Is Wafer Probe (On Wafer Test) a Laboratory? Semiconductor Industry
dlsquality
To My Semiconductor Friends:
Does a wafer probe (or on wafer test) operation qualify as a laboratory as defined in ISO/TS 16949?
Jen Kirley
Quality and Auditing Expert
Re: Is Wafer Probe a Laboratory?
Welcome to The Cove! :bigwave:
I have seen such inspection/reliability analysis activities listed in alignment with 7.6.3.1 although most often I expect people to consider it a calibration control element because of the note commenting about ISO/IEC 17025.
V
vanputten
Hello Dlsquality:
I reviewed the defintion for "laboratory" which is 3.1.4 in T 16949. Then I reviewed the definition for laboratory in the Semiconductor Supplement, which is on page 11 of 27. clause 3.1.5S.
After that, I re-read 7.6.3, 7.6.3S, and 7.6.3.1S.
I have some ideas but would like to hear your thoughts first.
7.6.3 Internal Laboratory applies to test, inspection, or calibration services.
To Jennifer: By the way, IEC/ISO 17025 is applicable to all organizations performing tests and/or calibrations. The scope of IEC/ISO 17025 is greater than just calibration. These tests and/or calibrations can be a component of inspection and product certification.
Regards,
Dirk
dlsquality
Based on the semiconductor supplement definition of laboratory (i.e. laboratories are those facilities that perform reliability, qualification or durability testing to the requirements of a customer documented specification), it doesn't appear that the wafer probe area would fall under that definition. Right?
Q
qualityboi
It's not a lab. Reliability testing is usually done in QA. Probe is more of a final electrical test at wafer level. I don't think its the intent of the standard to call any process that qualifies or tests product a lab nor does either standard state what you do and don't call a lab, it only states the requirements for a lab.
Here is an example of what the quality manual states for AMI semiconductor who is registered to the 16949 and it passes just fine...
9.6.1 Laboratory Requirements
The responsibility for performing test and calibration to meet the requirements of AEC-Q100 is under the control of our internal qualified laboratory as well as under commercial independent qualified laboratories or external best in the market in the given country.
9.6.1.1 Internal Laboratory
All laboratories in AMIS are engineering laboratories without any certification rights and can be used only for verification of the product performance.
Laboratory scopes and flow are available for laboratories that perform repetitive activities that need safety regulations, related to validation processes and customer feedback.
9.6.1.2 External Laboratory
For calibration of test and measurement equipment, accredited laboratories (if possible commercially independent) are used. Calibration can be done either by calibration labs (external calibrations) or per AMIS #5500103, Product Realization and Process System Requirements.
Hershal
Metrologist-Auditor
Your operation may potentially be considered a lab.....not a hard and fast truth however.....
What are you testing for and under what criteria? If you are checking functionality, then an argument can be made that the operation is a lab, whether at the end of the production line or in a separate room.
If a lab, then consider whether to seek accreditation under ANS/ISO/IEC 17025.
Just some thoughts.
Hershal
V
vanputten
Hello All:
I agree with what everyone has posted. I think if someone wanted to play hardball, they could make a case that wafer sort is a lab based on the defintions and the wording of TS 16949 and the Semiconductor Supplement. I hope that the intent of these requirements is as is stated in this thread; wafer sort is NOT performed in a "lab."
We don't consider electrical test during wafer fabrication, wafer sort, or IC electrical test (final test) a "Laboratory" or lab function. We consider these to be inprocess / final inspections. We do consider failure analysis and product qualification to be performed in a "lab" and apply the 7.6.3 requirements to these areas.
It is my expereince that other semiconductor manufactueres do the same thing.
I think Dlsquality has asked an excellent question particularily for the semiconductor industry.
Thank you for asking the quesiton!
Regards,
Dirk
V
vanputten
Forgot to add....
Qualityboi stated "nor does either standard state what you do and don't call a lab,"
I think 3.1.4 of TS and 3.1.5S of the Semiconductor Supplement do state what is done in a lab. The definitions do not state what is a lab (room, area, facility, etc.) but they do state what is done in a lab. Based on the defintions, a lab is any location where these activites are performed, imho.
Thankfully the Semiconductor Supplement seems to reduce the scope of activities in a lab to "reliability, qualification, and durability testing" which matches what is discussed in this thread.
Regards,
Dirk
Q
qualityboi
Well I think you know where I am coming from, which is reducing the scope to what is reasonable. We don't call the Probe and Test processes a lab at our semi-con facility, nor do we apply those standards. I don't think anyone else in the industry does either (two I know of do not and are certified), but who knows you could get a 3rd party auditor that thinks anywhere qualification, reliability and testing intersects the process should be called a lab. Good topic!
D GR&R (Gage R&R) for Automated Wafer Probe Testers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K Please share a Product Audit Checklist for a Wafer Fab Document Control Systems, Procedures, Forms and Templates 3
L ESD for Class 2 Wafer Fab products Manufacturing and Related Processes 2
R Sampling Plan for Wafer Inspection (Small Lot) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
O What Class Clean Room Requirement for 0.8 um process - Wafer Foundry Manufacturing and Related Processes 5
B Precision Current Loop for Current Probe Calibration Reliability Analysis - Predictions, Testing and Standards 2
Ron Rompen Question regarding CMM probe damage General Measurement Device and Calibration Topics 4
M 'Active' device? Software/laptop with attached camera 'looking' at passive metal probe EU Medical Device Regulations 3
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
Crimpshrine13 Calibration of pH Meter Probe Calibration and Metrology Software and Hardware 3
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
W Insulation requirements of BF type infant skin temperature probe IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
T Pulse oximeters ISO 80601-2-61, is 0% okay for probe fault? US Food and Drug Administration (FDA) 4
J CMM Probe Certification General Measurement Device and Calibration Topics 1
A Salt Bath Probe Style SAT requirement Waiver per AMS 2750 Rev E Section 3.4.7 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Marc USA to insist on pre-flight mobe power probe Travel - Hotels, Motels, Planes and Trains 3
G Comparison Study of CMMs and software along with Probe Types Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
M Calculating Coefficients for an RTD (Resistance Temperature Detector) Probe General Measurement Device and Calibration Topics 3
F Additional Isolation Required? Doppler Probe Desktop Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
S BS 5682 ? Carbon Dioxide Probe? Other ISO and International Standards and European Regulations 2
S CMM Hardware - Renishaw Probe Magnetism question Calibration and Metrology Software and Hardware 8
V CNC Probe Qualification and DME Interface General Measurement Device and Calibration Topics 4
R Defining the type of Applied Part - Metal Probe (Applied Part) employs Water Cooling IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B Interpol to Probe Bulgaria for Certification Fraud Registrars and Notified Bodies 11
E Change in Electrocardiogram (EKG) Probe Material - New 510(k) required? Other US Medical Device Regulations 1
G Effects of CMM Probe Tip Ball Size measuring a Round Part OD - CMM Help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
K Probe on CNC machine - Inspecting on cnc machine tools vs. CMM Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Marc Criminal probe launched into Toyota's safety problems World News 25
M Reference Thermocouple Probe (TRP) Calibration General Measurement Device and Calibration Topics 5
M Can an Internal Buttress Thread be inspected with a Zeiss CMM with a scanning probe Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R Starrett AV612 (combo vision and touch probe) Galileo Instrument Software Validation General Measurement Device and Calibration Topics 3
T FMEA for Testing and Test Development such as ICT, Flying Probe, Boundry Scan for PCA FMEA and Control Plans 3
N CMM Reference Probe Drift General Measurement Device and Calibration Topics 4
Ajit Basrur Teva recalls drug following Jackson death probe Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
T Calibration of a digital usb temprature probe. General Measurement Device and Calibration Topics 3
A Qualifying a CMM Star Probe - Brown/Sharpe CMM Model Gage 2000 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
Q Auditor Access to Records - How far an Auditor can Probe ISO 13485:2016 - Medical Device Quality Management Systems 19
Ron Rompen CMM Probe Size Selection when doing a CMM Layout of a Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
apestate CMM probe tip qualification -- why do it? General Measurement Device and Calibration Topics 20
apestate CMM Star Probe Numbering - Bottom, Back, Left, Front, Right vs. 1, 2, 3, 4, 5 General Measurement Device and Calibration Topics 5
