Is this calibration work instruction adequate?
blue moon
is it required to make the clibration out side or we can do it internal ?
is this work instruction is enougth ? or it must show more details and be refrenced from the manfacturing
SUBJECT :
CALIBRATION PROCDURE FOR ALL MONITORING AND
MEASURING DEVICE
Objective
To confirm calibration of the monitoring and measuring devices
Scope : All measuring devices affecting product/process quality
Details
1.
Clean the instrument, which require calibration.
2. Ensure slip gauge block box having all slip gauges required
for calibration.
3 Set the instrument at zero setting
4 Ensure Zero error and reading zero on vernier or
digital readout
5 Measure 1.00 mm slip gauge with the instrument.
Record the difference in reading if any
6 Select the range of measurement required for given job
7 Select minimum 5 slip gauge in the given range
8 Repeat the step no. 5 with selected slip gauges for
example for the range of 1.00 to 10.00 mm as 3,5,8,10 mm.
9 Record the difference take average of the all five reading
10 Now use this average as reading difference for all your
measurement in the selected range
11 For all your measurement requirement follow this
Procedure
SteelMaiden
Re: is this enought work instruction for calibration
Can you show enough training of the folks doing the calibration to prove they know what they are doing? And, are they truly trained well enough to understand what they are doing without comprehensive work instructions? An auditor is probably going to want to know how the calibrator knows the acceptable tolerance, what should be done if the equipment is out of calibration and what information needs to be recorded, such as "as found" and "as left" dimensions. These are a few thoughts, there are others here who are more current in calibration than I.
Marc
What type(s) of measuring equipment is this procedure for?
BradM
Just a couple of technical things to go along with SteelMaiden's training points...
If these are calipers/micrometers, there is a certain amount of pressure/ # of clicks that one should apply when seating the block.
Will they need to wring blocks together for the measurement?
I don't see any tolerance assessment. How are they to know if it is in or out? What should they do?
Do you have another set of gauge blocks to use while your first set is out for calibration? Are your gauges of suitable accuracy for your tolerance?
A few things I noticed.:D
brahmaiah
SUBJECT :
MEASURING DEVICE
Objective
Details
1.
for calibration.
digital readout
Procedure
This Work instruction is inadequate.You cannot use this work instruction as a common instruction for all Measuring and Test Equipment(MTE).
Slip gauges are required only for some specific MTE.Variety of MTE IN industry are too innumerable and differ in design and application.
Ideally you have to write several work instructions to cover all your measuring equipment and one common master list of MTE with permissible error suitable to your product tolerances.
V.J.Brahmaiah
Stijloor
V.J.Brahmaiah
Can you post a few examples to help tech4arab?
Stijloor.
brahmaiah
Stijloor.
I donot have soft copies of Calibration work instructions.
If you want me to post Calibration procedure I can post it.
Calibration work instructions should be in line with ISO 17025 or applicable ASTM or other applicable testing standards .But allowable tolerances can decided by the organization based on its product tolerances.It is not practicable to specify tolerances from the testing standards as the standards specify tolerances applicable to brand new equipment.
V.J.Brahmaiah
BradM
We do appreciate the help. What Stijloor is asking is if you would be willing to post an adequate example of a procedure for slip gauges. If not, no big deal.
V.J.Brahmaiah
As to your point about tolerances, I agree, and appreciate hearing about others being more flexible in what tolerances they establish for their equipment.
tech4arab, I do think you should consider V.J. Brahmaiah's suggestion to see if there is an ASTM procedure for doing this work. An accepted (validated) standard is always better than trying to get one from scratch.
T Thread Gage Calibration / Verification Instruction needed General Measurement Device and Calibration Topics 21
J Caliper Calibration Instruction - Example Caliper Calibration Procedure Wanted General Measurement Device and Calibration Topics 23
Q Calibration Work Instruction Examples General Measurement Device and Calibration Topics 2
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
Crimpshrine13 Calibration of pH Meter Probe Calibration and Metrology Software and Hardware 3
F ESD workbench "calibration" Manufacturing and Related Processes 2
F Nist traceable calibration certificates General Measurement Device and Calibration Topics 1
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
T Calibration or Verification -> Cm and Cmk, etc. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
G Is repeatability required for equipment calibration? General Measurement Device and Calibration Topics 10
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Photovoltaic Tester Calibration General Measurement Device and Calibration Topics 0
B Temperature loop: partial calibration General Measurement Device and Calibration Topics 10
G Glass scale calibration at 74 degrees F? General Measurement Device and Calibration Topics 4
A Digital Timer Calibration Requirements General Measurement Device and Calibration Topics 3
Ron Rompen Barcode Verifier Calibration and Use Calibration and Metrology Software and Hardware 5
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
A Calibration of Power Supplies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D Calibration Process Flow Map Example Wanted General Measurement Device and Calibration Topics 3
