ISO 13485 Quality Record Retention Period
I’m currently updating our Control of Records SOP in response to the following feedback from a GAP/pre-certification audit:
"The control of records procedure did not define the time that records must be retained"
However I am struggling to find an official retention period for quality records. Can anyone confirm the official retention time/period for quality records under 13485?
I have checked the Medical Device Directory (93/42/EEC) and states it’s “5 years after the last product has been manufactured”.
So does this mean 5 years plus the lifetime of the product/device (e.g. lifetime of product is 10 years so 15 years total retention time), or is it just 5 years after the last product has been manufactured?
And I assume this stated retention period applies to IVD Devices (non-implantable)?
Also how do you decide how long to retain other quality records e.g. management reviews as they are not directly linked to a product or medical device (unlike testing records, Device Master Record etc)?
Do you just assign them the same default retention period of 5 years as stated in the MDD?
Apologies for all the questions!
Jean_B
Non-directly linked very safe bet is 15 years, but I've commonly set them safely at 7 years to cover certification periods that external parties might want to look back on. It remains highly dependent on product design aging and other factors though.
IVD is unknown to me.
Core questions:
  • Is my device special in any region, due to which i face special rules? (Japan; implantables)
  • What is my certification period? (and at least double that)
  • Did I specify (explicitly) or record (usually implicitly) a expected/projected useful/designed/service life? (This is different from warranty or guarantee period!)
Short overview (researched end of 2017) without sources (those manufacturers that would source, can source it themselves, just being efficient)
  • EU MDR: at least ten (10) years (fifteen (15) for implantables) after placing last device on the market (watch your blue guide here due to definition).
  • EU MDD: at least five (5) years (fifteen (15) for implantables) after placing last device on the market (watch your blue guide here due to definition).
  • Brazil: Equivalent to shelf life, or at least 2 years (counting from date of distribution) for products without shelf life.
  • USA: For the designed & expected life, or at least 2 years (counting from date of commercial distribution) for products without shelf life.
  • Canada: For the designed & projected useful life, or at least 2 years (counting from date of distribution) for products without shelf life.
  • Australia: at least five (5) years after last medical device was manufactured (to which that QMS was applied).
  • China: specified service life + 5 years (counting from the moment service life starts)
  • Japan (a complex one with designations, do your own research/verification with your MAH): Equivalent to shelf life, or at least five (5) years, except when products with specially designated maintenance control required medical devices, then fifteen (15) years. When shelf life exceeds either of these, then shelf life + 1 year.
EU Blue guide: ‘Blue Guide’ on the implementation of EU product rules - Internal Market, Industry, Entrepreneurship and SMEs - European Commission
From ISO 13485:2016:
The organization shall retain the records for at least the lifetime of the medical device as defined by the
organization, or as specified by applicable regulatory requirements, but not less than two years from
the medical device release by the organization.
If your device lifetime is 10 years, you need to retain your records for at least 10 years. In that case though, it is safer to just make it 15.
This requirement encompasses all quality system records.
You can maintain records electronically. You just have to show that the software you use for this is validated for its intended use.
NikkiQSM
Agreed with indubioush.
Our organization defines the life-time of the product to be 10 years or unless agreed upon with the customer, in writing.
Ed Panek
QA RA Small Med Dev Company
I recommend storing them for as long as space permits. If an auditor wants to dig through files from the past 15 years to find a violation that's their prerogative. OK sarcasm off.
S ISO 13485 Lead Auditor - Debate between our Quality Team and Regulatory Auditor - Internal Auditor Training ISO 13485:2016 - Medical Device Quality Management Systems 42
S SOP for ISO 13485:2016 Quality related Software validation ISO 13485:2016 - Medical Device Quality Management Systems 16
K ISO 13485 section 5.3 Quality Policy - No framework for establishing and reviewing quality objectives ISO 13485:2016 - Medical Device Quality Management Systems 2
S Procedure on Privacy Policy in the ISO 13485 quality management system ISO 13485:2016 - Medical Device Quality Management Systems 3
R ISO 13485 Software validation procedure and Quality Objectives Monitoring wanted Document Control Systems, Procedures, Forms and Templates 1
F ISO 13485:2016 Quality Policy Requirements Other ISO and International Standards and European Regulations 18
T ISO 13485 8.2.5. Monitoring and measurement of quality management system processes ISO 13485:2016 - Medical Device Quality Management Systems 1
S ISO 13485 Cl. 5.4.2 - Is Documented Quality Planning required? ISO 13485:2016 - Medical Device Quality Management Systems 2
B Integrated Quality Manual ISO 13485:2003 ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 6
R ISO 13485:2016 - Quality Objectives Regulatory Requirement Examples ISO 13485:2016 - Medical Device Quality Management Systems 1
S Is a Quality Policy Statement a Requirement? (ISO 13485) ISO 13485:2016 - Medical Device Quality Management Systems 7
R Examples of Quality Objectives related to ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 6
T ISO 13485:2016 Clause 7.4.2 regarding Supplier Quality Agreements ISO 13485:2016 - Medical Device Quality Management Systems 11
Y ISO 13485:2003 &FDA QSR (21 CFR 820) Quality Manual,34 Procedures and Form Book, Video, Blog and Web Site Reviews and Recommendations 8
J ISO 13485 and ISO9001 Quality Management Implementation Start ISO 13485:2016 - Medical Device Quality Management Systems 6
S Is this Quality Policy acceptable in the context of ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 24
J Two Quality Management Systems - ISO 13485 in one company possible? Quality Manager and Management Related Issues 4
B Best format for a combination ISO 9001/ISO 13485 Quality Manual? Quality Management System (QMS) Manuals 6
A Quality Objectives 5.4.1 - KPI SOP - ISO 13485 Audit Observations EU Medical Device Regulations 6
D Quality Management Systems - Differences between ISO 13485, 21 CFR Part 820 & ICH Q10 Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
M ISO 13485 x ICH Q10 Pharmaceutical Quality System - Comparison Evaluation ISO 13485:2016 - Medical Device Quality Management Systems 2
T Quality Compliance Software to meet ISO 13485 QMS and 21 CFR 820 Requirements Quality Assurance and Compliance Software Tools and Solutions 3
T Quality Staff - Independence (ISO 13485 Clause 5.5.1) ISO 13485:2016 - Medical Device Quality Management Systems 1
M IVD Annex III Path - Suitable Quality System (e.g. ISO 9001, ISO 13485)? EU Medical Device Regulations 2
Y Ideas of interactive exercises for a Quality Training (ISO 13485) Training - Internal, External, Online and Distance Learning 6
A Share Quality Policy that covers ISO 9001, ISO 13485 and MDD 93/42/EEC? ISO 13485:2016 - Medical Device Quality Management Systems 2
D Quality System Manual - Exclusions from ISO 13485 Clause 7.5 ISO 13485:2016 - Medical Device Quality Management Systems 4
F Quality Manual Template for ISO 13485 - Small Contract Medical Device Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 3
Sam Lazzara ISO 13485 Quality Policy that concisely meets standard ISO 13485:2016 - Medical Device Quality Management Systems 24
Y Training on the Basics of a QMS (Quality Management System) for ISO 13485 Training - Internal, External, Online and Distance Learning 4
N Template for a Quality Plan upgrading to ISO 13485 from ISO 9001 ISO 13485:2016 - Medical Device Quality Management Systems 2
Marc ISO 13485 - Medical Device Quality Management System Standard ISO 13485:2016 - Medical Device Quality Management Systems 30
M Writing Quality Objectives - ISO 13485 Quality Manual Quality Manager and Management Related Issues 2
L Quality Manual for ISO 13485 vs. 21 CFR 820 Quality Management System (QMS) Manuals 1
P Quality formats - ISO 13485 Design and development related records and formats ISO 13485:2016 - Medical Device Quality Management Systems 7
P Example ISO 13485 Quality Manuals/Systems Quality Management System (QMS) Manuals 6
Q ISO 13485 Clause 4.2.2 Documentation Structure - Quality Manual clarification ISO 13485:2016 - Medical Device Quality Management Systems 6
T Upgrading of QMS from ISO 9001 to ISO 13485 - Quality Manual Revision ISO 13485:2016 - Medical Device Quality Management Systems 5
P Looking for Quality Plan Examples - Medical Devices - ISO 13485 Misc. Quality Assurance and Business Systems Related Topics 5
S Integrating both ISO 13485 and TS 16949 into the same quality manual Quality Management System (QMS) Manuals 7
Q ISO 13485 Quality Manual Requirement ISO 13485:2016 - Medical Device Quality Management Systems 2
J ISO 13485 Similarities to 21 CFR Part 210/211 (Pharmaceuticals) for Quality systems Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
R Quality Policy: ISO 13485 vs. ISO 9001 (or AS9100 or..) ISO 13485:2016 - Medical Device Quality Management Systems 16
Ajit Basrur Quality Plan for ISO 9001 and ISO 13485 - Template or Example Needed Document Control Systems, Procedures, Forms and Templates 29
I ISO 9001 Quality Policy Manual vs. ISO 13485 Quality Policy Manual ISO 13485:2016 - Medical Device Quality Management Systems 6
L ISO 13485:2003 Quality Policy Controlled with a Revision date and number? ISO 13485:2016 - Medical Device Quality Management Systems 5
Q Minimum Quality records required by ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
F Going from ISO 9001 to ISO 13485 - How do I make a Quality manual? ISO 13485:2016 - Medical Device Quality Management Systems 5
M Efficient approach to convert Quality System from ISO 13485:2000 to ISO 13485:2003 ISO 13485:2016 - Medical Device Quality Management Systems 3
E Need an ISO 9001/14001/13485 Quality Manual - Many suppliers - Pharma and Med Devices Quality Management System (QMS) Manuals 7
