ISO 13485 change in process
FuzzyD
All I work for a small machine job shop that does many one and two piece runs, Occasionally we have to change manufacturing methods mid process do to various reasons. What is the best way to handle these changes with product realization? Should we complete a new product realization each time the process is changed or is there an alternative?
Thanks in advance!!
yodon
Are these pieces intended for finished devices? Do you do 100% inspection on the outputs? Do you have a Quality Agreement (or similar) in place with your customers that require you notify them of any changes?
Sorry for all the questions but it can get complicated.
FuzzyD
The quality agreement does not state we need to notify them of changes. Most product is only made once or twice at the most and is not validated.
Zero_yield
"You can observe a lot by just watching."
I think it would be best to clarify with your customers what the intended use of the product is. I'm thinking of the parts that we occasionally outsource to a machine shop.
1). A one-time mounting bracket / tool holder for a piece of production equipment or a 5S / process flow improvement
-This likely wouldn't be a problem if there was some slight tweak, as long as all the materials stayed the same.
2). A validated/qualified fixture for processing product through some piece of equipment.
-As long as the final output matches the drawing, it likely wouldn't be a problem. However, I would definitely notify the customer if it's being manufactured in a different method than originally agreed to so that they could assess the risk to their process and product.
3). A piece of an actual medical device.
-This is where it gets really hairy, as yodon alluded to.
A ISO 13485 procedure change and reflect to legacy manufacture items ISO 13485:2016 - Medical Device Quality Management Systems 2
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
M Change in Constitution / Ownership of firm -------ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
M ISO 13485:2016 Cl. 5.1 - Management commitment verbiage change ISO 13485:2016 - Medical Device Quality Management Systems 2
S Packaging and Label Change Requirements - ISO 13485/FDA 21CFR820 ISO 13485:2016 - Medical Device Quality Management Systems 3
B ISO 13485 & Change of Address/Location ISO 13485:2016 - Medical Device Quality Management Systems 8
R ISO 13485 Certification for an Internal Warehouse? ISO 13485:2016 - Medical Device Quality Management Systems 1
J Is ISO 13485 certification necessary for Class I (non-sterile) medical devices? ISO 13485:2016 - Medical Device Quality Management Systems 4
A ISO:13485 Strategy for a Startup ISO 13485:2016 - Medical Device Quality Management Systems 5
G ISO 13485 and CE certification strategy ISO 13485:2016 - Medical Device Quality Management Systems 7
A Small Company Implementing ISO 13485 Timeline/Process/Steps Advice ISO 13485:2016 - Medical Device Quality Management Systems 5
R ISO 13485:2016 “Lifetime” of a product Manufacturing and Related Processes 4
kys123 Implications of failing an Anvisa Audit for ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 4
A Risk Assessment for ISO 13485:2016 section 7?? ISO 13485:2016 - Medical Device Quality Management Systems 11
L Annex of ISO 13485:2016 as harmonized standard (MDR/IVDR) ISO 13485:2016 - Medical Device Quality Management Systems 2
LostLouie DHF linked to ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 7
B ISO 13485 Certificate Location / Scope ISO 13485:2016 - Medical Device Quality Management Systems 9
M ISO 13485 Supplier Question ISO 13485:2016 - Medical Device Quality Management Systems 13
M ISO 13485:2016 Identification & Traceability ISO 13485:2016 - Medical Device Quality Management Systems 4
K Clause 7.5.2 of ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
J ISO 13485 and new warehousing ISO 13485:2016 - Medical Device Quality Management Systems 2
A Applying for ISO 13485 certification ISO 13485:2016 - Medical Device Quality Management Systems 8
Ed Panek Auditor Feedback ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 12
S ISO 13485 certification training Training - Internal, External, Online and Distance Learning 1
Ed Panek ISO 13485 Reporting Requirements ISO 13485:2016 - Medical Device Quality Management Systems 4
B ISO 13485 Qualification of R&D Equipment Qualification and Validation (including 21 CFR Part 11) 1
J Recognised/reputable courses for ISO 13485 Section 7.3 (Design & Development)? ISO 13485:2016 - Medical Device Quality Management Systems 1
Q ISO 13485 certificate needed if I go for MDSAP certification? ISO 13485:2016 - Medical Device Quality Management Systems 3
K ISO 13485 Design Requirement with respect to "component" manufacturers ISO 13485:2016 - Medical Device Quality Management Systems 11
P Registrar Cancelled ISO 13485 Auditors multiple times? Registrars and Notified Bodies 1
rob3027 ISO 13485 justification for design and development exclusion for medical packaging ISO 13485:2016 - Medical Device Quality Management Systems 18
A Help understanding what it takes to implement a QMS that is ISO 13485 compliant ISO 13485:2016 - Medical Device Quality Management Systems 4
FuzzyD ISO 13485:2016 Customer Assessment OFI ISO 13485:2016 - Medical Device Quality Management Systems 2
M ISO 13485 consultants and auditors with design oriented focus ISO 13485:2016 - Medical Device Quality Management Systems 7
S Brexit ISO 13485:2016 + Corrigendum - What does a UKCA DoC require? EU Medical Device Regulations 2
Aliken Recommendation for the ISO 13485 certification company ISO 13485:2016 - Medical Device Quality Management Systems 7
ISO-tired ISO 13485: file structure overview ISO 13485:2016 - Medical Device Quality Management Systems 11
M PROBLEM IN SCOPE OF ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
S ISO 13485 signing of Procedures etc. ISO 13485:2016 - Medical Device Quality Management Systems 10
N ISO 13485 Scope Reduction Other ISO and International Standards and European Regulations 2
M Can veterinary implants be ISO 13485 certified? ISO 13485:2016 - Medical Device Quality Management Systems 23
D Audit Report details when ISO 13485:2016 and cGMP 21 CFR 820 are applicable ISO 13485:2016 - Medical Device Quality Management Systems 6
R Looking for ISO 13485 Internal Audit Checklist ISO 13485:2016 - Medical Device Quality Management Systems 8
R Interesting Discussion Chapter 7.5 of ISO 13485 for manufacturers of mobile medical applications ISO 13485:2016 - Medical Device Quality Management Systems 4
V ADDING NEW MEDICAL DEVICE / Product, WHEATHER THIS AFFECTS EXISTING ISO 13485 CERTIFICATION? ISO 13485:2016 - Medical Device Quality Management Systems 4
K Subcontractors Providing Services Under MDD or MDR need ISO 13485 from EU Notified Body? CE Marking (Conformité Européene) / CB Scheme 8
E Theoretical project: Implementing ISO 13485:2016 into a start up acrylic bone cement manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 4
M ISO 13485: 2016 Lot numbering question ISO 13485:2016 - Medical Device Quality Management Systems 4
Q Documented Evidence of Training ISO 13485: 2016 ISO 13485:2016 - Medical Device Quality Management Systems 46
