ISO 13485 certified == cGMP compliance?
AmandaMusser
We are classified as a "component manufacturer" through the FDA and are ISO 9001 & 13485 certified. The FDA scheduled an audit of our facility, within the first hour the inspector realized that we are indeed a component manufacturer and decided that the audit did not need to be completed. However, the auditor suggested that we become cGMP compliant...
So I've been researching... I came across a statement "if you are 13485 certified, you are cGMP compliant". Can anyone tell me if that is a true statement and recommend some type of training program or facility that we could look into?
Thank you in advance,
Amanda
Doug Tropf
Amanda
While the requirements of 13485 and cGMP have been harmonized to a great extent, there are still some differences, mainly regarding the cGMPs being more detailed and prescriptive. I would suggest you search the Post Attachments List or other sources to find a good comparison matrix and then conduct a gap analysis.
V
vinqua
Amanda
Just because you are 13485 certified, you might not be cGMP. It depends on your certifying body. They were probably lenient and didn't want to give you any non-conformities. Did you receive any non-conformities from your certifying body? If not, that means you have been using the same certifying body.
Do you mind me asking if you received any non-conformities from the FDA Audit? If you did, then that means you are not cGMP compliant. According to the FDA , you have to become cGMP compliant.
GStough
Good advice, Doug. :applause::thanks:
Amanda, you may also want to check this web site http://www.gmp1st.com/ for more information on cGMPs.
Hope this helps. :bigwave:
Stijloor
Amanda
Amanda,
Our Fellow Covers Ted and Gidget have done great work:
Read their posts and attachments.
Look here for post + attachment
Stijloor.
Marcelo
Although both are related to the "quality systems" portion of the lifecycle regulations, as Doug pointed out, the cGMP is more prescriptive, meaning that they asks for more documentation (it was in some ways based on the old versions of quality systems standards which was more of a task-based documented SOP standards, very different from the process approach of the recent standards - ISO 13485 inclusive).
Also, there´s some fundamental difference in the approaches for "effectiveness" in the USa and "intented use" in ISO 13485 (which is based mainly on the EU point of view) which prevents them from being implemented and eudit as the same.
yodon
I wonder if the responses are missing the mark for the original post. Amanda indicates her company is a *component* manufacturer, not a finished device manufacturer. So what does cGMP compliance mean for a component manufacturer? Obviously the auditor didn't see the need for a thorough inspection. Are component manufacturers required to maintain DHRs and DMRs? Maybe there's no difference from a cGMP perspective?
Doug Tropf
This is from the QSR Manual, "Current FDA policy is to rely upon the finished device manufacturer to assure that components are acceptable for use. Component manufacturers are not routinely scheduled for GMP inspections; however, FDA encourages them to use the QS regulation as guidance for their quality system".
Marcelo
Component manufcturers have to be part of the quality system of the final device manufacturers because, dependening on the component, they can have a big impact on the final product. The "quality/risk management system parity" in which the suppliers are either part of the QS or have their own based on the the ones for the manufacturer is a trend in the industry.
A ASL requirement when the supplier is certified for ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
J Possible to get ISO 13485 certified with only OEM Product? ISO 13485:2016 - Medical Device Quality Management Systems 4
C CE marking for general IVD (self-certified) & ISO 13485 QMS requirements - auditing EU Medical Device Regulations 6
M Is it possible to get iso 13485:2016 certified as a one man band ISO 13485:2016 - Medical Device Quality Management Systems 1
C ISO 13485 certified as precursor to regulatory compliance to 21 CRF Part 820? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
M Are Medical device Raw material suppliers required to be ISO 13485 certified ISO 13485:2016 - Medical Device Quality Management Systems 13
N "Sterile" missing on the CE Certificate - ISO 13485 Certified Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 5
L Risk Management in an IVD, ISO 13485 certified company ISO 14971 - Medical Device Risk Management 2
L Looking for an ISO 13485 Certified Body in the US Registrars and Notified Bodies 28
S Database of ISO 13485 Certified Pharmaceutical Companies ISO 13485:2016 - Medical Device Quality Management Systems 1
C Start from Scratch: How to get my company ISO 13485 certified ISO 13485:2016 - Medical Device Quality Management Systems 11
L Do ISO 13485 Certified Organizations need to have Control Plans and FMEAs? ISO 13485:2016 - Medical Device Quality Management Systems 11
E How to become a Certified ISO 13485 Auditor ISO 13485:2016 - Medical Device Quality Management Systems 22
A Is a subcontractor required to be ISO 13485 certified? ISO 13485:2016 - Medical Device Quality Management Systems 27
somashekar ISO 13485 & ISO 9001 certified with addition of site. Covegratulations 10
I ISO 13485 - Would it be beneficial to get certified under my circumstances? ISO 13485:2016 - Medical Device Quality Management Systems 5
K Is ISO 9001 necessary if ISO 13485 certified? ISO 13485:2016 - Medical Device Quality Management Systems 17
J Can a non-medical device manufacturer (mold making) be certified to ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 11
T Already ISO 9001 Certified - What happens when we get ISO 13485 registered? ISO 13485:2016 - Medical Device Quality Management Systems 11
H Medical Device Suppliers Becoming Certified to ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 2
Y Contracted to get the organisation ISO 13485 certified ISO 13485:2016 - Medical Device Quality Management Systems 45
Ed Panek ISO 13485:2016 Section 5.5.3 ISO 13485:2016 - Medical Device Quality Management Systems 3
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
D ISO 13485 scope (implantable) - Polymers for dental application EU Medical Device Regulations 9
A ISO 13485 procedure change and reflect to legacy manufacture items ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 13485 & CE Certification for Surgical Gloves CE Marking (Conformité Européene) / CB Scheme 0
S Inventory Listing and ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 3
M ISO 13485:2016 Certification Scope ISO 13485:2016 - Medical Device Quality Management Systems 2
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
M Scope for ISO 13485 Certification of a Translation Service Provider ISO 13485:2016 - Medical Device Quality Management Systems 17
Q ISO 13485 7.5.6 Validation - Off the shelf Software ISO 13485:2016 - Medical Device Quality Management Systems 3
A ISO 13485 Certification for Resin Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 4
A ISO 13485 Sterilization Clause Applicability ISO 13485:2016 - Medical Device Quality Management Systems 7
K ISO 13485 and compliance of electronic signature ISO 13485:2016 - Medical Device Quality Management Systems 5
T ISO 13485 - Assembly instructions written vs. online ISO 13485:2016 - Medical Device Quality Management Systems 5
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 5
N 93/42/EEC certification without ISO 13485 EU Medical Device Regulations 3
M How Specific in an ISO 13485:2016 Scope for a Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 9
A ISO 13485 for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 7
0 ISO 13485:2016 Chapter 8 Integration of the subsections ISO 13485:2016 - Medical Device Quality Management Systems 3
M Change in Constitution / Ownership of firm -------ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
E ISO 13485 QMS certification as a Supplier ISO 13485:2016 - Medical Device Quality Management Systems 8
T ISO 13485:2016 Clauses related to process matrix ISO 13485:2016 - Medical Device Quality Management Systems 3
J Can signed agreements over-ride review of every "contract" under ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 2
J Implementing an ISO 13485 QMS Software ISO 13485:2016 - Medical Device Quality Management Systems 6
Q EN ISO 13485:2016/AC:2018 - AC:2018 being stated in the applicable harmonized standard listing Other ISO and International Standards and European Regulations 1
J Leveraging another company's ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
J New Job Position - Achieving ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 5
A Scope of ISO 13485 certificate ISO 13485:2016 - Medical Device Quality Management Systems 1
