ISO 11607-2 "Critical Parameter" vs. "Process Parameter"
I'm new to Quality Engineering as a field in general, but I've been asked to look into a GAP assessment for the ISO 11607-2 document. I went through the document and noted the changes from the prior versions to see what has changed, and for the most part it seems the same except that there seems to be a significant difference between the change from critical parameters to process parameters. My understanding is that critical parameters are those that are defined as critical to the final important aspects of the part (i.e. its functionality, etc.) whereas process parameters seems to be more like parameters that affect any of the final aspects of a part even if they aren't critical per se. Am I understanding that correctly?
I would really appreciate an in depth discussion about this because I don't think I really understand since it seems like this change could be rather burdensome/significant compared to what it was before. Additionally, as I am new to Quality in general, any tips/tricks that you use to find out this type of information quickly would be much appreciated so that I can be more efficient in the future.
indubioush
In the forward, it states the following:
the terminology of “critical” process parameters has been discontinued and the concept of a process specification has been introduced to include all elements required to manufacture a product that consistently meets specifications.
You previously were only required to define, control, monitor, the "critical" process parameters. Now there is no such "critical" distinction; there are only process variables and process parameters.
process variable
chemical or physical attribute within a cleaning, disinfection, packaging or sterilization process, changes in which can alter its effectiveness
process parameter
specified value for a process variable
@indubioush, so it means every process variable then assuming that said process variable alters the effectiveness of the cleaning, disinfection, packaging or sterilization process? So if it doesn't affect those things (let's say speed of a device is a particular process variable) then it doesn't require control/monitoring then yes?
Aymaneh ISO 11607-1: 2019 main changes Other Medical Device Related Standards 2
B ISO 11607-1 for surgical instruments sterilized by end user Other Medical Device Related Standards 1
P European versions of standards - ISO 10993-1 and ISO 11607-1 EU Medical Device Regulations 6
M Accelerated Ageing Test for Orthopedic Implants -- ASTM F 1980 or ISO 11607 or both are applicable ? Other Medical Device and Orthopedic Related Topics 2
K Differences between EN ISO 11607-1:2009 vs. 2017 Other Medical Device Related Standards 1
C ISO 11607-1 Packaging System - Temperature and shipping conditioning Other Medical Device Related Standards 4
I Work Instruction for Validation of Packaging to EN ISO 11607-2 Requirements Document Control Systems, Procedures, Forms and Templates 3
B ISO 11607-1:2009 vs. 2006 - What Changed? Other Medical Device Related Standards 2
M Tyvek Blister Pack Testing Requirements - ISO 11607 Other ISO and International Standards and European Regulations 7
M Checklist for ISO 11607-2:2006 - Medical Device Packaging - Information needed Other Medical Device Related Standards 9
A ASL requirement when the supplier is certified for ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
D ISO 9001 certificate issued by QMS International for 10 years - legit? Registrars and Notified Bodies 8
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 2
K Medical Device Repairs and ISO Scope ISO 13485:2016 - Medical Device Quality Management Systems 3
K Software Updates in the Field and ISO scope ISO 13485:2016 - Medical Device Quality Management Systems 0
M ISO 13485-2016 online certification ISO 13485:2016 - Medical Device Quality Management Systems 1
Z Auditor Findings ISO 14001:2015 vs. 45001:2015 ISO 14001:2015 Specific Discussions 5
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
S Supplier Management ISO 13485: 2016- Which supplier needs to fill in a self assessment form? ISO 13485:2016 - Medical Device Quality Management Systems 6
C ISO/IEC 17021-1 clause 7.1.2 - Determination of competence criteria Document Control Systems, Procedures, Forms and Templates 2
G ISO 17023 2017-11 - Suggestions for good books ISO 17025 related Discussions 0
B Timeframe for updating QMS / transitioning from ISO 14971:2012 to ISO 14971:2019 ISO 14971 - Medical Device Risk Management 5
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Possible to get ISO 13485 certified with only OEM Product? ISO 13485:2016 - Medical Device Quality Management Systems 4
D ISO 14971:2019 vs MDR Annex 1, Requirement #4 - "Manufacturers shall inform users of any residual risks" ISO 14971 - Medical Device Risk Management 2
D Definition of equipment for ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 1
L Biological Assessment (ISO 10993-1) Other Medical Device Related Standards 1
M ISO 13485:2016 Complaint Definition Clarity Customer Complaints 2
J ISO 9001:2015, ISO 14001 & OHSAS18000 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
G ISO 14001 - 6.1.3 Compliance Obligations ISO 14001:2015 Specific Discussions 1
D Rules for Paper Forms outside of an eQMS - 3 Questions (ISO 13485) Document Control Systems, Procedures, Forms and Templates 9
S Qualification question - ISO 13485 Reliability Analysis - Predictions, Testing and Standards 0
K ISO 13485 clause 8.5.2 'Any necessary CA shall be taken without undue delay' ISO 13485:2016 - Medical Device Quality Management Systems 11
G National Structural Steel Specification 7th Edition - Do I now have to be audited against ISO 3843-3 as well as ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J How much to charge for helping a startup company with initial ISO 13485 certification? Consultants and Consulting 3
J ISO 13485 System 'soft start' - How to best reflect this in initial audits, management review minutes and other records? ISO 13485:2016 - Medical Device Quality Management Systems 3
L How to understand the clause 6 Planning of ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 4
B ISO 8536-4 Contamination Index ISO 13485:2016 - Medical Device Quality Management Systems 0
S Practical Implementation of ISO 14971 ISO 14971 - Medical Device Risk Management 6
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
L Process changes and biocompatibility (ISO 10993-1) Other Medical Device Related Standards 1
J Recommendations for online ISO 19011 training? Training - Internal, External, Online and Distance Learning 6
D ISO 13485 8.2.1 and 8.2.2 - Customer Feedback and Customer Complaints ISO 13485:2016 - Medical Device Quality Management Systems 5
S Requirements to obtain ISO 50001 Certification ISO 14001:2015 Specific Discussions 2
