Is there a standard for HALT (High Accelerated Life Testing)?
Marc
Hunkered Down for the Duration
#11
Here's a paper written by a man who's supposed to have coined the term 'HALT'.
HALT AND HASS The Accepted Quality and Reliability Paradigm
He may have "coined" HALT as a phrase/acronym, but it was popular before him. I was introduced to accelerated life testing in 1986-87 and a fellow named Jerry Schlagheck and I called it ESS (Environmental Stress Screening) for electronic assemblies. We did lectures on it one of which a guy from Ford attended which is how I got into automotive. In the picture I included in my previous post in this thread if you look at the upper right you'll see a chamber we design to use speakers instead of shakers for the vibration part of the sequence in production. It was designed for high volume production screening. We also partnered with Cincinnati Sub Zero (no, not the refrigerator company - see http://www.csztesting.com/ ), a manufacturer of environmental test chambers, in designing the early temperature shock chambers. He mentions a 40 degree change (as opposed to 5 degrees in temperature step cycles). This was done by having two (or three) chambers with an elevator (if top and bottom chambers) or a slide mechanism (side by side for 3 chamber systems).
Anyway - I could tell you all about that stuff because it was a specialty we did and lectured about, but the Hobbs Engineering paper pretty well describes everything. Here is another old "painting" I did way back then circa 1986 - It was used to explain what defects thermal shock and vibration were expected to reveal and why things were failing, especially in "rugged environments" as opposed to, say, a stereo which sits on a shelf most of its life and is not subjected to vibration such as in a moving vehicle, not to mention sitting in a relatively stable environment temperature and humidity wise:
But to the point, his paper is right on even though he wasn't the first to use it. Jerry and I did a lot of troubleshooting of designs, one of which was the Bradley Fighting Vehicle "brain". We also used finite element analysis of board designs for predicting vibration stress points and points of likely failure.
While Ford never bought into production screening (cost and time factors), they began to use it extensively in the design phase along with finite element analysis.
WoW! This is like a blast from the past for me. Brings back a lot of memories.
John Broomfield
#13
Strictly speaking this testing should be specified or at least scoped as part of the design and development planning to help validate the verified design.
Marc
#14
Actually, it should be considered at the Request for Quote stage prior to acceptance of a contract from a customer. Before we ever accepted a contract the QAPP, which included validation test plans, had to be approved by the customer and so stated by the contract.
In all my writings here (and elsewhere) over the years, I have always stressed the importance of Contract Review prior to acceptance of any contract (not to mention any time a contract is changed such as a customer making a print change after the original contract is accepted).
#15
Hi Marc,
right now i am doing one project in which the PCB layout changed(mainly due to MCU change) as well as some components (MCU changed, some resistor and capacitor with smaller footprint). The number of PCB layer, PCB supplier and PCB size were not changed.
my understanding is due to layout change and component change, a HALT is necessary at high level, however i am not sure if vibration is indeed necessary(my understanding is that vibration is more applicable if there are through hole parts - we dont have in my case, or customer application involves movement of the parts - our customer dont move parts during application). I checked a few articles, they do mentioned HALT can detect something, but there was no mentioning of criteria to which a temp test, voltage test, vibration test is needed.
can you share your thought as to whether or not vibration test is necessary or the guideline to a particular test item in HALT?
Thanks!
Marc
#16
I have been retired for some time. Hopefully one of the others here can help with an answer.
Sidney Vianna What ISO Standard (under the TC 176) supports the UN Sustainable Development Goal #10? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 11
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q EN ISO 13485:2016/AC:2018 - AC:2018 being stated in the applicable harmonized standard listing Other ISO and International Standards and European Regulations 1
J SAE J1739 standard IATF 16949 - Automotive Quality Systems Standard 2
Marcel DS LV 123 - BMW, AUDI, Mercedes Standard VDA Standards - Germany's Automotive Standards 1
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
Y UL 1998 Standard: software classes Software Quality Assurance 0
G What to do with correction factors overlooked by an accredited standard (6.4.11)? ISO 17025 related Discussions 5
G Copy of withdrawn ISO 9001:1994 Quality Management Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Anonymous16-2 SOP (Standard Operating Procedure) Numbering Document Control Systems, Procedures, Forms and Templates 7
Ed Panek Compliance with Standards? When a standard is updated/revised CE Marking (Conformité Européene) / CB Scheme 3
Skooma Deburring and Tolerances - Is there a Standard for deburring or removing material? Manufacturing and Related Processes 3
B Purchasing AS9100D Standard in Japanese AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
O In addition to the standard, what other ISO 13485 sources do people recommend? ISO 13485:2016 - Medical Device Quality Management Systems 5
B ASTM E18-2020 - Rockwell testing standard changes? General Measurement Device and Calibration Topics 2
M Informational RoHS Standard - EN 63000:2018 to replace EN 50581:2012 Medical Device and FDA Regulations and Standards News 11
D Recent changes to ISO 14971 - SOP required for managing standard revisions ISO 13485:2016 - Medical Device Quality Management Systems 1
P Cenelec updated standard information CE Marking (Conformité Européene) / CB Scheme 1
S Is there a standard for sample size during R&D phase Other ISO and International Standards and European Regulations 18
N Program or application for standard time measurement in industry from video surveillance? Human Factors and Ergonomics in Engineering 1
K Question on whether IEC 60601-2-62 standard is applied IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
B Clause 5.1.12 of Technical Standard IEC 62304/A1 IEC 62304 - Medical Device Software Life Cycle Processes 5
M Viable count Measurement ISO Standard Other Medical Device Related Standards 1
I When exactly was "competence" added to the ISO-9001 standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S Managing specification changes on standard parts purchased through trading companies Document Control Systems, Procedures, Forms and Templates 2
MDD_QNA QR Code Standard ISO/IEC 15417:2007 - Does anyone use it? Other Medical Device Related Standards 3
S Average and standard deviation of Cumulative Data Statistical Analysis Tools, Techniques and SPC 5
R Standard Filter for Calibration Colorimeter ISO 17025 related Discussions 1
B Standard for Dielectric Strength Test IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Specific Absorption Rate (SAR) Testing - What Standard to Use? Other ISO and International Standards and European Regulations 1
M Harmonised RED Standard ETSI EN 440 - Which Version? Other ISO and International Standards and European Regulations 0
R QMS Standard appilications on different Defense Sector Quality Management System (QMS) Manuals 1
A Supplier Quality Standard vs Senior Management Direction Supplier Quality Assurance and other Supplier Issues 2
B To detect the non standard variable IATF 16949 - Automotive Quality Systems Standard 5
J What is the minimum standard for automotive component traceability? Manufacturing and Related Processes 2
B Need For BIS Standard Mark? Imported OEM's Power supply,Li-Ion Battery Other Medical Device Regulations World-Wide 0
C On spontaneous but non-standard rankings FMEA and Control Plans 3
E Post Market Surveillance Standard Various Other Specifications, Standards, and related Requirements 4
A IEC 60601-2-2 - Defib-proof test amendment to base standard IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N Is there a standard / rules pertaining to eating in medical device manufacturing area? Manufacturing and Related Processes 5
M Performance Standard for Balloon Trocars Other Medical Device Related Standards 2
D Standard guide for shelf life determination of non sterile component with degradation materials Reliability Analysis - Predictions, Testing and Standards 1
S Where to get online AS standard audit certification classes? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P ISO 10993-1:2018 - When will the European equivalent become a Harmonized Standard? Other Medical Device Related Standards 13
M Informational From AAMI – FDA Recognizes AAMI Standard and TIR Medical Device and FDA Regulations and Standards News 0
