Is there a form I can use to explain what I'm submitting PPAP for?
V
vardar3
Is there a form I can use to explan what I'm submitting PPAP for?
When I submitt a PPAP it is uaually for a whole list of changes, and some of them are not self explanitary on the print. So I'm looking for some formal way to help me explain what the change is for.
I know one option is I could make my own.
Re: Is there a form I can use to explan what I'm submitting PPAP for?
What kind of changes are you referring to? Is your company design responsible for the product(s)?
W
WKHANNA
Our customer requires a Warrant page with the PPAP.
"Reason for Submission" such as 'Initial Submission', 'Engineering Change', 'Process Change', etc, is noted there.
Deereman
Something I did for multiple reasons for a PPAP was to add an addendum (which was noted on the Warrant) which listed the purpose of the submission (in my case, multiple revisions ganged on one submission). This was a Tier II supplier submission to a Tier I supplier. It worked...
By the way, the revision listed on the warrant was the latest.
Howard Atkins
Forum Administrator
The warrant is this document-
There is also space for
Reason for submission
Other- please specify below
Please do not try to reinvent the wheel
Keep It Simple and Sensible
Stijloor
When I submit a PPAP it is uaually for a whole list of changes, and some of them are not self explanatory on the print. So I'm looking for some formal way to help me explain what the change is for.
Examples of Part Submission Warrants (PSW).
Stijloor.
V
vardar3
Add NES M0094 Flammability note and CC13Add pull strap color chart and reference notePull strap dimension 11.5 min was 17.5 minLower tube 13 was 12.7Cover front rear material PP-H2TF2 was PPSpring 2.1 was 2.2Rod lock material SAE J403 - 1037-1045 was SAE J403 - 1037.Upper tube material SAE J2340-420XF was 060XFAdd assembly 0012213 to BOMRevise lower tube notch tolerance RO .3 +/- .2 was RO.3 +/- .1. 90° +/- 3 was 90° +/- 2°.Beige strap color code PC-81 was VP-16.
These are the changes that are happening with this revision bumb. It take some explaination, so I was looking for a type of format to do that
I'm not sure what a "revision bumb" is (BOM?) but how did your customer communicate these changes to you? It's usually enough to reference the customer document(s) under "Additional Engineering Changes" on the PSW if the changes in question haven't been incorporated in the current design record.
If the changes have been incorporated in the current design record, and you beholden to PPAP the changes only, you would just "balloon" those things on the drawing and explain on the PSW that the Reason for Submission is Engineering Changes.
Unless it's customer-specific, there is no form to use for what you want to do. If you want to list out the changes, do so on an addendum to the PSW. If you do this, there should be bilateral reference between the PSW and the addendum. That is to say, the PSW should reference the addendum and the addendum should reference the PSW.
Deereman
If the changes are due to a Customer ECN or Revision (which is what it sounds like), you should just reference the ECN or Revsion on the warrant (reason for submission would be "Engineering Changes" and the actual ECN or Revision change(s) letters or numbers would be listed in the upper blocks where you enter the part name, PN, etc.
You would not have to list the actual changes on the warrant as the Customer knows what the ECN or revision incorporated.
As far as the changes themselves, you'll have to do a layout (normally for KPC and the revised dimensions) and any updated certs that may be required.
Now, did any of the revised requirements actually make a change to the product you are currently supplying? If not, you may just be able to submit the warrant.
O
OmegaS
Add NES M0094 Flammability note and CC13Add pull strap color chart and reference notePull strap dimension 11.5 min was 17.5 minLower tube 13 was 12.7Cover front rear material PP-H2TF2 was PPSpring 2.1 was 2.2Rod lock material SAE J403 - 1037-1045 was SAE J403 - 1037.Upper tube material SAE J2340-420XF was 060XFAdd assembly 0012213 to BOMRevise lower tube notch tolerance RO .3 +/- .2 was RO.3 +/- .1. 90? +/- 3 was 90? +/- 2?.Beige strap color code PC-81 was VP-16.
Hi Vardar,
Can you provide me the norms:
"NES M7100" and "NES M0094"
I'm trying to get them in internet or several sourses but I'm not having success until I see your post. Please, can you tell me where, how or if you can provide them to me!?
Thank you.
Regards.:thanx:
Techilady Ford Special Characteristics Communication and Agreement Form (SCCAF) provides production requirements? FMEA and Control Plans 4
S Transitional Adolescent A and B - "CDRH PREMARKET REVIEW SUBMISSION COVER SHEET FORM FDA 3514" Medical Device and FDA Regulations and Standards News 1
P AS9102 Form 3 Inclusions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
John C. Abnet VDA 6.3 questionnaire form VDA Standards - Germany's Automotive Standards 1
K Generic preventive maintenance form wanted Document Control Systems, Procedures, Forms and Templates 2
M Is it Necessary to Use Health Canada Form when Reporting? Canada Medical Device Regulations 1
S Supplier Management ISO 13485: 2016- Which supplier needs to fill in a self assessment form? ISO 13485:2016 - Medical Device Quality Management Systems 6
I Form templates for software (iso9001) Document Control Systems, Procedures, Forms and Templates 0
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
D New Equipment form / template Document Control Systems, Procedures, Forms and Templates 5
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B EMPB (Erstmusterprufbericht) VDA form confusion + PSW VDA Standards - Germany's Automotive Standards 2
gunnyshore Form FDA 3500A MedWatch eSubmitter 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
M AS9102B Detail Part/Assembly FAI Form 1 box 13; AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A AS9102B - 3.6 Design Characteristics and form 3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M AS9102 FAI Report formats - Boxes in form 1, 2, 3 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C AS9145 Appendix D PPAP Approval Form APQP and PPAP 2
L Form-dependent position prevention control FMEA and Control Plans 1
Y Blank Fields on CAPA Form Document Control Systems, Procedures, Forms and Templates 21
Q Do Management Review records have to be on a controlled form? ISO 13485:2016 - Medical Device Quality Management Systems 30
M How to complete structure Analysis and Function analysis sections' columns of AIAG-VDA DFMEA form FMEA and Control Plans 0
P AS9102 Form 3 Dimension Results Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Informational EU – MDCG 2019-12 Designating authority’s final assessment form: Key Information Medical Device and FDA Regulations and Standards News 0
Ed Panek Relevant questions on Substantial Change Form CE Marking (Conformité Européene) / CB Scheme 3
B Documenting hardware on Form 2 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Nonconformity for missing form number on the job description document Nonconformance and Corrective Action 1
Sidney Vianna Interesting Discussion Interesting article form the UNIDO Magazine - CSR: a wolf in sheep’s clothing? Sustainability, Green Initiatives and Ecology 16
R Process Specification - What is the name of this PPAP form? APQP and PPAP 15
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G I-chart form for GM GP-12 Customer and Company Specific Requirements 2
M Informational US FDA – Ethicon Recalls Circular Staplers for Insufficient Firing and Failure to Completely Form Staples Medical Device and FDA Regulations and Standards News 0
B AS9102 COTS Form 1 vs. 2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Incoming (Receiving) Inspection - General form for incoming part inspection Document Control Systems, Procedures, Forms and Templates 17
S C of C release with accompanying EASA Form 1 for EASA Part 145 EASA and JAA Aviation Standards and Requirements 0
S Where did FDA 510(K) form 3654 go? Other US Medical Device Regulations 4
M What are the differences between "Process Flowchart form" and "Process Flow Diagram form"? IATF 16949 - Automotive Quality Systems Standard 4
K Does anyone have a copy of a GM 5 Phase Problem solving form Problem Solving, Root Cause Fault and Failure Analysis 1
Ron Rompen Source needed for Spline Form gauge (GO and NOGO members) General Measurement Device and Calibration Topics 3
T NAFTA request for form with no part numbers showing Supply Chain Security Management Systems 0
C Do we need to make a new OFI (Opportunity for Improvement) for each document/form we update? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
R SaMD - Software as a Medical Device - Software change control form ISO 13485:2016 - Medical Device Quality Management Systems 3
K Work Order Form (Controlled Document)? Document Control Systems, Procedures, Forms and Templates 5
J Medical Device Vigilance decision tree FORM - Please share yours EU Medical Device Regulations 15
O Localized clean room dust extraction system coupled in HVAC - Manufacturing solid dosage form Manufacturing and Related Processes 9
Ajit Basrur Informational Merger of PAC and APLAC to form the Asia Pacific Accreditation Cooperation (APAC) General Measurement Device and Calibration Topics 0
JoshuaFroud FDA Form MDSAP AU F0029.1.004 - Help with Completion US Food and Drug Administration (FDA) 0
L AS9102 Form 1 Section 13 Detail or Assembly Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
