Is Validation of Plating Processes required and who is responsible?
I work at an electroplating company and we plate quite a few components that are used in medical devices. I'm wondering when OQ/PQ is required. GHTF says that plating processes should be validated, but if we perform inspection after plating (using a sampling plan) and we test for CTQ outcomes such as plating adhesion and plating thickness, aren't we verifying the process each time we plate an order?
Secondly, I'm wondering who is responsible for determining if validation is required. We are providing the plating service for another company who is supplying the material to be plated and then they are using the parts with our plating in their medical device. If our customer says they want us to start plating a part for them, do we need to be performing a validation, or do we only need to do it if they request it from us?
William55401
Typically, medical device companies request component process validation of their suppliers as part of component purchasing controls. Mature component suppliers will have validation methods well defined for the med device customer to review outcomes. Less mature component suppliers will need help from the med device customer in developing their validation approaches.
Update. I am not experienced in plating process validation. I did look at the GHTF and see plating grouped in with molding. To me, the decision to validate is made based on the GHTF grouping.
So what about the opposite where the med device customer is not mature and they send us a new product to plate. Are we just supposed to plate it and send it to them without doing any validation work? Or do we need to perform a formal validation running an OQ to low and high settings followed by a PQ with 3 runs at nominal settings? Do we just leave it up to them and relinquish responsibility for it? It seems like overkill to perform a validation for a battery contact being used in a medical device. It seems legitimate for a surgical implant, but then if we're sampling and performing inspection on every lot it doesn't really seem that useful either.
John Broomfield
Like welding, plating is a special process where the product cannot be fully verified without destroying the product. So, the design of a special process has to be validated.
Your customers, naturally will want to engage a plating company that has a suite of current validated plating processes that match their requirements. Before accepting their business you will review each customer's requirements to confirm your ability to fulfill their requirements.
If not currently able you may be able to change the customer for design and validation of the plating process they seek, or you may have to do this yourselves to prequalify for their PO.
Therefore we design each plating processes to result in a spec to control the critical variables and then we validate each spec by making and testing samples to destruction.
We may then be assured of quality by plating strictly in accordance with the validated plating spec.
William55401
Good response from the moderator. Here's my take. As a supplier, you need to do the right thing and look out for your customer as well as protect the compliance status of your firm. Question. Are you 13485 certified? (Some component suppliers are). As part of contract review, that is the time to educate the customer on validation requirements. These will come at a cost and your firm must price them accordingly to account for the time and effort.
John Broomfield
Test coupons may be used to validate the plating process.
But testing the bond strength (of electroplated chromium for example) may require use of one of these quantitative test methods:
...of these, I understand, only the qualitative Heat/Quench test is nondestructive which may be insufficient for the customer's purpose.
From ASTM B571 − 2013
Qualitative nondestructive testing is done all the time on plated parts. Occasionally a sacrifice is needed, as when doing a microsection for plating thickness, or a bend test, but destructive testing isn't the norm. Even if it's done it doesn't mean that plating always requires destructive testing. Whether or not validation is prudent depends on the circumstances.
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
P Validation of Plating Process for Medical Devices Qualification and Validation (including 21 CFR Part 11) 8
Q ISO 13485 7.5.6 Validation - Off the shelf Software ISO 13485:2016 - Medical Device Quality Management Systems 3
M ERP / QMS related software standards for Validation IEC 62304 - Medical Device Software Life Cycle Processes 6
C ISO 19227 Validation Cost Other Medical Device Related Standards 2
A CNC Mill and Lathe - Validation Manufacturing and Related Processes 2
N Sterilization Protocol Change in Validation Process and further impacts ISO 13485:2016 - Medical Device Quality Management Systems 1
B Oracle Cloud ERP Validation during Quarterly Patch ISO 13485:2016 - Medical Device Quality Management Systems 1
D Software validation team Misc. Quality Assurance and Business Systems Related Topics 3
J Validation Sample Size for Tray Seal Qualification and Validation (including 21 CFR Part 11) 1
F AS9100 - Validation, FAIR's, ITAR and Sub-Contracting AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R PCBA process validation Qualification and Validation (including 21 CFR Part 11) 2
A ISO 17025 - Methods validation and clients ISO 17025 related Discussions 3
S Sterilization validation after changing sterilization process provider Qualification and Validation (including 21 CFR Part 11) 3
B Sterilization Validation Plan Other Medical Device Related Standards 3
D Test Method Validation Qualification and Validation (including 21 CFR Part 11) 4
T Laboratory Verification after validation ISO 17025 related Discussions 3
silentmonkey Rationalising the level of effort and depth of software validation based on risk ISO 13485:2016 - Medical Device Quality Management Systems 10
D Questions regarding process validation ISO 13485:2016 - Medical Device Quality Management Systems 6
Y We found out we have been using a equipment without validation for past 4 years Quality Manager and Management Related Issues 6
Z Is IQ necessary for laser marking validation? EU Medical Device Regulations 3
E 13485:2016, Sections 4.1.6, 7.5.6 and 7.6 - Validation of Software - Need some Advice please ISO 13485:2016 - Medical Device Quality Management Systems 3
A Validation of Forced Aeration Process ISO 13485:2016 - Medical Device Quality Management Systems 3
M API 4F/7K/8C Design Package Validation Oil and Gas Industry Standards and Regulations 2
I ISO 2233:2000 Question - Medical Device Shipping/Transportation Validation Other ISO and International Standards and European Regulations 1
B TMV - Selection of TM's for Validation ISO 13485:2016 - Medical Device Quality Management Systems 5
S Forced ServiceNow validation - No change in our current user and functional requirements IT (Information Technology) Service Management 6
P Human Factors / Usability validation in the time of COVID Human Factors and Ergonomics in Engineering 18
C Template for Excel Validation Reliability Analysis - Predictions, Testing and Standards 6
M IT validation for a paper based MD repair company QMS ISO 13485:2016 - Medical Device Quality Management Systems 6
P Unrealistic Packaging Validation Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
D Test summary report example for design validation wanted - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
T ISO 13485 - Process validation at critical suppliers ISO 13485:2016 - Medical Device Quality Management Systems 7
K Software Validation for Measurement Tools used in Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
Stoic Manual soldering processes - 100% verifiable, or always requiring validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Rees System Validation Qualification and Validation (including 21 CFR Part 11) 1
K PQ validation qualification - Asked to write a PQ protocol ISO 13485:2016 - Medical Device Quality Management Systems 6
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
K Old medical devices -> 7.3.7. Design and development validation ISO 13485:2016 - Medical Device Quality Management Systems 1
S SOP for ISO 13485:2016 Quality related Software validation ISO 13485:2016 - Medical Device Quality Management Systems 9
Y Retrospective Validation - Class I device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
S High voltage testing - ISO 17025 - 7.2.2 Validation of methods and 7.3 Sampling ISO 17025 related Discussions 3
M Production approval testing - Alternative ideas for Validation Reliability Analysis - Predictions, Testing and Standards 4
M Validation of two nearly identical products Other Medical Device Regulations World-Wide 5
J Requested Validation plan and reports Manufacturing and Related Processes 4
