ISO 13485 - 7.5.2 cleanliness , 6.4.2 validation of special processes, and 6.4.2 contamination ability to be exempt?
Jkc3usc12
Exempt from these 3 ISO 13485 clauses?
7.5.2 - My company is a distributer of a non-sterile product and have no required cleaning instructions besides a recommendation for the user.
6.4.2 - Returned product is received but any product that has been returned from the hospital is decontaminated there. The product distributed becoming contaminated has not happened.
7.5.6 - we do not design or manufacture any product.
Rincewind
7.5.2:
I do not believe you can exclude clause 7.5.2 from your QMS, it is stated:
"The organization shall document requirements for cleanliness of product or contamination control of
product if:
b) product is supplied non-sterile and is to be subjected to a cleaning process prior to sterilization or
its use; [...]", this reads to me like it fits your product pretty well from what you told us.
6.4.2
I just had a pretty similar discussion with an auditor the other day, the question is, how do you make sure the device is properly disinfected/sterilized when it gets back to you? Do you have a form the hospital has to fill out and send you back with the product? The clause clearly states "potentially contaminated product" as well so depending on your auditor or a risk analysis performed by your people you might need a procedure for this as well.
7.5.6
This does not only apply to manufacturing processes but to service provision as well, so if you can not claim that all your processes are verifiable you might need to validate some, some companies get around this by performing final tests on every product they manufacture, as you do not manufacture anything I do not know if this can be used by you.
Jkc3usc12
Agree with your points. Again being solely a distributor of the product I just have a hard time with some of the elements. We receive it in a box, check it, then rebox, and send. That is the main function of the facility.
6.4.2 could I possibly say we do not receive contaminated product. If we do it is scrapped or not accepted?
7.5.6 again we do not manufacture so all validation and testing of product is done at before we receive it.
Rincewind
If that is what happens then that would be your procedure. If the device is possibly contaminated it is scrapped. A simple procedure could maybe be: You only accept products which have some kind of certificate from the customer that it was decontaminated before it was send out to you (I have seen companies do that, for example companies selling surgical instruments), if this certificate is missing you scrap the product (or clean it yourself before further processing but that might be not possible for you if you are just a distributor.)
Again, this clause does not only apply to the manufacturing process but service provision as well. It depends on what your part in the cycle of this product is, I am thinking about 7.5.4 servicing activities for example (as you mentioned you receive products back). But if you have concluded non of your processes need to be validated you could exempt it.
Lokus200
6.4.2 - you can add receiving inspection requirements to verify that it was decontaminated.
7.5.6 - if your scope is distribution only, you should document the justification for it in your Quality Manual. You are not a manufacturer so you don't have to validate manufacturing processes, however, you may have to validate your distribution process.
Jkc3usc12
7.5.2:
product if:
6.4.2
7.5.6
both 7.5.2 and 6.4.2 we did declare in our QM but was written a NC for not declaring the non applicable. This is what was written -
The Scope of the Quality Management System is not fully effectively described because not all non-applicable clauses have been declared
clauses 7.5.2 cleanliness, 7.5.6, validation of special processes, and 6.4.2 Contamination control, have not been declared.
D ISO: 13485:2016 Sec. 7.5.2 (C) - Requirements for cleanliness of product or contamination control ISO 13485:2016 - Medical Device Quality Management Systems 2
J ISO 13485:2003 Section 7.5.1.2.1 Cleanliness of Product ISO 13485:2016 - Medical Device Quality Management Systems 1
C ISO 13485 Clause 7.5.1.2.1 Cleanliness of Product and Contamination Control Question ISO 13485:2016 - Medical Device Quality Management Systems 7
B ISO 13485 7.5.1.2.1 Cleanliness and Contamination of Product Requirements ISO 13485:2016 - Medical Device Quality Management Systems 5
S ISO 13485 certification training Training - Internal, External, Online and Distance Learning 1
Ed Panek ISO 13485 Reporting Requirements ISO 13485:2016 - Medical Device Quality Management Systems 4
B ISO 13485 Qualification of R&D Equipment Qualification and Validation (including 21 CFR Part 11) 1
J Recognised/reputable courses for ISO 13485 Section 7.3 (Design & Development)? Other ISO and International Standards and European Regulations 1
Q ISO 13485 certificate needed if I go for MDSAP certification? ISO 13485:2016 - Medical Device Quality Management Systems 3
K ISO 13485 Design Requirement with respect to "component" manufacturers ISO 13485:2016 - Medical Device Quality Management Systems 11
P Registrar Cancelled ISO 13485 Auditors multiple times? Registrars and Notified Bodies 1
rob3027 ISO 13485 justification for design and development exclusion for medical packaging ISO 13485:2016 - Medical Device Quality Management Systems 18
A Help understanding what it takes to implement a QMS that is ISO 13485 compliant ISO 13485:2016 - Medical Device Quality Management Systems 4
FuzzyD ISO 13485:2016 Customer Assessment OFI ISO 13485:2016 - Medical Device Quality Management Systems 2
M ISO 13485 consultants and auditors with design oriented focus ISO 13485:2016 - Medical Device Quality Management Systems 7
S Brexit ISO 13485:2016 + Corrigendum - What does a UKCA DoC require? EU Medical Device Regulations 2
Aliken Recommendation for the ISO 13485 certification company ISO 13485:2016 - Medical Device Quality Management Systems 7
ISO-tired ISO 13485: file structure overview ISO 13485:2016 - Medical Device Quality Management Systems 11
M PROBLEM IN SCOPE OF ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
S ISO 13485 signing of Procedures etc. ISO 13485:2016 - Medical Device Quality Management Systems 10
N ISO 13485 Scope Reduction Other ISO and International Standards and European Regulations 2
M Can veterinary implants be ISO 13485 certified? ISO 13485:2016 - Medical Device Quality Management Systems 23
D Audit Report details when ISO 13485:2016 and cGMP 21 CFR 820 are applicable ISO 13485:2016 - Medical Device Quality Management Systems 6
R Looking for ISO 13485 Internal Audit Checklist ISO 13485:2016 - Medical Device Quality Management Systems 8
FuzzyD ISO 13485 change in process ISO 13485:2016 - Medical Device Quality Management Systems 3
R Interesting Discussion Chapter 7.5 of ISO 13485 for manufacturers of mobile medical applications ISO 13485:2016 - Medical Device Quality Management Systems 4
V ADDING NEW MEDICAL DEVICE / Product, WHEATHER THIS AFFECTS EXISTING ISO 13485 CERTIFICATION? ISO 13485:2016 - Medical Device Quality Management Systems 4
K Subcontractors Providing Services Under MDD or MDR need ISO 13485 from EU Notified Body? CE Marking (Conformité Européene) / CB Scheme 8
E Theoretical project: Implementing ISO 13485:2016 into a start up acrylic bone cement manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 4
M ISO 13485: 2016 Lot numbering question ISO 13485:2016 - Medical Device Quality Management Systems 4
Q Documented Evidence of Training ISO 13485: 2016 ISO 13485:2016 - Medical Device Quality Management Systems 46
D Customer Survey Example - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 7
D Normative References for ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 5
A Scope of ISO 13485 certification as legal manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 4
R ISO 13485 certification scope ISO 13485:2016 - Medical Device Quality Management Systems 5
M Requirements ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 12
M ISO 13485 Clause 7.3.8 ---- on Business Transfer ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 13485--Question regarding performing calibrations in house. ISO 13485:2016 - Medical Device Quality Management Systems 13
I EN ISO 13485:2016/A11:2021 ISO 13485:2016 - Medical Device Quality Management Systems 2
A ISO 13485:2016 Clause 8.2.1 ISO 13485:2016 - Medical Device Quality Management Systems 3
FuzzyD ISO 13485:2016 Clause 8.2.6 ISO 13485:2016 - Medical Device Quality Management Systems 4
A ISO 13485 Calibration Requirements- Assess and Record validity Previous measuring results ISO 13485:2016 - Medical Device Quality Management Systems 5
K Can I make an exclusion of Design and Development in ISO 13485:2016 if my product is not regulated ISO 13485:2016 - Medical Device Quality Management Systems 12
S Is the Design Service Provider required to be ISO 13485 certified? ISO 13485:2016 - Medical Device Quality Management Systems 13
C ISO 13485 Clause 7.3.3 a) ISO 13485:2016 - Medical Device Quality Management Systems 2
S ISO 13485, Clause 4.1.2 b) ISO 13485:2016 - Medical Device Quality Management Systems 12
Ed Panek FDA Submits to White House Plan to Harmonize with ISO 13485 US Medical Device Regulations 2
B ISO 9001:2015 vs ISO 13485:2016 Gap analysis ISO 13485:2016 - Medical Device Quality Management Systems 9
K 3rd party auditor for ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 4
chris1price MDSAP and ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 5
