ISO 10993 - Repeat tests necessary if colour changes slightly?
mr.mike
Hi Everyone,
We are wanting to submit samples for Biocompatibility testing (ISO 10993), but the colour is slightly off. I'm curious if there's some way to argue equivalence given that the colouring process is identical, albeit with different proportions of CMYK.
For example, suppose you have a blue rubber ISO 10993 tested, and passed. Then, marketing decides the blue should be slightly lighter. Does this then mean that all the biocompatibility tests have to be repeated? Or can it be argued that the colours and dyes are still the same, just mixed in slightly different proportions?
I realize that what is tested should (ideally) be identical to the final product. But it also seems that design changes involving identical materials, just in slightly different quantities, necessitating a complete re-testing is unreasonably onerous.
Any advice or discussion much appreciated.
MM
MIREGMGR
...suppose you have a blue rubber ISO 10993 tested, and passed. Then, marketing decides the blue should be slightly lighter. Does this then mean that all the biocompatibility tests have to be repeated? Or can it be argued that the colours and dyes are still the same, just mixed in slightly different proportions?
FDA regulates color additives because of legacy problems with carcinogenicity and toxicity of substances used for that purpose in the past. The various rules are indexed at http://www.fda.gov/forindustry/coloradditives/default.htm.
If an additive by itself has been formally shown to be safe (i.e. "GRAS") up to a specified concentration and you use it at a concentration that does not exceed that specification, the specific quantity of additive used in a particular polymer batch should not be relevant.
If an additive by itself has not been formally shown to be safe but you have shown it to be safe in a particular concentration as blended into a polymer batch, you can infer from that testing that it also will be safe at a lower concentration.
NikkiQSM
Hi Everyone,
MM
If you were to change the colorant used - then BioComp testing would of course be required again.
If you are going to change the amount of colorant used - as long as it is not a drastic difference in the original amount - you should be fine with not conducting the testing again.
MIREGMGR
My understanding is:
True if the amount of colorant is decreased.
Not true if the amount of colorant is increased.
This of course assumes that the colorant is not GRAS. If it is, the problem goes away.
Ronen E
Problem Solver
Moderator
If you are unsure, you can ask a 3rd party biocomp. test lab (e.g. NAMSA, no affiliation) expert-toxicologist to review your specifics and issue a formal written opinion. Might come handy later, if questions are asked during inspection.
If the change is not big, most chances it will end with a remote desktop review and no testing.
mr.mike
Yes, I did inquire to 3rd party test labs. In my experience, regardless of the question, they are always pretty vague. The standard answer is something along the lines of "it should be the same as the final product. If not, you will have to justify why it's not."
Fair enough. I'm sure they're just covering themselves, as it's not their responsibility to be giving definitive regulatory advice.
As it is, I'll take a look at the FDA approved list of colourants for medical devices (and cross my fingers the ones used are on it). Barring that, luck would have it that the samples we submitted have higher amounts of all CMYK than the final colour, so we can always justify as suggested by MIREGMGR.
Thanks everyone!
Ronen E
Problem Solver
Moderator
Did you ask for the casual "free advice" or did you offer to pay for a proper review and a written expert opinion? One usually gets what they pay for.
AJayC
Color Additives For Medical Devices
If you use a "direct food contact ink" for printing on a medical device, for the 510K submission are we required to list the color additive in the ink?
The device's intended use will mean the printed area of the device will touch human skin for a short period (<24hrs). Therefore, Biocompatability testing will be performed on the finished product.
S Knee Implant (Femoral -Cobalt chrome)-Sub chronic toxicity test (ISO 10993-11)choice of root Medical Device and FDA Regulations and Standards News 2
R ISO 10993-18 Medical Device and FDA Regulations and Standards News 1
M ISO 10993-17 - Ancillary Medicinal substance leachables Medical Device and FDA Regulations and Standards News 1
M Medical Devices - Ancillary - ISO 10993-17 Medical Device and FDA Regulations and Standards News 6
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
L Biological Assessment (ISO 10993-1) Other Medical Device Related Standards 1
L Process changes and biocompatibility (ISO 10993-1) Other Medical Device Related Standards 1
S ECG Cable Banana to Snap or Tab electrode Adapters -- ISO 10993 Requirement Other Medical Device Related Standards 0
K Diagnostic X-ray devices - Applicability of Biocompatibility Testing per ISO 10993-1 Manufacturing and Related Processes 7
A ISO 10993-7:2008/ Amd.1:2019 - Classification of special populations Other Medical Device Related Standards 3
P European versions of standards - ISO 10993-1 and ISO 11607-1 EU Medical Device Regulations 6
S ISO 10993 Biocompatibility Evaluation - Electronic thermometer Other Medical Device Related Standards 3
P ISO 10993-1:2018 - When will the European equivalent become a Harmonized Standard? Other Medical Device Related Standards 13
I ISO 10993 Biocompatibility Requirements - manufacturing process chemicals Other Medical Device Related Standards 8
N Technical File Reviewer has requested more testing to ISO 10993 Other Medical Device Related Standards 10
T ISO 10993-7 - Ethylene oxide sterilization residues Other Medical Device Related Standards 1
planB ISO 10993-1:2018 has just been published Other Medical Device Related Standards 2
M Does ISO 10993 Apply to Packaging? (e.g. Travel Case) Other Medical Device Related Standards 4
K ISO 10993 Requirements For 510k - Substantial Equivalence Other US Medical Device Regulations 11
T Using Risk Management in ISO 10993 - Medical Device Accessory 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P ISO 10993 - Sterile (Irradiation) Polypropylene Syringe Question Other Medical Device Related Standards 6
D Actual Definition of Non-Contact for ISO 10993 Other Medical Device Related Standards 1
R Biocompatibility - ISO 10993 and SVHC Requirements Other Medical Device Related Standards 4
S ISO 10993-1: External Communicating Device biocompatibility test requirements Other ISO and International Standards and European Regulations 4
S Selecting materials for implants to comply with ISO 10993 biocompatibility Other Medical Device Related Standards 4
T Plastic of an infusion pump enclosure and ISO 10993 ISO 13485:2016 - Medical Device Quality Management Systems 2
E Upcoming changes for ISO 10993 and IEC 60601 in South Korea Other Medical Device Regulations World-Wide 2
M FDA issues draft guidance to replace G95-1 (Application of ISO 10993) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B Verify GB/T 16886 is the same as ISO 10993 US Food and Drug Administration (FDA) 5
B New ISO 10993-12 - Consistency of Extraction Conditions through different Assays Other ISO and International Standards and European Regulations 1
S Suppliers of ISO 10993 compliant Material for Skin Contact Other ISO and International Standards and European Regulations 3
M Pre-Selecting Materials for ISO 10993-1 Biocompatibility Compliance Other ISO and International Standards and European Regulations 5
F ISO 10993-10 - Removed from List of Harmonized Standards Other Medical Device Related Standards 4
S ISO 10993 Cytotox Testing - Direct Contact rather than Extractables Other Medical Device Related Standards 4
E Meeting ISO 10993-1 2009 Material Risk Assessment Requirements Other Medical Device Related Standards 13
M ISO 10993 Labs which can test Cytotoxicity, Sensitizaton and Irritation Other Medical Device Related Standards 10
M ISO 10993 for Fabric based Electrode - Finding already FDA Approved Materials Other Medical Device Related Standards 11
J Biological Evaluation requirements per ISO 10993 - Medical Device Testing ISO 13485:2016 - Medical Device Quality Management Systems 2
A Claiming Biocompatibility without ISO 10993-1 Other Medical Device Related Standards 19
J ISO 10993 (Biological Compatibility) Approved Materials US Food and Drug Administration (FDA) 23
T ISO 10993-10: 2002 vs 2010 version - What are the Major Changes? ISO 13485:2016 - Medical Device Quality Management Systems 2
W ISO 10993 (Biological Evaluation of Medical Devices) for Suppliers Other ISO and International Standards and European Regulations 8
I EO (Ethylene Oxide) Residuals - EN ISO 10993-7:2008 EU Medical Device Regulations 5
D Does anyone know of a biocompatible ABS tested & certified to ISO 10993-1 Other Medical Device Related Standards 5
W ISO 10993 - Replacing Sensitization Test with Systemic Toxicity Test? Other Medical Device Related Standards 4
I ISO 10993-10:2010 Guidance Document for Irritation and Sensitization Test - Changes ISO 13485:2016 - Medical Device Quality Management Systems 3
M EO (Ethylene Oxide) and ECH (Ethylene Chlorohydrin) Residual as per ISO 10993-7:2008 ISO 13485:2016 - Medical Device Quality Management Systems 15
I ISO 10993-1:2009 Sensitization (Initial Evaluation Test) vs. USP Other Medical Device Related Standards 3
B What ISO 10993 considers Non-Invasive vs. Invasive MDD 93/42/EEC EU Medical Device Regulations 3
C Differences between the biocompatibility standards ISO 7405 and ISO 10993 Other Medical Device Related Standards 2
