ISO 13485 and DHF (Design History File) requirements
K
KoD_RP
Hi All,
I am working on a software house certified under ISO 13485:2012.
We have developed a product under these regulations. A customer now asks for the DHF document, which is not required for 13485.
1. Do you know whether the IEC32604 requires a DHF document?
2. Is there a template available just to get an idea?
3. Is there a correlation between 13485 procedures and the "Design control".
Frankly, I am a bit confused.
4 How do I track different versions of the some document?
5. We have a web based reporting system where the customer can report bugs/changes etc. Based on the request, we update SDS documents, perform test reports etc. Do we have to record the web based entries as well in the DHF?
Any help will be highly appreciated!
Paul
mihzago
take a look at this recent post: http://elsmar.com/Forums/showthread.php?t=68109&goto=newpost
it should answer some of the questions.
I assume you mean IEC 62304. IEC62304 does not require DHF, but DHF is nothing more than a collection of all documents, deliverables and artifacts generated during the course of the design and development activity. DHF is not a single document, but many companies create a DHFI (Design History File Index), which references all documents that are part of the DHF.
There is almost a 1 to 1 correlation between the FDA Design Control and ISO 13485, especially the 2016 version which added things like:
7.3.9 Control of Design and development changes
7.3.10 Design and development Files (essentially your DHF).
Any changes you make to your product, and documentation generated to support the changes, also become part of the DHF.
yodon
Just to expand a bit more on what mihzago wrote, let me touch on your points 4 & 5.
Item 4 should be nothing more than your standard document control procedures. Can you provide any more information on why this is an issue?
For item 5, 62304 has some specific controls on issues reported from the field and how they are managed and closed out. There are also some requirements for communicating issues. And there are even more requirements for tying those issues into the risk management process as well as trending. Beyond that, QSR (FDA) requirements also expect you to capture web-based reports as feedback (and if they drive changes, they would be done under design [change] controls).
K
KoD_RP
Thanks a lot for the feedback Yodon,
I am mainly trying to understand the DHF logic. Is it a document where I have to just enumerate the project files or I have to track also the relationship between them e.g. web-based reported issue A led to the change of SDS file B (I am already doing the latter through traceability matrices, review protocols and reference documents).
Regarding your question: All our documents have a history section where we track changes/per version. Assuming that I have 4 versions of the same document, the first during design output phase, the second during validation and the last two after release. For each of these four versions, should the DHF document contain just the file name/location/version/release date or detailed descriptions of the changes as well? I also assume that the DHF document is sorted chronologically.
Thanks for the clarifications. We cover the majority of the specs however we have to slightly alter our QMS to fit the needs of 14971 in order to comply with 62304. Going back to DHF, this means that inside the document we will have to add the actual web link to the corresponding web-based reporting system?
Many thanks,
Paul
yodon
The DHF is, at least to me, more of a concept than a document. It's a collection of the entire design history with controls in place to allow you to see the current state of the design configuration (i.e., latest releases of all docs in the design). Your document control system maintains the previous versions for the required time so you are able to retrieve the latest plus the prior revisions.
In terms of having to "alter your QMS to fit the needs of 14971 in order to comply with 62304" - can you elaborate? Certainly 62304 requires some 'integration' with 14971 but I'm not sure how this would drive changes to your QMS.
Regarding the web links to the reporting system, I wouldn't say actual hyperlinks are required (but certainly not prohibited if it would be useful!). I presume there's some kind of numbering system and so you could just reference the numbers. Typically we compile the list of changes (by number with brief description) in a software release into a Version Description Document (VDD). This supports the configuration status accounting requirement. We also use the VDD to list known open issues.
K
KoD_RP
Thanks for the feedback!
It's clear now. I had in mind something similar, since all prior document versions are tracked, however the "History" term inside the DHF leads to misperceptions.
Our QMS is 13485:2012 certified. We have a Risk Management QP which describes the work flow. We follow a FMEA approach to identify risks and define corrective actions in order to minimize risks. However, we don't explicitly state the way we trace the corrective actions through out the project (risk control), even though at the end of the project we are able to verify that the corrective actions were performed. In addition, we don't evaluate the overall performance of our risk management system. According to 14971, and please correct me if I am wrong, the aforementioned procedures should be stated in the QMS.
Many thanks!
Paul
yodon
You may be mixing terms a bit which could be part of the confusion. ("Corrective actions" are most typically what would be done to address a nonconformity.) One of the outputs of risk management is risk controls or mitigations (what I think you're calling corrective actions). Indeed, you do need to demonstrate that the risk controls are implemented and effective (at the time they're needed). Per 13485, one of the design inputs is the output of risk management. Thus, you do need to demonstrate traceability from the risk control to verification.
Yes, you should have procedures that guide your risk management activities. Per 14971:2012, your risk file (the collection of risk management artifacts) contains, in addition to the analysis and evaluation, the (evidence of) implementation and verification of controls and the assessment of the acceptability of residual risk.
Hello, I realize this post is almost 2 years old, but the subject matter you've discussed is closely related to my question.
I understand the concept of DHF and it works fine for a company with a large set of controlled documents over a period of time.
I am consulting for a startup company in France that wants to be certified to ISO 13485:2016. They have over 2 years of uncontrolled documents, having never put a true quality system in place. They've been doing animal testing and have paper records for that. Should I be looking at scanning hand-written proof-of-concept ideas and photos of dry erase boards with drawings representing brainstorming? Should I be including e-mail conversations between early company members discussing their ideas for the product and its technology? All of that constitutes early design inputs and planning.
Thank you for your help.
Scott
yodon
Can't say that's the tack I would take. Sounds like what they've been doing up to now is "research" (outside the scope of design). Certainly they've gathered good data (presumably) to prove the concept but without good controls in place (tests under approved protocol, proper record capture, etc.), the reliability of that data would likely cause that data to be dismissed.
It sounds to me like they're ready to move into design and need to properly establish the Design & Development Plan, do the required Risk Management activities, capture the design inputs, etc. and start building the DHF / Medical Device file. I do tend to take a conservative approach - I want my clients as bullet-proof as possible with their submissions / compliance.
O Distributors and ISO 13485 - DHF and DMR Responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 7
Ed Panek ISO 13485:2016 Section 5.5.3 ISO 13485:2016 - Medical Device Quality Management Systems 3
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
D ISO 13485 scope (implantable) - Polymers for dental application EU Medical Device Regulations 9
A ISO 13485 procedure change and reflect to legacy manufacture items ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 13485 & CE Certification for Surgical Gloves CE Marking (Conformité Européene) / CB Scheme 0
S Inventory Listing and ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 3
M ISO 13485:2016 Certification Scope ISO 13485:2016 - Medical Device Quality Management Systems 2
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
M Scope for ISO 13485 Certification of a Translation Service Provider ISO 13485:2016 - Medical Device Quality Management Systems 17
Q ISO 13485 7.5.6 Validation - Off the shelf Software ISO 13485:2016 - Medical Device Quality Management Systems 3
A ISO 13485 Certification for Resin Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 4
A ISO 13485 Sterilization Clause Applicability ISO 13485:2016 - Medical Device Quality Management Systems 7
K ISO 13485 and compliance of electronic signature ISO 13485:2016 - Medical Device Quality Management Systems 5
T ISO 13485 - Assembly instructions written vs. online ISO 13485:2016 - Medical Device Quality Management Systems 5
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 5
N 93/42/EEC certification without ISO 13485 EU Medical Device Regulations 3
M How Specific in an ISO 13485:2016 Scope for a Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 9
A ISO 13485 for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 7
0 ISO 13485:2016 Chapter 8 Integration of the subsections ISO 13485:2016 - Medical Device Quality Management Systems 3
M Change in Constitution / Ownership of firm -------ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
E ISO 13485 QMS certification as a Supplier ISO 13485:2016 - Medical Device Quality Management Systems 8
T ISO 13485:2016 Clauses related to process matrix ISO 13485:2016 - Medical Device Quality Management Systems 3
J Can signed agreements over-ride review of every "contract" under ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 2
J Implementing an ISO 13485 QMS Software ISO 13485:2016 - Medical Device Quality Management Systems 6
Q EN ISO 13485:2016/AC:2018 - AC:2018 being stated in the applicable harmonized standard listing Other ISO and International Standards and European Regulations 1
J Leveraging another company's ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
J New Job Position - Achieving ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 5
A Scope of ISO 13485 certificate ISO 13485:2016 - Medical Device Quality Management Systems 1
A ASL requirement when the supplier is certified for ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
M ISO 13485-2016 online certification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
S Supplier Management ISO 13485: 2016- Which supplier needs to fill in a self assessment form? ISO 13485:2016 - Medical Device Quality Management Systems 6
J Possible to get ISO 13485 certified with only OEM Product? ISO 13485:2016 - Medical Device Quality Management Systems 4
D Definition of equipment for ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 1
M ISO 13485:2016 Complaint Definition Clarity Customer Complaints 2
D Rules for Paper Forms outside of an eQMS - 3 Questions (ISO 13485) Document Control Systems, Procedures, Forms and Templates 9
S Qualification question - ISO 13485 - Setting up a small lab Reliability Analysis - Predictions, Testing and Standards 2
K ISO 13485 clause 8.5.2 'Any necessary CA shall be taken without undue delay' ISO 13485:2016 - Medical Device Quality Management Systems 11
J How much to charge for helping a startup company with initial ISO 13485 certification? Consultants and Consulting 3
J ISO 13485 System 'soft start' - How to best reflect this in initial audits, management review minutes and other records? ISO 13485:2016 - Medical Device Quality Management Systems 3
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 5
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
D ISO 13485 8.2.1 and 8.2.2 - Customer Feedback and Customer Complaints ISO 13485:2016 - Medical Device Quality Management Systems 5
Sravan Manchikanti How to interpret '8.3 Control of nonconforming product' for SaMD device while implementing ISO 13485 & MDSAP ISO 13485:2016 - Medical Device Quality Management Systems 7
M Getting started in ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 31
P ISO 13485:2016 MDSAP Certification Fee Survey ISO 13485:2016 - Medical Device Quality Management Systems 6
C SOP Template needed for ISO 13485 6.3 Infrastructure ISO 13485:2016 - Medical Device Quality Management Systems 9
T ISO 13485 8.3 - Non-Conforming Materials - on-line rework or part of process? ISO 13485:2016 - Medical Device Quality Management Systems 11
