Is there a specification that provides directions on how changes to an Engineering drawing is noted?
A drawing was provided to me for review that the change block called out a revision change and the change was noted on the drawing with a bubble on the drawing which was fine. But there were numerous changes not reflected.
Those Changes include making 2 place decimals to 3 place on some dimensions, removing views, changing notes, ...etc. all of which were not noted in the Drawing Revision block.
The engineer wants only to add a comment to the revision block that says "added Dimensions and Tolerances," without actually listing the individual changes.
He says that it is sufficient for this type of drawing whose only scrutiny is internally.
I need criteria for making changes to drawings.
Thank You
Thank You
