Is there a relatively inexpensive method of Calibrating our Torque Wrenches?
hogheavenfarm
We are a small metal manufacturing shop looking to bring some of our external calibration jobs in house. Is there a relatively inexpensive method of calibrating our torque wrenches available? We do not need high accuracy, but we do need it NIST traceable. What would your suggestions be?
We have about 50 various size torque wrenches and drivers, and I am not able to keep our torque equipment on a schedule since we are largely contract driven, and when the jobs slow down, so does the calibration budget. I end up removing most of the tools from use until the next job comes along. Then we are up against it timewise to send the wrenches out and get started on the job. I can stay ahead on the mics and calipers simply because I can do them here while it is slow.
BradM
Hmm... good question.
It depends on a number of factors. First, are all the torque devices in a similar range? Do you have a lot of variance of ranges (oz/in; inch/lbs; etc.)
I understand what you mean, but the required accuracy and gaining the appropriate ratios is important. If you end up with a 1:1 ratio, you might as well flip a coin. :tg: So, the accuracy of the instruments you have would need to be assessed. This will assure that you get an appropriate standard with sufficient accuracy.
I see a couple of ways to calibrate in-house. First, get a test rig with weights to verify your torque instrument. Or, get an instrument with sufficiently higher torque accuracy, and use it to check your shop instruments. With this setup, you will need to build a jig and assure that you have minimized additional factors like offset addiing to torque, etc.
Do you have enough history on them that you could extend the calibration interval?
On the surface, unless you have a lot of in-house torque equipment, I'm not sure you would get a payback quick enough to justify carrying it in-house. :)
W
WestCoastCal
I may have misinterpreted what you wrote, but when you stated that you can't keep them on an schedule, it sounds like they get calibrated if there is new contract. When properly managed, the cal due date is when the instrument should (theoretically) go out of its MPE.
What you torqued with the torque wrenches have not been validated until the torque wrenches have been recalibrated. If in tolerance, there is a higher probability of what you torqued being good. If the torque wrench tested out of tolerance, there is a higher probability of what you torqued as not being good.
I agree with Brad, doing them in house will cost a nice chunk to get up and running (let alone the quality management system requirements). Also, if you have past history, do an interval analysis to see if you have the intervals set properly. Lastly, if you can determine what accuracy you actually require, then you can definately dictate to your vendor as to what the acceptance criteria should be going forward. (they should base the as found condition on the previous calibrated accuracy prior to derating).
hogheavenfarm
Thanks Brad and WestCoast, (and Miner),
yes, we have inch pounchs and ft pounds - I only mentioned accuracy since I saw that the calibration equipment was sold to varying levels of accuracy , I meant to say we needed to lowest level for our work generally -
As for calibration interval - you are again correct , there is no check until the equipment is calibrated again. Unfortunately I have no control over this, nor is any of this understood in this organization. But thats getting in too deep for this question....
Calibration records exist, scattered though they are, and the equipment is scheduled for annual calibration, although in many cases it should be at 6 months due to heavy usage. Again, I have no say in this matter. I am currently sending out wrenches that are past calibration by over two years. Some is due to equipment being used off site, and that equipment is only returned at the completion of the job, regardless of whether is expires in the meantime.
Calibration here is seen only as an expense to be charged to the start of a job, because it is a prerequisite of the customer, not that its good business practice.
Oops! I must correct myself. You do not "calibrate" a torque wrench. You determine it's capability:
http://elsmar.com/Forums/showpost.php?p=376473&postcount=2
Sorry Miner. :eek:
Indeed, Brad! This is another one legends which grew in reaction to an auditors questions...
I had experience of a shop who did little but assemble large equipment using bolts. They found, through capability studies of their wrenches, that the more expensive (initial price) torque wrenches (breaking beam type) were far more capable than lower cost or dial indicator types. As a result of the initially expensive (daily-weekly) studies, checking wrenches could be backed off to a monthly event etc.
The torque setting master(s) were in the regular calibration program, of course...
JaxQC
Google the words “torque analyzer”. Send it out to get it calibrated to NIST standards. Then do all the rest yourself at your shop.
Remember to check it across the range (linearity) ie… 30, 60, 90 for a 100 wrench & not just one location. Also add it to your Lab Scope.
Ballpark is @ $ 1500.
apestate Inexpensive Gage Blocks for small aerospace startup shop General Measurement Device and Calibration Topics 1
L Inexpensive Gage Management Software recommendations for less than 75 Gages Calibration and Metrology Software and Hardware 8
E Can anyone recommend a good/inexpensive calibration house? General Measurement Device and Calibration Topics 9
J Inexpensive SPC Software Package with Results I can email Quality Assurance and Compliance Software Tools and Solutions 6
Q Sampling method for Distributor verification activities EU Medical Device Regulations 1
A Beginners help with ISO3951-2 Combined control s-method n>5 what is Phi ?? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S What is the best method to bond urethane foam to urethane foam? Manufacturing and Related Processes 4
R BS EN 12060:1998 - Zinc and zinc alloys Method of sampling Specifications Manufacturing and Related Processes 4
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 1
Pau Calvo How to motivate colleagues to use 8D method or similar Quality Manager and Management Related Issues 37
M Proper method to test flow of a regulator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Please share your method used for PEMS Validation IEC 62304 - Medical Device Software Life Cycle Processes 5
Y Post Market Surveillance Indicators and Analysis method EU Medical Device Regulations 1
silentmonkey Seeking efficient method to manage install base data Manufacturing and Related Processes 0
D 4M (Man, machine, method, materials) Management Manufacturing and Related Processes 3
Ron Rompen Measurement Method Challenge - Measure feature #91 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C FDA on changing acceptance criteria re: analytical method validation US Food and Drug Administration (FDA) 1
M Issuing NCR for improper method statement submissions Internal Auditing 10
F Irradiation Sterilization Validation Maximum Dose - VDmax 25 method (ISO 11137) EU Medical Device Regulations 2
I "Method" vs "Process" - Differences Document Control Systems, Procedures, Forms and Templates 33
P Test Method Validation for Tensile Strength Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
C ICP versus AA: How to determine appropriate specification for assay method verification Qualification and Validation (including 21 CFR Part 11) 1
I Flatness - Rectangular part using the three jack method Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
B AS9102 Supplier Flow Down Method AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
M Control Method correspondence between PFMEA and CP FMEA and Control Plans 8
qualprod Qualitative or Quantitative? Risk method evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Ron Rompen Dual level holes - Measurement method suggestions wanted General Measurement Device and Calibration Topics 9
D Sampling method that is representative of the devices supplied by that distributor EU Medical Device Regulations 5
P Production Line Pump Cleaning Validation Method Question Qualification and Validation (including 21 CFR Part 11) 0
A Risks related to Method Validation and Stability Studies Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
qualprod ISO 9001 Risk control method - What could be the better way to control risks? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Ford Method - Position Capability with MMC Modifier Capability, Accuracy and Stability - Processes, Machines, etc. 14
J Inspection method for T10 Hex driver General Measurement Device and Calibration Topics 13
qualprod ISO 9001:2015 - Right method to address clause 6.1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S Stakeholder analysis Method Six Sigma 1
T ER Checklist - Method(s) of conformity EU Medical Device Regulations 1
T ISO 17025 Method Verification - One sided “F” test or two sided “F” test ISO 17025 related Discussions 1
B Dosimeter Calibration Method General Measurement Device and Calibration Topics 5
A Test method for presence or absence of hexavalent chromium on a metal coating RoHS, REACH, ELV, IMDS and Restricted Substances 4
S Response Surface Method to create design matrix in Minitab Using Minitab Software 5
T Method to assess Measurement System of a Continuous Process Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G HPLC Method Equivalence between USP and EP Various Other Specifications, Standards, and related Requirements 1
