ISO 13485 Document Control - Document Changes - Needing Suggestions
love02eat
I am needing some suggestions on how to make changes to a work instruction that will keep the company incompliance with ISO13485. We are a manufacturing company that makes tubing for medical devices we are not a finished product we are not audited by FDA but we keep all rules in accordance. My dilemma is that different operators can finish the same job do to the fact that the product goes to different depts. to get finalized. Also accountability is not a strong point in this work place so someone is quick to say they didn't do that. (1.)There is already limited spacing for the techs to write all there measurements down but there can some times be mistakes and they correct them more then once. Also if the work order says they don't have to measure certain areas those spaces are blank. So the prior employee who created a work instruction just made it worse with using this rule 8.13.1 Use an asterisk ( * ) next to each error per person. The asterisk
will identify each error and who made the correction.
so on some docs you will 3 or 4 **** plus date and signature then she said no blanks all must put a line thru all blank data with N/A and initial and date it in the areas that doesn't get filled out. I need to know a better way for the techs to do there job with out extras and making internal audits task full because if they put the line and N/A but not there signature now its a noncompliance..
yodon
Without knowing your processes, it's going to be difficult for anyone to give appropriate suggestions. And there are a wide range of options. For example, can you move to an electronic-based system with appropriate checks and balances? Another option may be to have an in-process Quality (peer) check before the operator signs off. Another method may be to just provide more space on the form!
You do point out some pretty serious issues. The biggest of which, in my mind, is the loss of accountability. The documentation should be set up to where it's clear who did what and why (including mark-up corrections).
(Not sure what "rule 8.13.1" is and why recording asterisks is a good idea.)
I don't know how helpful that was. Probably the ideal approach would be to get all the stakeholders together to (re)define an optimized process that captures the required information, has checks along the way to minimize the need to do corrections after the fact, and covers all regulatory and customer requirements.
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
S What is the intent of the term "document" in ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 1
G Migrating to an ISO 13485:2016 Compliant Document Control System ISO 13485:2016 - Medical Device Quality Management Systems 6
I Does ISO 13485 have a Periodic Document Review Requirement? ISO 13485:2016 - Medical Device Quality Management Systems 7
C Document Numbering and Hierarchy Requirements for ISO 13485 Document Control Systems, Procedures, Forms and Templates 3
A Document Approval Requirements in an ISO 13485 and FDA System Document Control Systems, Procedures, Forms and Templates 7
D ISO 13485 Help - Determining what processes I specifically need to document ISO 13485:2016 - Medical Device Quality Management Systems 9
A ISO 13485, Document Control and Software Validation ISO 13485:2016 - Medical Device Quality Management Systems 9
E Document Retention Schedule Requirements per ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 4
P ISO 13485 Audit - EN 62366:2008 not in External Document File IEC 62366 - Medical Device Usability Engineering 1
I Document that summarizes the ISO 13485 and based on ISO 14969 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Defining Document Review and Approval responsibilities - ISO 13485 - Medical Device Document Control Systems, Procedures, Forms and Templates 3
O ISO 13485 sample document or template - Class II medical device ISO 13485:2016 - Medical Device Quality Management Systems 16
J Document control - ISO 13485:2003 - Obsolete controlled documents shall be retained? Document Control Systems, Procedures, Forms and Templates 7
R Where to Document Exclusions per ISO 13485 and ISO 9001 ISO 13485:2016 - Medical Device Quality Management Systems 2
Ed Panek ISO 13485:2016 Section 5.5.3 ISO 13485:2016 - Medical Device Quality Management Systems 3
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
D ISO 13485 scope (implantable) - Polymers for dental application EU Medical Device Regulations 9
A ISO 13485 procedure change and reflect to legacy manufacture items ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 13485 & CE Certification for Surgical Gloves CE Marking (Conformité Européene) / CB Scheme 0
S Inventory Listing and ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 3
M ISO 13485:2016 Certification Scope ISO 13485:2016 - Medical Device Quality Management Systems 2
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
M Scope for ISO 13485 Certification of a Translation Service Provider ISO 13485:2016 - Medical Device Quality Management Systems 17
Q ISO 13485 7.5.6 Validation - Off the shelf Software ISO 13485:2016 - Medical Device Quality Management Systems 3
A ISO 13485 Certification for Resin Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 4
A ISO 13485 Sterilization Clause Applicability ISO 13485:2016 - Medical Device Quality Management Systems 7
K ISO 13485 and compliance of electronic signature ISO 13485:2016 - Medical Device Quality Management Systems 5
T ISO 13485 - Assembly instructions written vs. online ISO 13485:2016 - Medical Device Quality Management Systems 5
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 5
N 93/42/EEC certification without ISO 13485 EU Medical Device Regulations 3
M How Specific in an ISO 13485:2016 Scope for a Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 9
A ISO 13485 for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 7
0 ISO 13485:2016 Chapter 8 Integration of the subsections ISO 13485:2016 - Medical Device Quality Management Systems 3
M Change in Constitution / Ownership of firm -------ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
E ISO 13485 QMS certification as a Supplier ISO 13485:2016 - Medical Device Quality Management Systems 8
T ISO 13485:2016 Clauses related to process matrix ISO 13485:2016 - Medical Device Quality Management Systems 3
J Can signed agreements over-ride review of every "contract" under ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 2
J Implementing an ISO 13485 QMS Software ISO 13485:2016 - Medical Device Quality Management Systems 6
Q EN ISO 13485:2016/AC:2018 - AC:2018 being stated in the applicable harmonized standard listing Other ISO and International Standards and European Regulations 1
J Leveraging another company's ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
J New Job Position - Achieving ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 5
A Scope of ISO 13485 certificate ISO 13485:2016 - Medical Device Quality Management Systems 1
A ASL requirement when the supplier is certified for ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
M ISO 13485-2016 online certification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
S Supplier Management ISO 13485: 2016- Which supplier needs to fill in a self assessment form? ISO 13485:2016 - Medical Device Quality Management Systems 6
J Possible to get ISO 13485 certified with only OEM Product? ISO 13485:2016 - Medical Device Quality Management Systems 4
