Is this procedure ISO 9001 Clause 4.2.3 Compliant?
treesei
#12
A quick comment:
"Approvals are required from: Design Engineer Document Control
Manufacturing Purchasing
Production Engineer Marketing
Materials
Once all parties have signed off on a change the DCS will execute the change."
Are you sure each and every document change will need the approval of all seven departments above?
E
EDH05
#13
They will not. I suppose it should read: Once all necessary parties have signed off on a change the DCS will execute the change. However, do I then have to have something included about who is required for what, or who determines who the necessary approvals are?
treesei
#14
I would recommned one. I don't know how your QMS document structure is, but usually a simple matrix (as part of the procedure or a child document) will do the trick. This matrix determines who the necessary approvals are.
K
Kirin
#15
Hello All,
I'm new to the forum and have been reading through the thread as it is relevant to some work that i'm currently undertaking.
Not wanting to hijack the thread :notme:, but I was wondering if any of you would be able to provide some criticism on the first draft of my document control procedure? I was going to start a fresh thread, but didn't want to clog up the board with similar topics, plus I thought that it might be more useful for future readers to have relevant content grouped in the same thread.
I realise that it is not necessary to formally address each section of the document control requirements of the standard as I have done, I just felt that for the first draft it helped to keep me on track.
Is it necessary to add 'Scope' and 'Purpose' sections, or is that considered a little old hat now?
Thanks in advance!
#16
Welcome to the Cove! I'm sure you'll get good responses.
From a format point of view, you may wish to de-couple the document from the ISO numbering. In 2000, a lot of companies had the exact problem because they had their procedures numbered as 4.5 - the doc control requirement of ISO 9001 1994. It's just work that doesn't need doing!
I prefer to kick the old school formats so yours is fine by me!
treesei
#17
From my regulatory background, to me it is very important that a document clearly have two elements, either as part of it or referred to somewhere else: The exact application (the scope) and the definitions of important terms.
Another minor comment: In a document, any activity that "should" be done may not be done while that "shall" be done must be done.
Stijloor
#18
I don't care what should or shall happen. I am more concerned with what IS happening. Write active voice, present tense.
Stijloor.
treesei
#19
Stijloor.
I am afraid that in an audit, you have to care. All laws/egulations/guidances are written with careful use of these two words. A deviation from "shall" will cost you an NC. A deviation from "should" may not if you know how to handle the situation. The former is a requirement; the latter, a suggestion/recommendation.:)
Stijloor
#20
I am referring to internal documents. BTW, I am an auditor...:)
Stijloor.
M Does ISO 9001 mandates cooking procedure for restaurants ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A ISO 9001:2015 registrar Auditor requesting copies of procedure prior to audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
Q Nonconforming procedure and ISO 9001-2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Can the mandatory procedures of ISO 9001-2008 be documented within one procedure? Document Control Systems, Procedures, Forms and Templates 5
I Interior Design Company Design Procedure Example wanted (ISO 9001:2008) Design and Development of Products and Processes 3
I ISO 9001:2008 4.2 Documentation - Where to put a Procedure Quality Manager and Management Related Issues 7
C How to do a procedure for ISO 9001 2008 7.3 Design and Development ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Control of Production Procedure - ISO 9001 Clause 7.5.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K ISO 9001 Clause 4.2.4 Control of Records - Documented Procedure help ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
D Quality Manual ISO 9001 Clause 7.3 Procedure examples wanted Document Control Systems, Procedures, Forms and Templates 2
U How to amend changes in HR procedure ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Control of Records Procedure (ISO 9001 Clause 4.2.4) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Boss wants Quality Procedure for ISO 9001 Clause 8.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
K How to update from Procedure to Process - ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R Definition Document vs. Record in ISO 9001 Procedure - Differences between and Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 20
A Purchasing Procedure example as per ISO 9001:2008 wanted Document Control Systems, Procedures, Forms and Templates 2
C Procedure is not Implemented - Audit Finding - ISO 9001 Clause 7.5.1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Product Realization Procedure - How to comply with ISO 9001 Clause 7.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
netwizard Inventory Assessment Procedure (ISO 9001) needed Document Control Systems, Procedures, Forms and Templates 4
T Calibration of "Working" Tools in Calibration Procedure - ISO 9001:2000 General Measurement Device and Calibration Topics 11
G Does ISO 9001 require a procedure for every part of the business? Document Control Systems, Procedures, Forms and Templates 8
K Marketing Procedure in line with ISO 9001:2000 QMS standard needed Document Control Systems, Procedures, Forms and Templates 2
D ISO 9001 Procedure Writing Tips Document Control Systems, Procedures, Forms and Templates 41
K Can ISO 9001 4.2.3 and 4.2.4 Documents and records be one procedure? Document Control Systems, Procedures, Forms and Templates 8
G ISO 17025 or IS0 9001 Training procedure - Needed ISO 17025 related Discussions 7
Antonio Vieira ISO 9001:2000 vs. ISO 10012:2003 Procedure and Related Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M ISO 9001:2000 Internal Audit Procedure - On the right track? Internal Auditing 10
Y Looking for Procedure to apply ISO 9001:2000 in my organization from respected people Document Control Systems, Procedures, Forms and Templates 7
I ISO 9001:2000 Preventive Action Procedure: Seeking examples ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q ISO 9001 / ISO 13485 - What is considered a 'documented' procedure? ISO 13485:2016 - Medical Device Quality Management Systems 5
Gman2 ISO 9001 and Requirements as related to SAFETY - Procedure Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
F Internal Communication Procedure - ISO 9001 5.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
R Customer Focus - Level 1 Procedure - Addressing ISO 9001 Clause 5.2 Document Control Systems, Procedures, Forms and Templates 3
Raffy Continuous Improvement in ISO 9001:2000 - Separate Procedure Required? Preventive Action and Continuous Improvement 4
M Purchasing Procedure - QSR ?820.50 and ISO 9001:1994 Clause 4.6 ISO 13485:2016 - Medical Device Quality Management Systems 3
A ISO 13485 procedure change and reflect to legacy manufacture items ISO 13485:2016 - Medical Device Quality Management Systems 2
F ISO 13485 8.2.3 Reporting to regulatory authorities: Question regarding a procedure for this clause. ISO 13485:2016 - Medical Device Quality Management Systems 4
F Hi friends, can anyone show me an example of a procedure for ISO 13485 6.4.1 Work Environment? ISO 13485:2016 - Medical Device Quality Management Systems 2
F ISO 17025:2017 Format for Procedure and Records Document Control Systems, Procedures, Forms and Templates 3
S Procedure on Privacy Policy in the ISO 13485 quality management system ISO 13485:2016 - Medical Device Quality Management Systems 3
R ISO 13485 Software validation procedure and Quality Objectives Monitoring wanted Document Control Systems, Procedures, Forms and Templates 1
D Risk Assessment Procedure in accordance with ISO 17025:2017 ISO 17025 related Discussions 5
J ISO 17025 - Please share a sample procedure for monitoring the validity of results ISO 17025 related Discussions 1
J ISO 13485 8.4 Analysis of Data - Procedure example ISO 13485:2016 - Medical Device Quality Management Systems 1
C Is a First Article Inspection (FAI) Procedure required by ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
Y My mission is to draft a procedure related to ISO 14155 - Good Clinical Investigation Practices Other Medical Device Related Standards 1
S The procedure for replicate check in calibration lab as per ISO 17025 General Measurement Device and Calibration Topics 2
A ISO 14001:2015 transition audit - Major NC due to the procedure and audit plan ISO 14001:2015 Specific Discussions 10
S Risk Based Approach for ISO 13485:2016 Form/Procedure ISO 13485:2016 - Medical Device Quality Management Systems 23
