ISO 11137 - Verification dose audit for VD max method
muzammil21ad
Hi All,
I need one help with respect to verification dose audit for VD max method, we are validating our gamma sterilization process, i face problem with respect to verification dose audit, my gamma subcontractor have dose range starting at 9kGy only but my bio burden is less so the verification dose according to table 9 of 11137 is 7.5kGy,
so please let me know how i should complete my verification dose audit with this type of challenge
:thanx:
brianthermophilus
If that's your only dose option and your bioburden is lower, I would run your samples through 9kgy and perform material & packaging assessments to confirm that your product may withstand a higher dose. Nothing wrong with a higher dose as long as your product can handle it.
muzammil21ad
Thanks for your comments, this is verification dose to have confidence on my sterility not material compatibility excersise
Sent from my iPhone using Tapatalk
pkost
I would suspect using a higher dose will make the validation ineffective - from recollection the dose is low enough to give a an SAL of 1x10^-2....The subsequent sterilisation tests are sufficiently powered establish the SAL is validated....if you use a higher verification dose then the sterility tests will not be sufficiently powered
I think it is permitted to carry out the VDmax study at any facility, it does not have to be the main site of sterilisation - if you can find somewhere that operates at 7.5kGy, that may be a solution
muzammil21ad
I think doing dose mapping with 2 different other sources will give you different uncertainty and sterilizing agent characteristics , i am not sure if standard allow me to do ths because i am not as much expert than you may be pls correct me if i am wrong, if it is ok thn my prblm is solved
pkost
From my understanding, the dose setting is to demonstrate that the the 25kGy is sufficient to give an SAL of 10-6...25kGy is the same regardless of equipment used; the sterilising agent is gamma radiation...it's consistent
Dose mapping is different as it demonstrates that the entire load receives a dose of 25kGy...I suspect that this may need to be carried out in the intended sterilising facility, but I'm not sure.
The lab that is conducting the validation for you should be able to answer these questions and provide more qualified guidance!
R Microbiological test (USP61, USP62, USP71, ISO 11137.1, ISO11137.2) --- Testing flow chart Other Medical Device Related Standards 0
R What are the new changes in EN ISO 11137-1:2015+A2:2019? Other Medical Device Related Standards 2
S ISO 11137- Simulated product vs SIP Other Medical Device Related Standards 2
F Irradiation Sterilization Validation Maximum Dose - VDmax 25 method (ISO 11137) EU Medical Device Regulations 3
R ISO 11137 Gamma sterilization validation, dose setting, dose audit Other Medical Device Related Standards 1
I Certification in Sterilization for ISO 11135 and ISO 11137 Professional Certifications and Degrees 3
S If this EN ISO 11137 certificate acceptable for Contract Sterilization? ISO 13485:2016 - Medical Device Quality Management Systems 2
J Does anyone have a summary of changes made to ISO 11137-2? Other Medical Device Related Standards 3
F ISO 11137 - Flow Chart | Decision Tree sterilization Other Medical Device Related Standards 4
K Very small batch validation ISO 11137 (VDmax25) ISO 13485:2016 - Medical Device Quality Management Systems 6
S Controlled Environment for Manufacturing Sterile Product - ISO 11137 Other Medical Device Related Standards 2
C Auditing Checklist for ISO 11135 and ISO 11137 (regulations for sterilization) Other Medical Device Related Standards 9
M Radiation (Gamma or E-beam) Dose Audit SOP - Quarterly dose audits based on ISO 11137 Other Medical Device Related Standards 8
E ISO 11137 gamma sterilized device dose audit - Lead time? Other ISO and International Standards and European Regulations 7
M Gamma Sterility Validation - ISO 11137-2, 4.2 vs. FDA Requirements ISO 13485:2016 - Medical Device Quality Management Systems 6
C ISO 11137:1995 Sterilisation of healthcare products - Amd1:2001 ISO 13485:2016 - Medical Device Quality Management Systems 11
B ISO 9001:2015 Registered Companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C ISO Cert and Parent Company is not Certified ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
B Is 14971 Annex C checklist now in ISO/TR 24971 required to complete prior to 510k filing? ISO 14971 - Medical Device Risk Management 1
Q ISO Training Providers to fix careless workers? Training - Internal, External, Online and Distance Learning 19
M PROBLEM IN SCOPE OF ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
S ISO 13485 signing of Procedures etc. ISO 13485:2016 - Medical Device Quality Management Systems 4
N ISO 13485 Scope Reduction Other ISO and International Standards and European Regulations 2
Sidney Vianna ISO 37301 - Compliance management systems – Requirements with guidance for use Other ISO and International Standards and European Regulations 0
S ISO 3497 Metallic Coatings Other ISO and International Standards and European Regulations 1
R Basic Lab Practices - related to ISO 17025 testing labs ISO 17025 related Discussions 1
JDJohnson Micrometer & Caliper Calibration (ISO-9001) General Measurement Device and Calibration Topics 26
M Can veterinary implants be ISO 13485 certified? ISO 13485:2016 - Medical Device Quality Management Systems 23
D Audit Report details when ISO 13485:2016 and cGMP 21 CFR 820 are applicable ISO 13485:2016 - Medical Device Quality Management Systems 6
G Why do you guys think ISO 9001 doesn't ask specifically for preventive maintenance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
D Training for ISO 17025 ISO 17025 related Discussions 2
R Looking for ISO 13485 Internal Audit Checklist ISO 13485:2016 - Medical Device Quality Management Systems 7
FuzzyD ISO 13485 change in process ISO 13485:2016 - Medical Device Quality Management Systems 3
D ISO 9001:2015 Calibration Procedures Manufacturing and Related Processes 16
R Interesting Discussion Chapter 7.5 of ISO 13485 for manufacturers of mobile medical applications ISO 13485:2016 - Medical Device Quality Management Systems 4
J ISO Certificate Expiration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
V ADDING NEW MEDICAL DEVICE / Product, WHEATHER THIS AFFECTS EXISTING ISO 13485 CERTIFICATION? ISO 13485:2016 - Medical Device Quality Management Systems 4
G Auditing Top management: 6.3 ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Question regarding AQL - ISO 3951 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
Sidney Vianna Informational ISO/NP TS 17012 - Guidelines for use of remote methods in conducting audits of management systems Other ISO and International Standards and European Regulations 0
G IT being audited during ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Is the ISO/SAE 21434 a certifiable standard? IATF 16949 - Automotive Quality Systems Standard 3
K Subcontractors Providing Services Under MDD or MDR need ISO 13485 from EU Notified Body? CE Marking (Conformité Européene) / CB Scheme 5
2 What is ISO? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Moncia Customer satisfaction monitoring - ISO 9001 and 14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
M Document Control ISO and FDA ISO 13485:2016 - Medical Device Quality Management Systems 7
E Theoretical project: Implementing ISO 13485:2016 into a start up acrylic bone cement manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 4
Sidney Vianna ISO 9001 News ISO 9001 Design Specification to be developed - May 2022 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Regulatory compliance ISO 14001 ISO 14001:2015 Specific Discussions 5
M ISO 13485: 2016 Lot numbering question ISO 13485:2016 - Medical Device Quality Management Systems 4
