ISO 13485 Clause 7.3.2 - Purchased Data Approval and Record Requirements
Looking for second opinions on the requirements for approval and record requirements for purchased data that arose in an internal audit.
We have approved suppliers, documentation controlled part specifications and drawings for raw materials, contracts for routine contracted services etc. so am happy with the level of control of specifications and suppliers.
I have always considered that the clause of ISO 13485 7.3.2 "The organization shall ensure the adequacy of specified purchase requirements prior to their communication to the supplier." as approval of the purchase order (in addition to the approval of documented specifications etc).
Particularly as in some cases the purchased data is only documented in the PO form as there is no part specification; e.g. calibration or a service. My interpretation was that the approval of the PO was ensuring the adequacy of specified purchase requirements.
We have been challenged by purchasing dept that
a) approval of the PO is not required by ISO 13485 and
b) if we must approve POs; only 2 people have access to create a PO and these individuals review the PO as part of the process so no signature is required.
Similarly I have reviewed the 21 CFR part 820:50 requirements which state "purchasing data shall be approved in accordance with 820.40" 820.40 in turn relates to documentation control and review/approval of documents prior to issuance. So we meet that requirement for specifications, drawings etc but not for POs which do not have a specification, drawing or contract.
I suppose my interpretation was always approve the PO; to ensure control over purchased goods, correct part #, quantity etc.
Would be interested to know if this is in fact over the top and approval (printed & signed) is not required.
Thanks all!
Marcelo
Re: 7.3.2 Purchased Data
The adequacy requirements is there to guarantee that your purchasing information clearly reflect the organization need.
So, the questions here are:
- What is the related need?
- Does the purchasing information clearly reflect this need?
You may answer these two questions in one document, but more commonly, they are in different documents.
Then, you need to define where your purchase information is located. If it's in the PO, then you would need to approve it (you can look for formal interpretation RFI 104 for ISO 9001 which says "4.2.3 a) - Does documented purchasing information that is part of the quality management system, have to be approved according to 4.2.3 a)? - YES).
(To make things more clear, the process would be something like this: someone identify a need, register the need somewhere, then this need is translated into purchase information, which is registered somewhere, then a check is made to make sure that this purchase information clearly reflects the need, then the purchased information is approved, and then it can be sent).
Thank you Marcelo.
I agree we have most of the requirements documented in documentation controlled specifications, drawings etc but it is the Purchase Order that links the requirements to the supplier
a) Specifies the part number and revision, i.e. orders to the listed specification
b) lists the requirement if there is no specification for calibration, translations, product testing and so on
Don't mind challenging my thought process at all.
Good to check in with other quality people as sometimes in a small company the correct interpretation of the standard is not the popular one!
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
A ISO 13485 Sterilization Clause Applicability ISO 13485:2016 - Medical Device Quality Management Systems 7
K ISO 13485 clause 8.5.2 'Any necessary CA shall be taken without undue delay' ISO 13485:2016 - Medical Device Quality Management Systems 11
K Contamination Control - Class Is medical devices (Clause 6.4.2 ISO 13485:2016 (E)) ISO 13485:2016 - Medical Device Quality Management Systems 12
A ISO 13485 - Clause 8.3.3 appropriate actions in response to nonconforming product ISO 13485:2016 - Medical Device Quality Management Systems 2
K ISO 13485:2016, Clause 4.2.3 Medical Device File ISO 13485:2016 - Medical Device Quality Management Systems 4
F ISO 13485 8.2.3 Reporting to regulatory authorities: Question regarding a procedure for this clause. ISO 13485:2016 - Medical Device Quality Management Systems 4
L ISO 13485:2016 Clause 8.4 - Analysis of Audit Observations ISO 13485:2016 - Medical Device Quality Management Systems 8
M Contract Manufacturers and MDF Responsibilities, ISO 13485:2016, Clause 4.2.3 ISO 13485:2016 - Medical Device Quality Management Systems 3
JoshuaFroud Interpretation of Clause 5.5.2 in ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S What is the clause in ISO 13485 for SAP Software Validation? ISO 13485:2016 - Medical Device Quality Management Systems 3
M Damaged Customer Property - ISO 13485:2016 Clause 7.5.10 ISO 13485:2016 - Medical Device Quality Management Systems 7
GoSpeedRacer ISO 13485:2016 Clause 4.2.5 - Control of Records - HIPAA Requirements ISO 13485:2016 - Medical Device Quality Management Systems 11
T Struggling with ISO 13485:2016 Clause 6.2 - Level of Risk Associated with Work ISO 13485:2016 - Medical Device Quality Management Systems 3
T ISO 13485:2016 Clause 7.4.2 regarding Supplier Quality Agreements ISO 13485:2016 - Medical Device Quality Management Systems 11
R ISO 13485:2016 Clause 6.2 - Effectiveness Check ISO 13485:2016 - Medical Device Quality Management Systems 1
S Interpreting clause 4.1.5 in ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 9
S Software Validation – Clause 4.1.6 of ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 12
P Which ISO 13485 clause(es) are applicable for Value Proposition Creation ISO 13485:2016 - Medical Device Quality Management Systems 1
J Definition Servicing - Definition - ISO 13485 Clause 7.5.1.2.3 - Servicing Activities Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
T ISO 13485 Clause 4.2.1 - Clarification of Intent ISO 13485:2016 - Medical Device Quality Management Systems 6
R ISO 13485 Clause 4.2.1 - Documentation Requirement question ISO 13485:2016 - Medical Device Quality Management Systems 4
D Taking an Exception to Clause 7.3 in ISO 9001 and ISO 13485 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
X Help with ISO 13485 Clause 8.3 "Rework" as applicable to Medical Device Servicing ISO 13485:2016 - Medical Device Quality Management Systems 39
X Help with ISO 13485 Clause 6.4 as it applies to Medical Device Servicing ISO 13485:2016 - Medical Device Quality Management Systems 25
C ISO 13485 Clause 7.5.1.2.1 Cleanliness of Product and Contamination Control Question ISO 13485:2016 - Medical Device Quality Management Systems 7
Project Man The "Ifs" in ISO 13485 Clause 6.4 Work Environment - Machine Shop which makes parts ISO 13485:2016 - Medical Device Quality Management Systems 1
A Human Resources (ISO 13485 Clause 6.2) example of SOP ISO 13485:2016 - Medical Device Quality Management Systems 1
T Quality Staff - Independence (ISO 13485 Clause 5.5.1) ISO 13485:2016 - Medical Device Quality Management Systems 1
P Control of Monitoring and Measurement Devices - ISO 13485 Clause 7.6 says ... ISO 13485:2016 - Medical Device Quality Management Systems 3
A Purchasing Information Requirements - ISO 13485 Clause 7.4.2 and FDA QSR Supplier Quality Assurance and other Supplier Issues 2
D Quality System Manual - Exclusions from ISO 13485 Clause 7.5 ISO 13485:2016 - Medical Device Quality Management Systems 4
N Validation of Special Processes - N/A of ISO 13485 Clause 7.5.2 ISO 13485:2016 - Medical Device Quality Management Systems 12
I Not having Training Records for Documentation Changes - ISO 13485 Clause 4.2.3 Document Control Systems, Procedures, Forms and Templates 22
J ISO 13485 Clause 1.2 Application Clarification ISO 13485:2016 - Medical Device Quality Management Systems 1
K ISO 13485 Clause 7.4 Purchase Order Requirements Question ISO 13485:2016 - Medical Device Quality Management Systems 4
somashekar Calibration interval (Clause 7.6 ISO 13485:2003) - Biomedical test instruments ISO 13485:2016 - Medical Device Quality Management Systems 4
R ISO 13485 Clause 7.6 Control of Monitoring and measuring devices - Requirements ISO 13485:2016 - Medical Device Quality Management Systems 10
Q Interpreting Responsibility and Authority Clause 5.5.1 ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 18
Q ISO 13485 Clause 4.2.2 Documentation Structure - Quality Manual clarification ISO 13485:2016 - Medical Device Quality Management Systems 6
R Interpretation of ISO 13485 Clause 8.4 - Analysis of Data ISO 13485:2016 - Medical Device Quality Management Systems 20
J ISO 13485:2003 Clause 1.3 - Applicable Standards and Regulations ISO 13485:2016 - Medical Device Quality Management Systems 8
N Poor control of testing chemicals ? which ISO 13485/9001 clause does it contravene? ISO 13485:2016 - Medical Device Quality Management Systems 8
J How to accomplish ISO 13485 Clause 8.2.3 Monitoring and Measuring? ISO 13485:2016 - Medical Device Quality Management Systems 5
F ISO 13485 Clause 6.3 - System to determine and provide infrastructure ISO 13485:2016 - Medical Device Quality Management Systems 5
V Planning of Product Realization - Risk Management - ISO 13485 Clause 7.1 ISO 13485:2016 - Medical Device Quality Management Systems 6
D Effective Control of Processes - ISO 13485 Clause 4.2.1 (d) ISO 13485:2016 - Medical Device Quality Management Systems 2
A ISO 13485 Clause 8.2.2 - Internal auditor from within the company to be audited Internal Auditing 2
L ISO 13485: 2003 - Clause 8.4 Analysis of Data - Seeking an example procedure ISO 13485:2016 - Medical Device Quality Management Systems 2
H New Clause Structure of ISO 13485:2003 ISO 13485:2016 - Medical Device Quality Management Systems 5
