ISO 13485 Clause 4.2.2 Documentation Structure - Quality Manual clarification
Q
QualitySysISOAdmin
My company is currently implementing ISO 13485 and I am attempting to do a GAP analysis. I just needed some clarifications as to what is required of the quality manual in the last paragraph of section 4.2.2 Quality Manual.
"The quality manual shall outline the structure of the documentation used in the quality management system"
Does this mean I have to do a chart mapping of all of our documents in the QAM?
If yes, can I just include those procedures which are required by ISO 13485?
Does anyone have any examples of what they did for their company?
:confused:
Any help would be greatly appreciated! :D
Q
Quality Priest
Hi QualitySysISOAdmin,
I have always believed in keeping things simplified, to which end I have addressed "The quality manual shall outline the structure of the documentation used in the quality management system" with this in the Quality Manual
"The quality management system document hierachry is -
i. Quality Manual (Include Quality Policy and Quality Objectives)
ii. Standard Operating Procedures/Work Instructions
iii. Forms & Records"
This statement is then backed up with a Document and Data Control Process which shows the full structure including procedures for change, retention periods etc.
Hope this helps, and im now wondering what other methods people use.
RCW
I have a "Procedure Cross Reference" section for each clause(s)/section of the manual. Here I list the quality procedures that are applicable. I also added an appendix that lists all the quality procedures by document number and name (I have about 33 listed.) This is a great way to quickly find that document number you keep forgetting for your calibration procedure. :notme:
Seeing you're in the 13485 medical arena....you might want to consider the following. Do you want to provide a cross reference somewhere to FDA (21CFR820) or other quality specs (Canadian, European, Japanese)? You would have to determine what is applicable to your business. I did have an auditor in here one time and she was whining about not being able to cross reference my documentation to 21CFR820. It seemed like a small point at the time but after I added this to my documentation, I did find myself referencing it. Just a suggestion.
Q
QualitySysISOAdmin
We currently have a cross reference chart as an appendix to our QA Manual. If that will satisfy the standard then it seems that I could simply add on to the chart. Thanks for your input.
Roland Cooke
The manual I liked the most was one that flowmapped out each process (including management responsibility, document control, infrastructure management, regulatory compliance, you name it). Responsibilities were identified, and the relevant procedures and other QMS documentation were linked to the map on subsequent pages.
It wasn't lengthy (though I imagine it took a good while to create) but it was really effective IMO.
It was one of those manuals that people in the company actually used on a routine basis. A terrifying prospect indeed! :D
IIRC, they also had a couple of pages of executive summary for handing out to interested parties.
Q
QualitySysISOAdmin
Great! :D
We currently already have a QMS flow chart and a product flow chart which lists out the procedures for those steps as well. In addition, I also realized that we included a pyramid mapping that shows the hierarchy of our different document types (procedures, work instructions, specifications, etc.)
My only other question is does it have to reference all documents that are required by the standard?
And is it ok to exclude those that are less important?
Is what we are currently doing enough? (cross reference chart, pyramid mapping, and flow chart references)
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
A ISO 13485 Sterilization Clause Applicability ISO 13485:2016 - Medical Device Quality Management Systems 7
K ISO 13485 clause 8.5.2 'Any necessary CA shall be taken without undue delay' ISO 13485:2016 - Medical Device Quality Management Systems 11
K Contamination Control - Class Is medical devices (Clause 6.4.2 ISO 13485:2016 (E)) ISO 13485:2016 - Medical Device Quality Management Systems 12
A ISO 13485 - Clause 8.3.3 appropriate actions in response to nonconforming product ISO 13485:2016 - Medical Device Quality Management Systems 2
K ISO 13485:2016, Clause 4.2.3 Medical Device File ISO 13485:2016 - Medical Device Quality Management Systems 4
F ISO 13485 8.2.3 Reporting to regulatory authorities: Question regarding a procedure for this clause. ISO 13485:2016 - Medical Device Quality Management Systems 4
L ISO 13485:2016 Clause 8.4 - Analysis of Audit Observations ISO 13485:2016 - Medical Device Quality Management Systems 8
M Contract Manufacturers and MDF Responsibilities, ISO 13485:2016, Clause 4.2.3 ISO 13485:2016 - Medical Device Quality Management Systems 3
JoshuaFroud Interpretation of Clause 5.5.2 in ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S What is the clause in ISO 13485 for SAP Software Validation? ISO 13485:2016 - Medical Device Quality Management Systems 3
M Damaged Customer Property - ISO 13485:2016 Clause 7.5.10 ISO 13485:2016 - Medical Device Quality Management Systems 7
GoSpeedRacer ISO 13485:2016 Clause 4.2.5 - Control of Records - HIPAA Requirements ISO 13485:2016 - Medical Device Quality Management Systems 11
T Struggling with ISO 13485:2016 Clause 6.2 - Level of Risk Associated with Work ISO 13485:2016 - Medical Device Quality Management Systems 3
T ISO 13485:2016 Clause 7.4.2 regarding Supplier Quality Agreements ISO 13485:2016 - Medical Device Quality Management Systems 11
R ISO 13485:2016 Clause 6.2 - Effectiveness Check ISO 13485:2016 - Medical Device Quality Management Systems 1
E ISO 13485 Clause 7.3.2 - Purchased Data Approval and Record Requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
S Interpreting clause 4.1.5 in ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 9
S Software Validation – Clause 4.1.6 of ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 12
P Which ISO 13485 clause(es) are applicable for Value Proposition Creation ISO 13485:2016 - Medical Device Quality Management Systems 1
J Definition Servicing - Definition - ISO 13485 Clause 7.5.1.2.3 - Servicing Activities Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
T ISO 13485 Clause 4.2.1 - Clarification of Intent ISO 13485:2016 - Medical Device Quality Management Systems 6
R ISO 13485 Clause 4.2.1 - Documentation Requirement question ISO 13485:2016 - Medical Device Quality Management Systems 4
D Taking an Exception to Clause 7.3 in ISO 9001 and ISO 13485 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
X Help with ISO 13485 Clause 8.3 "Rework" as applicable to Medical Device Servicing ISO 13485:2016 - Medical Device Quality Management Systems 39
X Help with ISO 13485 Clause 6.4 as it applies to Medical Device Servicing ISO 13485:2016 - Medical Device Quality Management Systems 25
C ISO 13485 Clause 7.5.1.2.1 Cleanliness of Product and Contamination Control Question ISO 13485:2016 - Medical Device Quality Management Systems 7
Project Man The "Ifs" in ISO 13485 Clause 6.4 Work Environment - Machine Shop which makes parts ISO 13485:2016 - Medical Device Quality Management Systems 1
A Human Resources (ISO 13485 Clause 6.2) example of SOP ISO 13485:2016 - Medical Device Quality Management Systems 1
T Quality Staff - Independence (ISO 13485 Clause 5.5.1) ISO 13485:2016 - Medical Device Quality Management Systems 1
P Control of Monitoring and Measurement Devices - ISO 13485 Clause 7.6 says ... ISO 13485:2016 - Medical Device Quality Management Systems 3
A Purchasing Information Requirements - ISO 13485 Clause 7.4.2 and FDA QSR Supplier Quality Assurance and other Supplier Issues 2
D Quality System Manual - Exclusions from ISO 13485 Clause 7.5 ISO 13485:2016 - Medical Device Quality Management Systems 4
N Validation of Special Processes - N/A of ISO 13485 Clause 7.5.2 ISO 13485:2016 - Medical Device Quality Management Systems 12
I Not having Training Records for Documentation Changes - ISO 13485 Clause 4.2.3 Document Control Systems, Procedures, Forms and Templates 22
J ISO 13485 Clause 1.2 Application Clarification ISO 13485:2016 - Medical Device Quality Management Systems 1
K ISO 13485 Clause 7.4 Purchase Order Requirements Question ISO 13485:2016 - Medical Device Quality Management Systems 4
somashekar Calibration interval (Clause 7.6 ISO 13485:2003) - Biomedical test instruments ISO 13485:2016 - Medical Device Quality Management Systems 4
R ISO 13485 Clause 7.6 Control of Monitoring and measuring devices - Requirements ISO 13485:2016 - Medical Device Quality Management Systems 10
Q Interpreting Responsibility and Authority Clause 5.5.1 ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 18
R Interpretation of ISO 13485 Clause 8.4 - Analysis of Data ISO 13485:2016 - Medical Device Quality Management Systems 20
J ISO 13485:2003 Clause 1.3 - Applicable Standards and Regulations ISO 13485:2016 - Medical Device Quality Management Systems 8
N Poor control of testing chemicals ? which ISO 13485/9001 clause does it contravene? ISO 13485:2016 - Medical Device Quality Management Systems 8
J How to accomplish ISO 13485 Clause 8.2.3 Monitoring and Measuring? ISO 13485:2016 - Medical Device Quality Management Systems 5
F ISO 13485 Clause 6.3 - System to determine and provide infrastructure ISO 13485:2016 - Medical Device Quality Management Systems 5
V Planning of Product Realization - Risk Management - ISO 13485 Clause 7.1 ISO 13485:2016 - Medical Device Quality Management Systems 6
D Effective Control of Processes - ISO 13485 Clause 4.2.1 (d) ISO 13485:2016 - Medical Device Quality Management Systems 2
A ISO 13485 Clause 8.2.2 - Internal auditor from within the company to be audited Internal Auditing 2
L ISO 13485: 2003 - Clause 8.4 Analysis of Data - Seeking an example procedure ISO 13485:2016 - Medical Device Quality Management Systems 2
H New Clause Structure of ISO 13485:2003 ISO 13485:2016 - Medical Device Quality Management Systems 5
