ISO 13485 Certification and then CE Mark?
rwend07
Hey everyone,
We are looking to get ISO 13485 certification with the eventual goal of getting CE mark on some of our devices. Is it generally a good idea to get the certification done with the eventual notified body of choice? Does it matter if you get your ISO cert done with a different company than your NB?
pkost
I don't believe it is required to use the same organisation for ISO and CE, however I would strongly recommend it as there will be a consistent approach, it avoids unnecessary disagreements or contradictions and reduces your audit burden
If you do go for a different ISO certificating authority, you should use one that is appropriately accredited.
Mark Meer
Yes, definitely try to find a certification body that can do both your ISO 13485 certification and act as EU Notified Body.
The reason being is that both ISO certification and CE certification require regular audits, with a fair amount of overlap. If you go through a single organisation, you can avoid the extra (much redundant) audits, and all the expenses, resources, and headaches extra audits entail.
MM.
rwend07
MM.
So in general its a good idea to keep them the same so you don't get the redundancy of having a MDR related audit as well as an ISO 13485 audit. Makes sense, thanks.
paulag
Please consider that Notified Bodies are pretty stressed out with all the new EU MDR requirements...
Make sure find one pretty early in your process... one with the right accreditation for your device category, with enough ressources for a new ISO 13485 + CE marking
Mark Meer
Good advice to heed. Unfortunately there may be nothing you can do, except to factor in an extended schedule to CE marking, or else swallow the cost of having separate ISO certification body and Notified Body.
After being on a waiting list for months with our ISO CB for NB services, we finally gave up and transferred to another organization. After nearly a year, the ball is finally rolling for CE marking...
Bottom line: plan appropriately for time (and $$).
Best of luck!
MM.
rwend07
Best of luck!
MM.
Man, that is rough. We have already had several companies come back and straight up tell us that they are filled up "until at least the New Year". It would be interesting to hear how many technologies are being held up and the potential human impact of the NB "fiasco".
Ronen E
Problem Solver
Moderator
Better save the word fiasco to what's ahead with the advent of the MDR, 1.5-2 years down the track. I believe that what we see now is just the warm up.
Parul Chansoria
Founder, Elexes Medical Consulting
ISO 13485 certification is meant for company wide processes and CE Mark is for the product.
For CE Mark, it is critical to select a Notified Body (NB) that has product domain expertise, so that they understand your product and do not create any unreasonable roadblocks. Hence, my recommendation would be to first select an NB for CE and then check if they can also serve as the NB for ISO 13485. Selecting same notified body would help as you will work with consistent expectations.
C Question on Finding - BSI Stage 2 ISO 13485:2016 Certification - PMS ISO 13485:2016 - Medical Device Quality Management Systems 5
A ISO 13485 CERTIFICATION WITH REGULATORY ISO 13485:2016 - Medical Device Quality Management Systems 2
R ISO 13485 Certification for an Internal Warehouse? ISO 13485:2016 - Medical Device Quality Management Systems 1
J Is ISO 13485 certification necessary for Class I (non-sterile) medical devices? ISO 13485:2016 - Medical Device Quality Management Systems 7
G ISO 13485 and CE certification strategy ISO 13485:2016 - Medical Device Quality Management Systems 7
kys123 Implications of failing an Anvisa Audit for ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 4
A Applying for ISO 13485 certification ISO 13485:2016 - Medical Device Quality Management Systems 8
S ISO 13485 certification training Training - Internal, External, Online and Distance Learning 1
Q ISO 13485 certificate needed if I go for MDSAP certification? ISO 13485:2016 - Medical Device Quality Management Systems 3
Aliken Recommendation for the ISO 13485 certification company ISO 13485:2016 - Medical Device Quality Management Systems 7
V ADDING NEW MEDICAL DEVICE / Product, WHEATHER THIS AFFECTS EXISTING ISO 13485 CERTIFICATION? ISO 13485:2016 - Medical Device Quality Management Systems 4
A Scope of ISO 13485 certification as legal manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 4
R ISO 13485 certification scope ISO 13485:2016 - Medical Device Quality Management Systems 5
blackholequasar ISO 13485 certification prior to Medical Device Manufacturing... worth it? ISO 13485:2016 - Medical Device Quality Management Systems 4
B ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 2
S How to calculate Effective Number of People for ISO 13485 Certification? General Auditing Discussions 2
G ISO 13485 Certification - Can we get the ISO 13485 certification prior to shipment of the device? ISO 13485:2016 - Medical Device Quality Management Systems 6
N Does anyone use SGS for ISO 13485 / CE certification Registrars and Notified Bodies 0
D ISO 13485 & CE Certification for Surgical Gloves CE Marking (Conformité Européene) / CB Scheme 0
M ISO 13485:2016 Certification Scope ISO 13485:2016 - Medical Device Quality Management Systems 4
M Scope for ISO 13485 Certification of a Translation Service Provider ISO 13485:2016 - Medical Device Quality Management Systems 19
A ISO 13485 Certification for Resin Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 4
N 93/42/EEC certification without ISO 13485 EU Medical Device Regulations 3
E ISO 13485 QMS certification as a Supplier ISO 13485:2016 - Medical Device Quality Management Systems 8
J New Job Position - Achieving ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 5
M ISO 13485-2016 online certification ISO 13485:2016 - Medical Device Quality Management Systems 3
J How much to charge for helping a startup company with initial ISO 13485 certification? Consultants and Consulting 3
P ISO 13485:2016 MDSAP Certification Fee Survey ISO 13485:2016 - Medical Device Quality Management Systems 6
K Restricted Scope of ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 7
R Scope of ISO 13485 certification ISO 13485:2016 - Medical Device Quality Management Systems 6
T Legalizing ISO 13485 certification with an US state department of health ISO 13485:2016 - Medical Device Quality Management Systems 5
M Informational BSI – ISO 13485 and products with May 2020 deadline for MDR certification Medical Device and FDA Regulations and Standards News 0
S ISO 13485 scope of certification - We are a virtual manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 1
M Start-Up Company looking for ISO 13485 Certification Body and Medical Device CE Mark Notified Body Registrars and Notified Bodies 6
H Can an OEM use an CM ISO 13485 certification in helping to get out CE Mark? ISO 13485:2016 - Medical Device Quality Management Systems 2
J Online ISO 13485 Auditor Certification ISO 13485:2016 - Medical Device Quality Management Systems 7
B ISO 13485 certification advantages when I certify a Class 2a medical device CE Marking (Conformité Européene) / CB Scheme 12
S Portugal ISO 13485 Certification and EMC Test Houses Other Medical Device and Orthopedic Related Topics 3
Dobby1979 Gaining ISO 13485 Certification - New Startup Company ISO 13485:2016 - Medical Device Quality Management Systems 5
S Covering an acquired company in our ISO 13485 certification Registrars and Notified Bodies 1
I Should I get IRCA ISO 13485 certification or RAPS certification? Career and Occupation Discussions 3
A ISO 13485:2016 Certification for Design and Development ISO 13485:2016 - Medical Device Quality Management Systems 0
R Scope of Certification for a Design Organization with Outsourced Mfg. - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 10
K ISO 13485:2016 Self Certification for Class I (annex 9) Stand-Alone Software? ISO 13485:2016 - Medical Device Quality Management Systems 3
M OEM-OBL ISO 13485 Certification - Devices mentioned in the product scope ISO 13485:2016 - Medical Device Quality Management Systems 6
A Combined ISO 13485 Certification with ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 27
B Reapplying for ISO 13485 certification after certificate revocation ISO 13485:2016 - Medical Device Quality Management Systems 3
N We Passed Our ISO 13485:2003 Certification! Coffee Break and Water Cooler Discussions 7
K Adding a New Site to Our ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 9
S Certification services for ISO 13485, CMDCAS 13485, and CE Markings Canada Medical Device Regulations 18
