Is there a minimum industry standard for PpK ?
SGquality
Similar to a minimum CpK of 1.33 as the industry standard, is there a similar PpK requirements ?
Thanks !
Curtis317
1.67 PpK per my memory. However I cannot find any reference in the AIAG SPC manual for either CpK 1.33 either. Just the equations.
The minimum requiremet for Ppk to be 1.67 was removed some time ago I believe and it may have come from a single automotive supplier rather than AIAG. My memory may be very faulty on this, so if others remember more accurately, pease chime in.
What I do remember precisely is that the Ppk min applies when the capability study is done on early builds and the samples are from a very short time. In this context Ppk is an estimate of short term capabilty, but uses the total standard deviation since there are no subgroups: a single sample is taken from a short build that usually uses only one raw material lot(s), one operator, one piece of equipment, etc. This limited build condition provides the 'short term' condition. the minimum value is set at 1.67 to allow for build to build variation that would increase the overall variation reducing the long term capabiilty estimate.
in the beginning there was only one formula and one index: Cpk and the formula used the total standard deviation.
Then someone decided to get cute adn they added a short term capability estimate. Cpk became the short term estimate using the within subgroup standard deviation in the formula. Ppk became the long term estimate usign the total standard deviation in the formula. Most statistical software follows this convention. but most of industry has dropped the short term aspect as it has no real value. so often Cpk requirements expect you to use the total standard deviation...
very confusing adn overly complicated for an estimate that provides no real value or insight. There are many threads here that discuss this topic...should you want to learn more a search is a great place to start...
Darius
Agree, without the environment variables, no value is a "real standard", if the sample size is not defined nor the presence of patterns and sampling methodology, is there a meaning in such number? is as good as 42.:D
Darius
Agree or disagree with the use of Cpk/Ppk....
Sort off, :agree1: BUT Not as an standard, not to measure is worse course of action to measure, as this article says
You Can't Manage What You Don't Measure by John Reh
The issue here is to apply the same metric to all, and this is NOT right.
If you compare a metric against new data from the same system, if there are no new weir trends on the data (behave rougthly the same way), is possible to determine the trend of this system, using Cpk or ppk is fine but if you compare against the same system performance.
There is the saying that you shall not use performance or capability indicators if you are not stable, but if this is the case how could you expect to improve your system to such state of art behaviour, you are entering to the cycle of which is first the egg or the chicken. If your system has a non gaussian distribution, the same thing; but if your system behave as a log-normal distribution, Gamma, etc. managing that can led you to improvements, but only if you compare to the same condition.
In some other posts I tried to show that cpk/ppk are estimates obtained from a set of data, so you shouldn't take them as a true value which if you increase by 0.01 something was going on for good and decreased by 0.1 something was don wrong (I put 0.1 because is there the believe that a change no matter how big or small is a change:sarcasm:). And how can you compare the precision of 10 data sample against a 1000 data sample if you take just the cpk/ppk value?, and the sample size is almost always taken as a negligible piece of information, "the indicator came from a very famous statistical package and must be true":sarcasm:, really I saw this many times.
note: I put 42, because is the answer to everything, the answer is fine but what is the frame that make this "magical number" give it's meaning is missing.
Stijloor
<snip>The issue here is to apply the same metric to all, and this is NOT right.
Oh, trust me, I am in your camp. :agree1: The Cpk/Ppk addiction is rampant in automotive land. If I had my way, I would eliminate them all together. But in the mean time, OEM's continue to refer to their own and PPAP requirements, and I am not in a position to change that. :frust: :frust:
M What is the Minimum Documentation Required for Medical Device Industry? ISO 13485:2016 - Medical Device Quality Management Systems 3
S Minimum Samples for DFM discussion APQP and PPAP 10
S Minimum Retention Time for Records of internal audit results as per AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Minimum/ mandatory core processes AS9100 Process Maps, Process Mapping and Turtle Diagrams 6
C Document Record/Template Minimum Requirements ISO 13485:2016 - Medical Device Quality Management Systems 3
F Self-test minimum requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S Help needed in choosing the method of calculating the minimum sample size Internal Auditing 12
P Minimum Distance from Floor to Underneath of Machine Human Factors and Ergonomics in Engineering 5
D LiPo battery minimum requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P Search function minimum length Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 3
M Minimum sample size - Guidance and statistical rationale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Capability study with a minimum spec Statistical Analysis Tools, Techniques and SPC 8
L Significant Production Run - How 300 was determined to be the minimum quantity APQP and PPAP 2
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
shimonv Minimum 60601 requirements for a clinical trial IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J Minimum Supplier Certifications for Food Supplements Food Safety - ISO 22000, HACCP (21 CFR 120) 4
J What is the minimum standard for automotive component traceability? Manufacturing and Related Processes 2
M Applicability of IEC 60950-1 Table K2 - Minimum clearances between circuits Various Other Specifications, Standards, and related Requirements 0
M Characterization Testing - NO acceptance criteria, no minimum performance requirement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K Is minimum repair or replace guarantee period for medical devices in EU the same as consumer guarantee law of 2 years? EU Medical Device Regulations 5
S Designing the experiment with minimum run Statistical Analysis Tools, Techniques and SPC 0
JoshuaFroud Change Control - Minimum Requirements and Unhappy Staff ISO 13485:2016 - Medical Device Quality Management Systems 16
J IATF Minimum Automotive Quality Management System Requirements for Sub-Tier Suppliers IATF 16949 - Automotive Quality Systems Standard 12
N ETO Sterilisation Validation - EO Residual Minimum Sample Requirement ISO 13485:2016 - Medical Device Quality Management Systems 2
F Regulatory Compliant Quality Management System - Bare Minimum EU Medical Device Regulations 2
S What is the minimum pressure differential required for ISO Class 8 Clean Room? ISO 13485:2016 - Medical Device Quality Management Systems 3
somashekar ISO 13485 plus ISO 9001:2015 will now attract a minimum 2 day upgrade audit ISO 13485:2016 - Medical Device Quality Management Systems 9
J Minimum staff per 21 CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
D What is the minimum Sample Size for Weibull Analysis Reliability Analysis - Predictions, Testing and Standards 12
K What are the minimum requirements for Process Validation (Software)? ISO 13485:2016 - Medical Device Quality Management Systems 5
C Battery Powered Beauty Products minimum Legal Certifications Requirements CE Marking (Conformité Européene) / CB Scheme 7
B What is the minimum sample required for Performance Evaluation for IVD ? EU Medical Device Regulations 3
D Minimum requirements/experience/qualifications to be head of quality Career and Occupation Discussions 6
R Minimum Essential Receiving Inspection (M.E.R.I.) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S What is the minimum samples required for Customer Survey? Quality Manager and Management Related Issues 3
J Minimum number of parts to do an attribute gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
I Minimum and Maximum Validation Batch Size Requirements Qualification and Validation (including 21 CFR Part 11) 3
A Minimum Number of Parts for Attribute (Go / NoGo) Data Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S Minimum documents required by AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
N Minimum Design factor for CE Marking for machinery CE Marking (Conformité Européene) / CB Scheme 2
J Minitab Sample Size Calculation: 1 Sample t vs Minimum Sample Size for Means Using Minitab Software 3
G Why for a Shewhart chart the minimum feasible value for APL is 2401 units? Statistical Analysis Tools, Techniques and SPC 8
A Minimum Testing Requirements for a Clear Protective Equipment Barrier (Class II 510K) Other US Medical Device Regulations 1
V Critical Characteristics - Capability for a Minimum Specification APQP and PPAP 11
BradM What is the minimum size chamber for mapping? ISO 13485:2016 - Medical Device Quality Management Systems 2
Q Minimum Organization Structure to support TS16949 IATF 16949 - Automotive Quality Systems Standard 5
Q Minimum content required in a Quality Manual as per ISO 9001:2008 Quality Management System (QMS) Manuals 6
A ISO 13485 Supplier Monitoring Minimum Requirements Supplier Quality Assurance and other Supplier Issues 3
T New Packaging Line Performance Qualification (PQ) - Minimum Test Times ? Qualification and Validation (including 21 CFR Part 11) 3
