Is there any way to prove a process is in control other than with a control chart?
L
Leonardo Lopez
Hi:
IIm new at this, so this might look like a stupid question, but here it goes anyway...is there any other way to prove/measure that a process is in control other than with a control chart?
ralphsulser
Leonardo Lopez said:
Hi:
Leonadro, welcome to the Cove. There are no stupid questions here, so don't worry.
I don't know of any way other than statistically proving it. If you measure something, then the results are the data to use to calculate and verify degree of control.These statistics are the same for control charts or capability studies. You can purchase many kinds of software to crunch all the numbers and provide control limits, capability indicies, and graph all the data too.
Is this the kind of answer you are looking for?
Govind
Hi:
Leonardo,
Welcome to Cove. There are no stupid questions. All of us here learn from each other by sharing the knowledge. Iam learning a lot of stuff from this forum everyday.Do not hesitate to post questions.
Process can be controlled by designing controls in the system. Example: Closed loop control system (Automation) which measures the output at a desired frequency and feeds back to the system thus controlling the output within desired level.
We can set up to perform this function using statistical control chart principles or just control within desired specification limits. Both are controls.
The former one is statistically controlled.
However, using statistical principles, we will know the difference between random variation and special causes. This way we do not tweak the process too often. Also using control chart principles, we can make sure if the process is stable. Once the process is stable, we can start working on reducing the variation.
Govind.
D.Scott
Welcome to the Cove Leonardo -
The use of the words "prove - in control" rather limits the discussion to control charts but there are other ways to control a process. This can be done with in-process inspection, periododic testing/sampleing or other methods. One you might look at for maintaining control with minimal operator input is "Pre-Control". I have also used "Action Charts" mentioned above by Govind. Depending on what you want to control and the degree of control you wish to maintain, there can be a variety of alternatives to the common "control chart".
Dave
Hi:
This is a good question. I'm looking at this from adifferent point of view, in that the control chart does not control process. The C chart is only one of the tools used to monitor the process to indicate whether or not the item is within aceptable limits.
Controlling the process comes in the form of training, proper equipment, maintenance, work flow, etc,etc.
Darius
By Leonardo
I tink that many will not agree but: IMO If the mean and the standard deviation of a sample is the same, the process is the same or "in control" (so "F" and "t" test with for example 90% because is not a controled experiment). I know that the traditional way is without any out of control rules, but not all rules apply to any condition and sometimes a rule of out of control happens and is just by chance (nothing happend).
Welcome to the Cove.
:biglaugh:
P How to Scientifically Prove the Importance of a Process - CMMI Process Areas Software Quality Assurance 7
H How do we prove that we are improving the continual improvement process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
Q Do we have to prove a link between the mill and our raw material supplier? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 9
B How to prove that an organization implements anti bribery policy IATF 16949 - Automotive Quality Systems Standard 8
C UDI Label Verification - How do we ensure the barcode is correct and prove it? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S How to Statistically Prove 2 Dimensions are Related Using Minitab Software 18
U Sample size to prove parts are good with 99.73% confidence Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L What needs to be done to prove compliance with RoHS and WEEE EU Medical Device Regulations 5
A Is MSA useful to prove a Measurement System after Relocation? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P How to prove that Cr oxide makes a stent biocompatible (e-polished 316LVM) Manufacturing and Related Processes 9
P Testing a US device in Europe to prove Equivalence in a ?head-to-head? Study EU Medical Device Regulations 6
J Reliability Prove-out, Pass-Fail Testing Reliability Analysis - Predictions, Testing and Standards 2
K What would you give up to prove conformity and honesty? Internal Auditing 21
S ISO 17025 requirements not enough to prove NIST Traceability? ISO 17025 related Discussions 10
I Prove or disprove that a cube can be cut in 27 smaller cubes in less than 6 cuts Brain Teasers and Puzzles 14
M How do I prove I don't receive a controlled product? Ractopamine Hydrochloride Misc. Quality Assurance and Business Systems Related Topics 4
C Clinical Data to Prove Equivalence Other US Medical Device Regulations 4
U Can anyone prove that: 2x2=5 ? Coffee Break and Water Cooler Discussions 63
D Testing an Inspector to Prove Competency in Visual Inspection Records and Data - Quality, Legal and Other Evidence 2
S Lean System Developer - How should I work to prove myself? Lean in Manufacturing and Service Industries 19
D How to Prove and Explain to Consultant (Internal Auditor) and Manager? Internal Auditing 7
M Planning requirement 5.4: How should the management prove compliance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J How to prove that we conform to legal requirements Miscellaneous Environmental Standards and EMS Related Discussions 11
L How do you prove you need resources? Misc. Quality Assurance and Business Systems Related Topics 5
J Finished Goods Testing - Using historical test data to prove finished goods OK Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A Contract Review - How do you prove it? Contract Review Process 16
K Statistical Hypothesis Testing to prove signficant quality improvement or decline Statistical Analysis Tools, Techniques and SPC 6
V Process, component or full product re-qualification: leaded to unleaded solder Qualification and Validation (including 21 CFR Part 11) 7
C Refreshing an old and boring topic - Job descriptions and Roles vs Process Documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C OEE and In-process Inspection Manufacturing and Related Processes 2
S Effective nonconforming process for AS9100 8.7 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
T ISO 13485 - Process validation at critical suppliers ISO 13485:2016 - Medical Device Quality Management Systems 7
K Software Validation for Measurement Tools used in Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
J Sub-supplier change from manual to automated process - same specs - Report to FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
I Release checklist EO sterilization process Medical Device and FDA Regulations and Standards News 3
V Informational SMMT IATF Oversight - OEM KPI Process IATF 16949 - Automotive Quality Systems Standard 4
M Description of the requirements of clause 9.2.2.3 manufacturing process audit- needs your feedback IATF 16949 - Automotive Quality Systems Standard 0
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Design Control Procedures later in the Development Process ISO 13485:2016 - Medical Device Quality Management Systems 6
K Process Mapping - Inputs/Outputs/Detail Activities/Control points/Measurement? Process Maps, Process Mapping and Turtle Diagrams 4
D Social Media Feedback process for Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 6
P Images of Product for Automated Process - How long to keep? US Food and Drug Administration (FDA) 2
J Where to Place Process Maps in our Documentation? Process Maps, Process Mapping and Turtle Diagrams 4
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
B Supplier of design and manufacture process ISO 13485:2016 - Medical Device Quality Management Systems 10
D Calibration Process Flow Map Example Wanted General Measurement Device and Calibration Topics 3
G Devices from IQ, OQ or PQ process to be used for verification, validation and summative? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
