Is there a difference between form control and document control ?
Julie O
#11
A template is one document that may be controlled. Documents generated using the template as a guide are separate documents, which may also be controlled. When you refer to changing the content of the template, I'm not clear as to whether you are talking about changing the actual template or creating a new document using the template as a guide.
If you are changing the actual template, you have changed the template, creating a new version of the template. If you want people to be able to identify and use the most up-to-date version of the template, then you need to issue it as a new version. If you mean they are changing the template to create a new document that is not a template (eg, an actual job description, not the job description template), then you haven't revised the template. You have created a new document and should track it as the first version of that document.
dsanabria
#12
J0anne:
Andyn / Dsnabria: unfortunatly i can't do this because i don't have authorization for that and furthermore My Manager (management
thanks all for attempting to help me :) :) :thanks:
OK - the tell your Manager (the management Representative) to dis-invite this auditor because level of competence. Based on your written statement, it appears that this auditor is a "Desk" auditor. Tell your Manager to bring in an auditor that will focus on processes and Risk- approach to your AQMS and not someone that is writing NCR on items that do not add value to the audit.
Kronos147
#13
Kronos147: the NCR as stated by the auditor is as follows:
The client did not fully comply with the requirements of the clause in that evidence of poor document control was seen:.
OBJECTIVE EVIDENCE:
1) Job descriptions were seen for three separate managers. However, the same document number, HR/701/F/7 Issue 2, 23/09/14, was used on all. This referred only to the document template and not to the documented content. This was seen in several other cases, where a document template had been classified as a form and the documentary content had no issue control.
2) The blank audit plan form QA/1002/F/1 issue 3 does not include the names of the areas to be covered over the audit plan period. This is unlikely to change from plan to plan.
IF if if you have a doc control procedures that says this is what you do, then the NCR is invalid. I doubt you do, and then the NCR would be about the procedure and then it would be a major, IMO.
....you haven't revised the template. You have created a new document and should track it as the first version of that document.
I think this is the case.
By the way, what you listed is not the complete NCR. It lacks the clause and statement of requirement(s). It is important to understand the requirements. In this case, 4.2.3 says you have to have a procedure that includes methods to "approve documents for adequacy prior to use."
It also says "changes and current revision status are identified." It says more. But let's start with these.
If you are trying to say you used a form template (a good thing), but created a separate record for a job description for the janitor, the vice president, and the accountant. Then you called them all 'JD-XX-01 rev. A Job Description Template' then yes, your system has an issue.
How can you meet the requirement to make sure that the doc has been approved and that the relevant revision will be available?
Let me make it more clear: template JD-XX-01 Rev. A CAN be used to create JD-Janitor-01 Rev. B Janitor Job Description, and JD-VicePres-01 Rev. A Vice President Job Description....
However, JD-XX-01 Rev. A cannot be the Janitors job description in this department and the Accountants in another because if lacks that control that says "this is the right one." It is like you asked each person to use the template and write something to satisfy an auditor. Then, these records now lack the clear indication of approval.
So, take the ones you have, rename them, approved them, review the procedure, revise if required, train, and call it a day.
A form template can be something like a PO. The fields are there and the data has to be entered for each PO.
Once you take a template and put it towards a specific purpose, run it through your change control procedure and control it!
S Definition Form vs. Record - What is the Difference between a Form and a Record Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 63
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Terminal Lugs sizes - Difference between 225/24 vs. 275/24 lugs Manufacturing and Related Processes 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
gramps What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 3
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 4
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O Air Flow - Which is the operational difference between LAF (vertical and horizontal) and RLAF? Manufacturing and Related Processes 2
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
S DO 178B - What is the difference between review and verification? Federal Aviation Administration (FAA) Standards and Requirements 1
T The difference between SOP and Kaizen Standardization Lean in Manufacturing and Service Industries 2
K Difference between intended purpose and intended use of the device EU Medical Device Regulations 9
S Difference between an Advisory Notice (ISO 13485) and a Field Safety Notice? ISO 13485:2016 - Medical Device Quality Management Systems 3
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
qualprod What is the difference between 7.4.1 (2008) and 8.4.1 (2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
S What is the difference between a service request and a complaint? ISO 13485:2016 - Medical Device Quality Management Systems 2
I What is the difference between OOS/OOT Imported Legacy Blogs 3
A Definition Difference between Quality System Procedure and Standard Operating Procedure (SOP) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
Q Difference between Monitor & Measurement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T QA vs. RA - The difference between QA and RA Coffee Break and Water Cooler Discussions 6
A Difference between Discrimination and Least Count IATF 16949 - Automotive Quality Systems Standard 2
K Difference between Medical Electrical Equipment and Medical Equipment System IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Usability Standard - The difference between IEC 60601-1-6 to IEC 62336 Human Factors and Ergonomics in Engineering 1
S What is the difference between Verification and Validation of Test Reports? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A Difference between ISO 9001:2015 Clauses 8.1 and 8.5.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M IATF 16949 Cl. 8.4.2.2 vs 8.6.5 - Is there any difference between these clauses? IATF 16949 - Automotive Quality Systems Standard 7
C What is the difference between "Overall Risk" and "Risk"? (ISO 14971) ISO 14971 - Medical Device Risk Management 10
C The difference between a Critical Dimension vs. Critical Characteristic Misc. Quality Assurance and Business Systems Related Topics 2
