ISO 10993-5:2009 vs. ISO 10993-5:2003 differences - Cytotoxicity Testing
hi all ,
Do any one know about this updated standard of cytotoxicity testing . when will it apply to europe.
what is the difference between 10993-5:2003 and this new one?
Ajit Basrur
hi all ,
Hi waziz,
The old ISO 10993 was 1999 and not 2003. Refer the ISO website.
The standard to be available as EN ISO 10993-1:2009 was 10 Jun 09 - refer page 26 and 36 HERE - I have no update above this.
Let us see if there are more responses :)
RUBI
I have carried out cytotoxicty test (as per ISO 10993-5) on raw material of the medical device. Now is it necessary to carry out a test on medical device as well or is it okay to establish equivalence with the report of raw material?
If yes, how can i show the equivalence?
Thankyou
planB
Rubi,
per ISO 10993-1:2018 (or 2009), you have to evaluate the biocompatibility of the _final_ device according to its intended use as it comes into patient contact. Testing, including a cytotoxicity test, is only warranted if your existing data does not allow you address all trelevant biologiocal endpoint via material characterization - refer to Table A.1.
Cytotoxicity testing of raw material alone is typically not sufficient to establish biocompatibility of your medical device.
What kind of equivalence do you want to show?
HTH,
Gerhard
RUBI
Rubi,
HTH,
Gerhard
Thank you for your reply,
i want to show equivalence of cytotoxicity test of raw material(SS) with finished product for same test not for all biocomapatibility tests. Is it possible?
planB
Rubi,
yes, you can establish equivalence in terms of cytotoxicity: ISO 10993-5:2009, section 8.5, provides you with a qualitative and quantitative scoring system. If you reach at the same score for two materials after the same test, you could claim equivalence in terms of cytotoxicty.
Please note the caveat that I mentioned above: this evidence alone is not sufficient, as ISO 10993-5 specifically says in section 10, Assessment in results:
The overall assessment of the results shall be carried out by a person capable of making informed decisions based on the test data. Cytotoxicity data shall be assessed in relation to other biocompatibility data and the intended use of the product. The interpretation of the results of the cytotoxicity test shall take into account the classification of the device as given in ISO 10993-1. [...]
Any cytotoxic effect can be of concern. However, it is primarily an indication of potential for in vivo toxicity and the device cannot necessarily be determined to be unsuitable for a given clinical application based solely on cytotoxicity data.
The key to establishing biocompatibility is a risk assessment according to ISO 10993-1 and a thorough material characterization according to ISO 10993-18.
HTH,
Gerhard
E Meeting ISO 10993-1 2009 Material Risk Assessment Requirements Other Medical Device Related Standards 13
I ISO 10993-1:2009 Sensitization (Initial Evaluation Test) vs. USP Other Medical Device Related Standards 3
R What the difference in ISO 10993-11:2006 and 2009? Other Medical Device Related Standards 17
R ISO 10993-1:2009 incorporating Risk Management published by ISO ISO 13485:2016 - Medical Device Quality Management Systems 1
S Knee Implant (Femoral -Cobalt chrome)-Sub chronic toxicity test (ISO 10993-11)choice of root Medical Device and FDA Regulations and Standards News 2
R ISO 10993-18 Medical Device and FDA Regulations and Standards News 1
M ISO 10993-17 - Ancillary Medicinal substance leachables Medical Device and FDA Regulations and Standards News 1
M Medical Devices - Ancillary - ISO 10993-17 Medical Device and FDA Regulations and Standards News 6
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
L Biological Assessment (ISO 10993-1) Other Medical Device Related Standards 1
L Process changes and biocompatibility (ISO 10993-1) Other Medical Device Related Standards 1
S ECG Cable Banana to Snap or Tab electrode Adapters -- ISO 10993 Requirement Other Medical Device Related Standards 0
K Diagnostic X-ray devices - Applicability of Biocompatibility Testing per ISO 10993-1 Manufacturing and Related Processes 7
A ISO 10993-7:2008/ Amd.1:2019 - Classification of special populations Other Medical Device Related Standards 3
P European versions of standards - ISO 10993-1 and ISO 11607-1 EU Medical Device Regulations 6
S ISO 10993 Biocompatibility Evaluation - Electronic thermometer Other Medical Device Related Standards 3
P ISO 10993-1:2018 - When will the European equivalent become a Harmonized Standard? Other Medical Device Related Standards 13
I ISO 10993 Biocompatibility Requirements - manufacturing process chemicals Other Medical Device Related Standards 8
N Technical File Reviewer has requested more testing to ISO 10993 Other Medical Device Related Standards 10
T ISO 10993-7 - Ethylene oxide sterilization residues Other Medical Device Related Standards 1
planB ISO 10993-1:2018 has just been published Other Medical Device Related Standards 2
M Does ISO 10993 Apply to Packaging? (e.g. Travel Case) Other Medical Device Related Standards 4
K ISO 10993 Requirements For 510k - Substantial Equivalence Other US Medical Device Regulations 11
T Using Risk Management in ISO 10993 - Medical Device Accessory 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P ISO 10993 - Sterile (Irradiation) Polypropylene Syringe Question Other Medical Device Related Standards 6
D Actual Definition of Non-Contact for ISO 10993 Other Medical Device Related Standards 1
R Biocompatibility - ISO 10993 and SVHC Requirements Other Medical Device Related Standards 4
S ISO 10993-1: External Communicating Device biocompatibility test requirements Other ISO and International Standards and European Regulations 4
S Selecting materials for implants to comply with ISO 10993 biocompatibility Other Medical Device Related Standards 4
T Plastic of an infusion pump enclosure and ISO 10993 ISO 13485:2016 - Medical Device Quality Management Systems 2
E Upcoming changes for ISO 10993 and IEC 60601 in South Korea Other Medical Device Regulations World-Wide 2
M FDA issues draft guidance to replace G95-1 (Application of ISO 10993) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B Verify GB/T 16886 is the same as ISO 10993 US Food and Drug Administration (FDA) 5
B New ISO 10993-12 - Consistency of Extraction Conditions through different Assays Other ISO and International Standards and European Regulations 1
S Suppliers of ISO 10993 compliant Material for Skin Contact Other ISO and International Standards and European Regulations 3
M ISO 10993 - Repeat tests necessary if colour changes slightly? Other Medical Device Related Standards 11
M Pre-Selecting Materials for ISO 10993-1 Biocompatibility Compliance Other ISO and International Standards and European Regulations 5
F ISO 10993-10 - Removed from List of Harmonized Standards Other Medical Device Related Standards 4
S ISO 10993 Cytotox Testing - Direct Contact rather than Extractables Other Medical Device Related Standards 4
M ISO 10993 Labs which can test Cytotoxicity, Sensitizaton and Irritation Other Medical Device Related Standards 10
M ISO 10993 for Fabric based Electrode - Finding already FDA Approved Materials Other Medical Device Related Standards 11
J Biological Evaluation requirements per ISO 10993 - Medical Device Testing ISO 13485:2016 - Medical Device Quality Management Systems 2
A Claiming Biocompatibility without ISO 10993-1 Other Medical Device Related Standards 19
J ISO 10993 (Biological Compatibility) Approved Materials US Food and Drug Administration (FDA) 23
T ISO 10993-10: 2002 vs 2010 version - What are the Major Changes? ISO 13485:2016 - Medical Device Quality Management Systems 2
W ISO 10993 (Biological Evaluation of Medical Devices) for Suppliers Other ISO and International Standards and European Regulations 8
I EO (Ethylene Oxide) Residuals - EN ISO 10993-7:2008 EU Medical Device Regulations 5
D Does anyone know of a biocompatible ABS tested & certified to ISO 10993-1 Other Medical Device Related Standards 5
W ISO 10993 - Replacing Sensitization Test with Systemic Toxicity Test? Other Medical Device Related Standards 4
I ISO 10993-10:2010 Guidance Document for Irritation and Sensitization Test - Changes ISO 13485:2016 - Medical Device Quality Management Systems 3
