Is there a standard which states how often instruments should be calibrated?
N
nixnine1
Is there a standard which states how often instruments should be calibrated/validated? We have put 2 years on almost everything from calibration weights to gauges. Is that too much? And how do I know if it is too long?
NikkiQSM
Re: Calibration schedule
The equipment should have come with a certificate which explains when it needs to be calibrated.
NikkiQSM
You have to assess the equipment and based on risk of negatively affecting your product, you may want to increase the frequency of the calibration. For example, we use scales here to weigh up ingredients. It is very important that what the scale is reading it correct. The scales certificate originally stated that it should be calibrated annually, but because of the risk to our product, we have it calibrated quaterly.
Some devices might need to be calibrated every time they're used, and others might not need calibration at all. Establishing intervals usually involves risk assessment and moving from shorter intervals to longer ones based on the "as found" condition when a device is calibrated.
Not always! It's more a case of buying a calibration certificate first! Let's not overlook that the equipment manufacturer doesn't assume anyone wants calibration (results/certs) and certainly they don't know how (often) the equipment will be used. Theirs is a guesstimate, at best. To identify a calibration recall, one must know the results of the initial calibration, first. If the results show the equipment is on the limit as manufactured, it could be risky to let it go a whole year before recall...
No, there isn't. Everything is going to be different! I wouldn't expect weights to change in two years, but gauges might be out after 10 uses (depending what type of "gauge" you mean..)
NikkiQSM
Well said:applause:
I suppose I am too ingrained of using our equipment. Its for testing medical plastics, so everything here comes with a NIST calibration certificate :)
qusys
In addition to what the other Covers said, I would like to suggest to rely also on manufacturer manual and instruction.
Only you know how critical is a gauge/tool to ensure valid result in monitoring and measurement activities. As you said, you have a process in place.
Analyse your data trying to understand if a wrong measurement due to malfunction or bad calibration/adjustment of your tools/gauges affected the product and cause a return from the customer.:bigwave:
G
Gmzita
Hi - this is my first time posting or answering anything - so here it goes - I agree with everything that has been listed above - i.e. manufactures recommendation, monitoring and data analysis, etc. But you also may want to check the testing or calibration methods that you are using. For instance, some of the ASTM and ISO standards actually do state or recommend a frequency for the calibration of items. ASTM E4 has a section titled "Time Interval Between Verifications" which gives recommended intervals for the calibration of a Force Testing Machine. Many other standards may also contain this information. It will require some digging but you may be able to find the answers for some of the equipment there.
Big Jim
At least in a backhanded way, ISO 9001 does provide some guidance on calibration intervals. It may not seem evident though.
I think that it goes without saying that you don't want to do it so often that it is burdensome.
The outer limit is from the paragraph in 7.6 right below the letters (7.6 a-e) where it states:
"In addition, the organization shall assess and record the validity of the previous results when the equipment is found not to conform to requirements. The organization shall take appropriate action on the equipment and any product affected."
Determining and taking appropriate action on the equipment may not be very difficult, but doing so on the product affected can be a huge liability and a huge project as well, one that you don't want to do if at all possible. This, in my mind is the outer side of the interval. It needs to be often enough that your risk is mitigated as much as practical.
Simply choosing an interval of two years without thinking through the impact could expose you to a lot of risk.
D Approved Subcontractor List - The standard states "other methods may be utilized" Document Control Systems, Procedures, Forms and Templates 8
A Is there a standard on tolerances of substances ? Medical Device and FDA Regulations and Standards News 0
SABRINA DJILALI SAIAH Implementation of the ISAS-MEDIA 9001 standard in a TV channel ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B European Harmonized vs IEC standard IEC 62366 - Medical Device Usability Engineering 2
D Which ISO Standard to purchase? ISO 13485:2016 - Medical Device Quality Management Systems 7
C Standard -Machinist Handbook Customer Complaints 4
N EN 813, EN 12277, EN 1497 - Testing some harness prototypes to an EN standard Various Other Specifications, Standards, and related Requirements 0
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
S Shore A hardness Tester Acceptance Criteria Standard Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
Sidney Vianna What ISO Standard (under the TC 176) supports the UN Sustainable Development Goal #10? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 11
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q EN ISO 13485:2016/AC:2018 - AC:2018 being stated in the applicable harmonized standard listing Other ISO and International Standards and European Regulations 1
J SAE J1739 standard IATF 16949 - Automotive Quality Systems Standard 2
Marcel DS LV 123 - BMW, AUDI, Mercedes Standard VDA Standards - Germany's Automotive Standards 1
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
Y UL 1998 Standard: software classes Software Quality Assurance 0
G What to do with correction factors overlooked by an accredited standard (6.4.11)? ISO 17025 related Discussions 5
G Copy of withdrawn ISO 9001:1994 Quality Management Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Anonymous16-2 SOP (Standard Operating Procedure) Numbering Document Control Systems, Procedures, Forms and Templates 7
Ed Panek Compliance with Standards? When a standard is updated/revised CE Marking (Conformité Européene) / CB Scheme 3
Skooma Deburring and Tolerances - Is there a Standard for deburring or removing material? Manufacturing and Related Processes 3
B Purchasing AS9100D Standard in Japanese AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
O In addition to the standard, what other ISO 13485 sources do people recommend? ISO 13485:2016 - Medical Device Quality Management Systems 5
B ASTM E18-2020 - Rockwell testing standard changes? General Measurement Device and Calibration Topics 2
M Informational RoHS Standard - EN 63000:2018 to replace EN 50581:2012 Medical Device and FDA Regulations and Standards News 11
D Recent changes to ISO 14971 - SOP required for managing standard revisions ISO 13485:2016 - Medical Device Quality Management Systems 1
P Cenelec updated standard information CE Marking (Conformité Européene) / CB Scheme 1
S Is there a standard for sample size during R&D phase Other ISO and International Standards and European Regulations 18
N Program or application for standard time measurement in industry from video surveillance? Human Factors and Ergonomics in Engineering 1
K Question on whether IEC 60601-2-62 standard is applied IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
B Clause 5.1.12 of Technical Standard IEC 62304/A1 IEC 62304 - Medical Device Software Life Cycle Processes 5
M Viable count Measurement ISO Standard Other Medical Device Related Standards 1
I When exactly was "competence" added to the ISO-9001 standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S Managing specification changes on standard parts purchased through trading companies Document Control Systems, Procedures, Forms and Templates 2
MDD_QNA QR Code Standard ISO/IEC 15417:2007 - Does anyone use it? Other Medical Device Related Standards 3
S Average and standard deviation of Cumulative Data Statistical Analysis Tools, Techniques and SPC 5
R Standard Filter for Calibration Colorimeter ISO 17025 related Discussions 1
B Standard for Dielectric Strength Test IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Specific Absorption Rate (SAR) Testing - What Standard to Use? Other ISO and International Standards and European Regulations 1
