ISO 11197, Venting of Medical Supply Units - cl. 201.11.2.2.101
Benjamin Weber
Dear community,
I am struggling with the requirements and testing of clause 201.11.2.2.101 of ISO 11197:2019 regarding venting of compartments containing pipelines or terminal units for oxygen.
The requirement states that the "specific compartment shall be vented to atmosphere".
Then there is an example test method decribes: A simulated oxygen leakage (1 l/min through a 3 mm inner diameter hose) "at the entry point to the medical supply unit under test". This is quite straightforward.
My question is: Where should I measure the oxygen concentration? The standard says:
  • "the specific compartment shall be vented" and
  • "Compliance is checked by a simulated leakage test as defined in the example test method to show that the oxygen concentration within the medical supply unit is not greater than a volume fraction of 25%".
Thus I would place the sensor in the compartment where the pipelines / terminal units are located.
But from an engineering point of view and the corresponding requirements of IEC 60601-1, cl. 11.2.2 this is not really necessary, as long as there is no possible source of ignition. If the piping compartment and the electrical compartment are separated mechanically, I would rather be interested in the oxygen concentration inside the electrical compartment (sparks etc.) or even only close to socket outlets, switches etc.
Does somebody else have some toughts on this?
Tidge
I have no specific experience with this standard or this type of device, but it is possible that electro-static discharge could be a concern in addition to implemented ignition sources.
Benjamin Weber
Thank you very much! So far I didn't think about ESD. But your're right , this could lead to a fire, if the compartment is enriched with oxygen.
I Does BSI require suppliers to be ISO 9001 Certified? EU Medical Device Regulations 8
Ron Rompen ISO 9001 Sanctioned Interpretations and FAQs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Ashland78 Need IATF 16949 ISO Gap Analysis Excel File Internal Auditing 3
Brizilla ISO 13485 for a Distributor ISO 13485:2016 - Medical Device Quality Management Systems 7
E Organisational Chart-ISO 17025 Laboratory ISO 17025 related Discussions 3
S Do ISO certs require an Apostille? ISO 13485:2016 - Medical Device Quality Management Systems 13
Q Harmonised Standards (EN ISO 13485 / EN ISO 14971) in MDR (2017/745/EU) ISO 13485:2016 - Medical Device Quality Management Systems 3
Sidney Vianna Informational ISO/CD 7101 Health Care Quality Management System Standard Hospitals, Clinics & other Health Care Providers 0
Fjalar ISO 20417:2021: Technical Data (6.6.4 c) Other Medical Device Related Standards 0
D Automotive Customer asking for ISO 14001 Certification from suppliers ISO 14001:2015 Specific Discussions 3
K Need Help With Auditing Suppliers Against ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 49
L PFMEA for test procedures (ISO 14971) ISO 14971 - Medical Device Risk Management 5
J ISO 13485- 8.3.1 Non-conforming material high volume ISO 13485:2016 - Medical Device Quality Management Systems 4
Q ISO 20417:2021- Regulatory Identification Other ISO and International Standards and European Regulations 2
L ISO/IEC 20000-6 Technical Areas IT (Information Technology) Service Management 0
R What are the new changes in EN ISO 11137-1:2015+A2:2019? Other Medical Device Related Standards 2
Y ISO 10993-14:2001 - Gel implants stored in glass syringes Other Medical Device Related Standards 1
eldercare Multi-Site ISO/AS Certification Requirement for some sites ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
Sidney Vianna ISO 14001 News ISO 14001 Continual Improvement Survey ISO 14001:2015 Specific Discussions 0
Casana ISO 17025 - Contractor certification? IATF 16949 - Automotive Quality Systems Standard 5
B Sanctioned interpretation #10 - ISO 17025 IATF 16949 - Automotive Quality Systems Standard 2
H Contract Manufacturer as Design Owner ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
G Compliance with ISO 9001-2015 for ISO 17025 Accredited Labs? ISO 17025 related Discussions 5
blackholequasar ISO 13485 certification prior to Medical Device Manufacturing... worth it? ISO 13485:2016 - Medical Device Quality Management Systems 4
C ISO 14001 Internal Audit - Opportunity for Improvement ISO 14001:2015 Specific Discussions 2
P ISO 11607-2 Process Specification Other Medical Device Related Standards 1
S Which ISO Standards to Purchase - EN ISO and/or ISO Other Medical Device Related Standards 1
A ISO Clause 4.1/4.2 & 6.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
S Electronic Signatures - Non-Conformance - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 30
E ISO 13485 software validation ISO 13485:2016 - Medical Device Quality Management Systems 7
D Management reviews ISO 17025 ISO 17025 related Discussions 3
L Change Log in (controlled) Forms? (ISO 9001:2015) Document Control Systems, Procedures, Forms and Templates 6
K ISO 9001 Clause 8.3 & 8.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
I ISO 17025:2017 / ANAB 3125 - Articulating / Communicating Risks vis-a-vis Audit Findings ISO 17025 related Discussions 2
A Management of change procedure for ISO 45001 Occupational Health & Safety Management Standards 5
S Transition training for Internal Auditor from ISO 9001: 2008 to the ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Notified Bodies - ISO 13485 & MDR Technical Files ISO 13485:2016 - Medical Device Quality Management Systems 3
E Comparison of Personal Protective Equipment Standards EN 14605 vs GB24539 and ISO 13982 vs GB 24539 Occupational Health & Safety Management Standards 0
H R&D Lab ISO 9001 certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
C Biologic Evaluation based on ISO 10993-1 EU Medical Device Regulations 2
D Deviations - Where in ISO 13485 deviations are covered? ISO 13485:2016 - Medical Device Quality Management Systems 7
B ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 2
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Y ISO 13485:2015 Software Validation IQ/OQ/PQ ISO 13485:2016 - Medical Device Quality Management Systems 13
Ajit Basrur Any ISO standard or guidance documents on barcode and scanning? Other Medical Device Related Standards 1
J ISO 13485 for Metal Finishing Medical Device and FDA Regulations and Standards News 5
S How to calculate Effective Number of People for ISO 13485 Certification? General Auditing Discussions 2
C ISO Question - Do you say "I-S-O" or "I-Soh"? Misc. Quality Assurance and Business Systems Related Topics 14
D Question regarding where "validations" fit according to ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 1
H Asset Inventory - documents and people (ISO 27001) IEC 27001 - Information Security Management Systems (ISMS) 1
