ISO 13485:2016 “Lifetime” of a product
Reliable Source
Can someone tell me if the ISO 13485:2016 requirement for an organization to define the “lifetime” of their medical products (reference 4.2.4 and 4.2.5) extends to the products they purchase for suppliers? Specifically speaking, the company I work for purchases medical devices manufactured by our suppliers, who own the design rights, and they re-label/ package under our name. So I am trying to find out if the “lifetime” definition should be defined by the manufacturer, or in this case should we define it?
Davidngqk88
If your suppliers are iso13485, they need to define it.
But if you're the legal manufacturer, and you are iso13485 quality certified, then you need to define it.
EmiliaBedelia
IMO, if you are the one defining the intended use of the device (ie, if you are the one marketing the device and putting your name on it), you do need to identify and document the use life yourself. You need to consider the intended purpose of the device and what "real world" use would look like. However, the use life is going to be dependent on the design, so you probably don't actually have much control over what it is. Basically, the extent that you "define" the use life, and what you do with it, is commensurate with the activities that you perform.
Presumably you had some level of use evaluation before purchasing the product, based on your intended purpose. For example, if your device is a reusable metal surgical tray, and your supplier says that the use life is 1 week, that would not be acceptable, right? So, even if you are not making design decisions to meet that use life, you are still "defining" a level of acceptable performance. The things that you are doing to meet that requirement are just different (ie, you are selecting a supplier/device that will meet your use life - you are not choosing the material).
Another example, if your device is a surgical drill/handpiece - if your supplier defines the device use as 1/x week for 2 minutes each time, but your use case is 5x/week for 1 hour each time, the difference in the intended use will likely result in a different use life. So, even if the supplier does "define" a use life, you need to make sure that their assumptions/inputs are the same as your marketed use.
The lifetime needs to be defined and properly reflected throughout the rest of the product documentation as well. For example, if your device has a lifetime of 5 years, have you performed reliability testing that demonstrates that use life? Does your risk analysis properly analyze the risks of using a device that is too old? Do you communicate to the user in the IFU when the device is no longer functional? Does your Post-Market Surveillance system take this into account? (eg, if you get a complaint for a device that is 7 years old, do you consider the device age in the analysis?) If you do servicing or repair, how does that factor in? (eg, does the "use life" start over after the device is repaired?)
IMO this doesn't necessarily need to be a huge endeavor - you just need to show that you've considered the use life to the extent that it impacts the activities you're performing.
Reliable Source
Hi Emilia,
thank you for such a comprehensive response. I agree with everything you said. But I just wanted to confirm that the responsibility for defining the “lifetime” of a product is in fact the manufacturer/ designer and not the customer. Even when the product is re-labeled with the customer’s name.
R ISO 13485:2016 DESIGN TRANSFER Forum News and General Information 0
M Feedback process ISO 13485:2016 clause 8.2.1 ISO 13485:2016 - Medical Device Quality Management Systems 2
M Integrating ISO 9001:2015 audits with ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
A Risk Assessment for ISO 13485:2016 section 7?? ISO 13485:2016 - Medical Device Quality Management Systems 11
L Annex of ISO 13485:2016 as harmonized standard (MDR/IVDR) ISO 13485:2016 - Medical Device Quality Management Systems 2
LostLouie DHF linked to ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 7
M ISO 13485:2016 Identification & Traceability ISO 13485:2016 - Medical Device Quality Management Systems 4
K Clause 7.5.2 of ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
FuzzyD ISO 13485:2016 Customer Assessment OFI ISO 13485:2016 - Medical Device Quality Management Systems 2
S Brexit ISO 13485:2016 + Corrigendum - What does a UKCA DoC require? EU Medical Device Regulations 2
D Audit Report details when ISO 13485:2016 and cGMP 21 CFR 820 are applicable ISO 13485:2016 - Medical Device Quality Management Systems 6
E Theoretical project: Implementing ISO 13485:2016 into a start up acrylic bone cement manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 4
M ISO 13485: 2016 Lot numbering question ISO 13485:2016 - Medical Device Quality Management Systems 4
Q Documented Evidence of Training ISO 13485: 2016 ISO 13485:2016 - Medical Device Quality Management Systems 46
D Customer Survey Example - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 7
M Requirements ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 12
I EN ISO 13485:2016/A11:2021 ISO 13485:2016 - Medical Device Quality Management Systems 2
A ISO 13485:2016 Clause 8.2.1 ISO 13485:2016 - Medical Device Quality Management Systems 3
FuzzyD ISO 13485:2016 Clause 8.2.6 ISO 13485:2016 - Medical Device Quality Management Systems 4
K Can I make an exclusion of Design and Development in ISO 13485:2016 if my product is not regulated ISO 13485:2016 - Medical Device Quality Management Systems 12
B ISO 9001:2015 vs ISO 13485:2016 Gap analysis ISO 13485:2016 - Medical Device Quality Management Systems 9
K 3rd party auditor for ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 4
S Electronic Signatures - Non-Conformance - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 38
D Question regarding where "validations" fit according to ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 1
D Question on using audit checklist ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 20
M Customer Property - ISO 13485:2016 Clause 7.5.10 ISO 13485:2016 - Medical Device Quality Management Systems 9
H QMS ISO 13485:2016 - ISO14971 IEC60304 etc ISO 13485:2016 - Medical Device Quality Management Systems 6
B Operational Procedures for ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 7
Ed Panek ISO 13485:2016 Section 5.5.3 ISO 13485:2016 - Medical Device Quality Management Systems 3
S Inventory Listing and ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 3
M ISO 13485:2016 Certification Scope ISO 13485:2016 - Medical Device Quality Management Systems 4
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 8
M How Specific in an ISO 13485:2016 Scope for a Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 9
0 ISO 13485:2016 Chapter 8 Integration of the subsections ISO 13485:2016 - Medical Device Quality Management Systems 3
T ISO 13485:2016 Clauses related to process matrix ISO 13485:2016 - Medical Device Quality Management Systems 3
J Can signed agreements over-ride review of every "contract" under ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 2
Q EN ISO 13485:2016/AC:2018 - AC:2018 being stated in the applicable harmonized standard listing Other ISO and International Standards and European Regulations 1
J Leveraging another company's ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
M ISO 13485-2016 online certification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Supplier Management ISO 13485: 2016- Which supplier needs to fill in a self assessment form? ISO 13485:2016 - Medical Device Quality Management Systems 6
D Definition of equipment for ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 1
Mark273 ISO 13485:2016 Complaint Definition Clarity Customer Complaints 2
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
P ISO 13485:2016 MDSAP Certification Fee Survey ISO 13485:2016 - Medical Device Quality Management Systems 6
K Contamination Control - Class Is medical devices (Clause 6.4.2 ISO 13485:2016 (E)) ISO 13485:2016 - Medical Device Quality Management Systems 12
H ISO 13485:2016 Gap Analysis by NB ISO 13485:2016 - Medical Device Quality Management Systems 7
S SOP for ISO 13485:2016 Quality related Software validation ISO 13485:2016 - Medical Device Quality Management Systems 16
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
K ISO 13485:2016, Clause 4.2.3 Medical Device File ISO 13485:2016 - Medical Device Quality Management Systems 4
