Interesting Discussion Is there such a thing as FDA Good Documentation Practice (GDP)?
K
kmuela
#11
Thank you very much for taking the time to find this. It looks like there is nothing "official" out there, but some common sense practices that have been shared and accepted.
Thanks again,
KMuela:thanx:
Regulatory
#12
I am going little bit out of topic here.....
If your company is certified for ISO 13485:2003 then it is very easy for you to have the proper documentation in structure
I am attaching you document which clearly depicts the correlation between the ISO 13485:2003, GMP guidelines
G
Gert Sorensen
#13
Wow, Regulatory. I am flattered, that you would pass on the matrix that I made, that must mean that you found it useful. :)
By the way, unless your blog contains information that the users of the Cove would find useful, then please refrain from linking it.
harry
#14
Yes, we would prefer that you locate the link of your blog in your profile and reference it when necessary.
L
Littlethings
#15
I am looking for a visual aid that illustrates the good practices for changing a quality record when a mistake is made. I also would like to illustrate the bad practices so that the field folks can really understand whether their corrections are adequately documented.
JPMac
#16
Hi, I am familiar with what is referred to as Good Documentation Practices. In fact, I was just about to review the SOP on it and wanted to look around first for anything new and happened upon this chat. So you won't feel alone, http: compliance online.com and follow to training.
Also try ICH Q7A, which includes a short section on documentation of changes to douments. You may also look at ALCOA: Attributable, Legible, Contemporaneous, Original, Accurate. It is all related to GMP.
F
FDAINFO
#17
Is there such a thing as FDA Good Documentation Practice (GDP)? This is often referred to at my new company. If not, is anyone aware of a specific general guideline for it elsewhere? I have tried numerous web searches, with many references and general comments on a single instance of a good documentation practice, but I can't find a single, official document for "GDP" overall.
Thanks,
KMuela
Nothing from FDA, per se. We have a complete manual on Quality Systems, including QSIT and other materials. visit my web site and click on "books"
Ken Reid
W
Watchwait
#18
Like others, I agree that there is no specific FDA "GDP" expressed as such. The reference posted by Al, albeit a decade or more old is still as complete a reference as you'll find on FDA's expectations regarding "Good Documentation Practices":2cents:
bio_subbu
#19
Yes, there is no section of 21 CFR devoted to Good Documentation Procedures.
If you are a manufacturer; 21 CFR 820.40, the Document Controls portion of Quality System Requirements, (QSRs) is the most pertinent to you:
Subpart D--Document Controls
Sec. 820.40 Document controls.
Each manufacturer shall establish and maintain procedures to control all documents that are required by this part. The procedures shall provide for the following:
(a)Document approval and distribution. Each manufacturer shall designate an individual(s) to review for adequacy and approve prior to issuance all documents established to meet the requirements of this part. The approval, including the date and signature of the individual(s) approving the document, shall be documented. Documents established to meet the requirements of this part shall be available at all locations for which they are designated, used, or otherwise necessary, and all obsolete documents shall be promptly removed from all points of use or otherwise prevented from unintended use.
(b)Document changes. Changes to documents shall be reviewed and approved by an individual(s) in the same function or organization that performed the original review and approval, unless specifically designated otherwise. Approved changes shall be communicated to the appropriate personnel in a timely manner. Each manufacturer shall maintain records of changes to documents. Change records shall include a description of the change, identification of the affected documents, the signature of the approving individual(s), the approval date, and when the change becomes effective.
If your company is involved in performing clinical trials, you may want to read the following:
21 CFR 56.115 IRB Records
The Good Laboratory Practices, (GLPs), also include documentation practices:​
21 CFR 58.195 Retention of Records
L
linedraw
#20
You won’t find a detailed definition or explanation for "FDA Good Documentation Practice (GDP)". The reason is that if the FDA specifically defined the practice (GDP) and a company followed the FDA instructions then the liability would be on them (the FDA) if a company failed to meet the FDA requirements this area. Imagine a company responding to the FDA with words like “I followed exactly what you defined in your standard” or “your FDA standard said that this issue should be handled this way and we did it as defined”. How could the FDA respond to that? Also, for a body (FDA, etc.) to define "how to assure" may have a dramatic company cost impact which could be a whole new problem for a certification agency.
Instead, the FDA identifies what you need to "assure". How you assure is completely up to you and your company and then you will be measured by the FDA on if you met the intent of their words. Have you ever become involved in a discussion where their interpretation is different from theirs? Guess what, seeing that they wrote what you need to assure, they have the last word on what you need to do.
GDP can be defined by many companies in many ways. It’s not specifically one way, ”GDP” is defined/interpreted by the company person writing the internal P&P and hopfully it's in line with the auditing body (FDA or ISO certification house). Assurances can be accomplished in a number of ways, some easier than others some harder than others but they should all reach the same end goal.
Remember it's not the FDA, ISO cert house, or DoD responsibility to tell you how to do it but it is their responsibility to identify what you need to assure.
Thanks,
Linedraw
(Former DoD Auditor)
Sidney Vianna IS there such a thing as FDA "Good Distribution Practices" Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 10
F Is there such a thing as 'Critical supplier' status under the Dept. of Health (UK)? Medical Device and FDA Regulations and Standards News 2
B IVD or a general product test kit (if such a thing exists) EU Medical Device Regulations 0
U Is there such a thing as 1-part thermal cure epoxy? Manufacturing and Related Processes 11
Marc There's no such thing as Android, only Android-compatible After Work and Weekend Discussion Topics 2
A Is there such thing as Control of Information? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q Industry Standard burr on stamping-is there such a thing? Manufacturing and Related Processes 6
M Text Documentation - There is such a thing as overkill Document Control Systems, Procedures, Forms and Templates 2
J Is there such a thing as a 'Special Processes' in ISO 9001:2000? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B Product Safety Responsibility - Job shop such as a machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
D Is there a specific location for PPE such as safety glass holders and glove dispensers should be mounted Occupational Health & Safety Management Standards 10
DuncanGibbons OEM specifications such as AIPS spec from Airbus AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Qualification of Distributors such as McMaster-Carr and Digikey to Medical Device Companies ISO 13485:2016 - Medical Device Quality Management Systems 3
R Certificate of compliance to RoHS/REACH/WEEE - any such animal? REACH and RoHS Conversations 18
E Layouts : Can you "verify" things that are not visible (such as loctite present, internal dimensions) in a layout ? APQP and PPAP 2
A Audit purpose - case study - What is the role of SQE in such case? General Auditing Discussions 3
Q Calibration laboratory scope - Include software such as Gagetrak or Mini tab used? General Measurement Device and Calibration Topics 3
C Medical device file for components such as adhesives, gaskets, films, etc. ISO 13485:2016 - Medical Device Quality Management Systems 13
K Rules or guidelines for quoting FDA announcements and such? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
J Quality Testing for Tea, Electronic Noses and Such Manufacturing and Related Processes 5
A Insights on Transactional Ticket Audits such Parameters, Weighting Points, etc ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Procedures necessary for things such as the floor cleaner or weigh scale ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
R Immigration permit for countries such as Korea Immigration and Expatriate Topics 4
M Control of External Documents such as customer manuals AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 28
D SDS (MSDS) for complex products such as a TV, computer, cars, etc Miscellaneous Environmental Standards and EMS Related Discussions 3
N PFMEA for Non-Manufacturing Processes such as audits, direct procurement, etc. FMEA and Control Plans 5
B Existing reports and altering such reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B Paint Inspection - Paint Quality (such as rust, peel off, paint sag etc) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Hardware (Such as Rivets and Bolts) - Chemical and Physical Test Reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M MSA - Validation of Metrology Software such as PCDMIS Calibration and Metrology Software and Hardware 2
A Evaluation of Service Providers such as Consultants and Calibration Companies 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
V Evaluation of Paint Specifications including such as GM 9984123 and GM 14671 APQP and PPAP 1
A Internal Audits of various Processes such as Support Processes IATF 16949 - Automotive Quality Systems Standard 8
M 7.5.1.3 Should mentioned examples such as initial run be verified or validated? IATF 16949 - Automotive Quality Systems Standard 1
J Where to buy standards such as IEC 62366:2007 Other Medical Device Related Standards 2
C SPC for a Changing Process such as Tool Adjustments Design and Development of Products and Processes 23
D ISO/TS 16949:2009 - Why is it titled as such? IATF 16949 - Automotive Quality Systems Standard 7
N Capability on Parallel Processes such as Individual Mould Cavities Philosophy, Gurus, Innovation and Evolution 22
M Can the same form number be in Word and Excel for ISIR's and such? Document Control Systems, Procedures, Forms and Templates 9
B Quality Contracts with Clear Measures of Electronic Systems such as failure rate Quality Assurance and Compliance Software Tools and Solutions 5
M Auditing Test Management Software such as HP Quality Center (HPQC) Test Tool Internal Auditing 1
K True Position Checking such as Bolt Hole Position w.r.t Center Bore on Wheels Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
K What to look for when buying non-inventory products such as Gas & Electricity Service Industry Specific Topics 2
U Can I use Minitab (GLM) for such a case? Statistical Analysis Tools, Techniques and SPC 5
S MSA for Devices with NDT Technology such as a Thicknessmeter Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K Status Report to Management - How such a report should look like or contain? Quality Manager and Management Related Issues 20
L Outsourcing Special Processes such as Plating, Painting, NDT as related to AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
C Integrating Multiple Company Policies such Quality and an Environmental Policy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P Pest Control Activities such as Fogging for Cleanrooms ISO 13485:2016 - Medical Device Quality Management Systems 7
P Thank giving to Marc for such a informative form Coffee Break and Water Cooler Discussions 1
