems Standard 17
S FMEA - Reject a PPAP because the RPN number is not shown? QS-9000 - American Automotive Manufacturers Standard 6
S Process FMEA (PFMEA) RPN Corrective Action Plan FMEA and Control Plans 6
S FMEA RPN Corrective Action Plan QS-9000 - American Automotive Manufacturers Standard 1
R Defining the RPN cut off number - Working on the top 3- 5 high RPNs? FMEA and Control Plans 4
Kevin Mader FMEA Severity Index - Leading contributor to the RPN value FMEA and Control Plans 9
J RPN numbers in FMEA - It is not correct to go only by the RPN numbers when doing FMEA FMEA and Control Plans 12
B ISO 17025:2017 risk management Risk Management Principles and Generic Guidelines 0
Q FMEA and Risk assessment in MS ACCESS FMEA and Control Plans 2
