Is there a specification that provides directions on Drawing Revision Changes
J Allen
Is there a specification that provides directions on how changes to an Engineering drawing is noted?
A drawing was provided to me for review that the change block called out a revision change and the change was noted on the drawing with a bubble on the drawing which was fine. But there were numerous changes not reflected.
Those Changes include making 2 place decimals to 3 place on some dimensions, removing views, changing notes, ...etc. all of which were not noted in the Drawing Revision block.
The engineer wants only to add a comment to the revision block that says "added Dimensions and Tolerances," without actually listing the individual changes.
He says that it is sufficient for this type of drawing whose only scrutiny is internally.
I need criteria for making changes to drawings.
Thank You
Michael_M
ANSI Y14.5 may have something.
ISO9001 has something along the lines of:
The organization shall retain documented information on:
a. design and development changes;
b. the results of reviews
I have seen several aerospace prints that have 'SEE EO ####' in the revision header to save space.
Q
QAMTY
I have been working on drawings and used criteria like this:
1- When there are a lot of correctionsns and most of them occur in preliminary phases, we only put "General Revision"
2- when there are several corrections and most of them are cosmetic, "General revision"
3- When there are few revisions, we give full description " The room was removed and changed"
4- If you have columns and rows identified on the drawing, you refer the col A, row 2
where the corrections are placed, e.g. see A,3, see B,4
5-When there are very important corrections, full descriprion is important, because users detect quickly the corrections.
Hope this helps
Jean_B
You'll find technical documentation standards at https://www.iso.org/ics/01.110/x/
The ones I know contain some useful information on your question:
ISO 11442, which describes a general approach to controlling documents, but its annex A provides information on rules for revision.
ISO 7200 is specifically about "Data fields in title blocks and document headers"
I've also found BS 8888 to be a useful resource, though I see there's a 2017 edition out. I've only used the prior one.
M Labeling Specification in a DMR Other Medical Device and Orthopedic Related Topics 0
X Design stage overview (Product specification) EU Medical Device Regulations 3
T Manufacturer vs. Specification Developer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Sidney Vianna ISO 9001 News ISO 9001 Design Specification to be developed - May 2022 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
D Out of specification procedure for Medical device manufacturing Manufacturing and Related Processes 7
M Particular Specification References Out-of-Date Collateral Specification IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P ISO 11607-2 Process Specification Other Medical Device Related Standards 1
6 BAE SPECIFICATION 12596520 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R GS1 DataMatrix code does not meet GS1 Specification EU Medical Device Regulations 0
S Examples of FDA acceptable Software Design Specification (SDS) Medical Device and FDA Regulations and Standards News 6
K Radius with specification only Max limit Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G What does performance specification include? US Food and Drug Administration (FDA) 1
B Setting flexible packaging specification limits ISO 14971 - Medical Device Risk Management 4
G National Structural Steel Specification 7th Edition - Do I now have to be audited against ISO 3843-3 as well as ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D DQ documents of new equipment - Function specification Qualification and Validation (including 21 CFR Part 11) 0
DuncanGibbons Manufacturing Plan vs Material Specification vs Control Plan Manufacturing and Related Processes 5
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
Q User Requirement Specification for HR (Human Resource Management System) Manufacturing and Related Processes 1
S Managing specification changes on standard parts purchased through trading companies Document Control Systems, Procedures, Forms and Templates 2
D Performance specification as a Risk Control Measure, EN 14971 ISO 14971 - Medical Device Risk Management 7
D Subcontracting specification developer duties US Food and Drug Administration (FDA) 5
shimonv IEC 60601-1 Essential Performance - Is the signal accuracy specification an essential requirement? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
S How to find technical specification for facilities maintainance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Process Specification - What is the name of this PPAP form? APQP and PPAP 15
S When does a Distributor become a Specification Developer? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Procedure or Specification For Extending Gages Calibration Calibration Frequency (Interval) 2
Lisa Christo Specification developer Other Medical Device Related Standards 0
B IATF 16949:2016 – Technical Specification (eBook edition) IATF 16949 - Automotive Quality Systems Standard 3
R Contract Manufacturer/OEM Supplier - We are a specification developer for a kitted product 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
E Compliance to standards (ISO 80369) but the ID is out of specification Other ISO and International Standards and European Regulations 0
C ICP versus AA: How to determine appropriate specification for assay method verification Qualification and Validation (including 21 CFR Part 11) 1
M Specifications Aerospace - Who is responsible for providing the correct specification(s) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
I EO sterilization out of specification and correction Other Medical Device Regulations World-Wide 2
C Specification Developer or Consultant? Definitions 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Medical Device Manufacturer vs. Specification Developer Other US Medical Device Regulations 1
R Specification on flare testing extruded aluminum - Where to find Design and Development of Products and Processes 1
supadrai Establishment registered as specification developer and foreign exporter only 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M McDonnell Douglas Specification Control Drawings Various Other Specifications, Standards, and related Requirements 4
S Dates on Labels acceptable to the USA - GS1 General Specification 3.4.4 Other US Medical Device Regulations 3
S GR&R using 10 Parts with different Specification Limits Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
shimonv Soldering Station Accuracy out of specification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
P Accounting for Variability on High Side of Specification Reliability Analysis - Predictions, Testing and Standards 1
P Specification Subscription Services - Eg: Things like MSDS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J Deformation specification not defined in print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
N Understanding the absolute uncertainty specification for a Fluke 5500A Measurement Uncertainty (MU) 3
R Looking for calibration specification for Fluke 7250 pressure controller General Measurement Device and Calibration Topics 5
A Uncertainty Measurement - What this accuracy specification "1% + 10^5": means? General Measurement Device and Calibration Topics 2
