ISO 13485 relationship to 21 CFR 820
5
5johnson
We just had our 13485 certification audit. The Auditor pulled out 21 CFR 820 and audited us directly from it. I was not prepared for that. As I re-read ISO 13485, I cannot find where it states that we must be 21 CFR 820 compliant. What is the deal? What is the relationship between the ISO and the CFR?
SuperGirl
They are related, but different. If you were having your ISO 13485 cert. audit, the auditor should be auditing to that standard, not 21 CFR 820.
No where in ISO 13485 or 21 CFR 820 that states ou have to be compliant with the other.
somashekar
Are you in the US of A and going through your ISO 13485 certification ?
You are then required to have addressed the 21CFR820 requirements being a regulatory requirement touching you.
Aligning to ISO13485 is the big picture, where several regulatory requirements to which you subscribe are subsets.
Am I wrong ??
MIREGMGR
Agreed.
7.2.1 (c) requires you to conform to those aspects of 21CFR 820 (and 801, 807, etc.) that bear on product requirements, in regard to those aspects of ISO 13485 conformance that pertain to product requirements.
The auditor might take a broad view that everything your QMS is used for, pertains to your products; and similarly, everything in 21CFR 820 pertains to products.
Ronen E
Problem Solver
Moderator
I can see where the auditor is coming from, but I must say that auditing you directly against part 820, in full, is a bit extreme IMO. If you're in the USA, or distribute your devices in the USA market, you are definitely required to identify the applicable FDA requirements, and comply. If I was auditing you, I'd first look to see how you identified all such requirements (under the various 13485 clauses that mention regulatory requirements), and then how you addressed them.
Marc
I agree with this with the condition that most of the "quality" standards require compliance with applicable regulatory standards. However, in my opinion that does not give the auditor a door to audit compliance to specific regulations. All it requires is that the company has identified and addressed them. The original poster says that the audit was to ISO 13485, yet the auditor pulled out 21 CFR part 820 and audited to it.
We just had our 13485 certification audit. The Auditor pulled out 21 CFR 820 and audited us directly from it. <snip>
I would have stopped the audit right there. 21 CFR 820 specific requirements are outside the scope of an ISO 13485 registration audit.
5
5johnson
thank you all for your help. I was thinking of stopping the audit but felt like I was the one who missed something. Our facility is pretty tight. already ISO 9000 and ISO/TS 16949. We did alright. We passed, but I have way more findings that I want. Now that I know the facts I can address some of these findings with the auditor. thanks again for your help.
Ajit Basrur
Ronen has addressed right to the point ... are you based in US and do you manufactured "finished medical devices" ?
If the answer is YES, the ISO 13485 auditor has to check if you are fulfiling the regulatory requirements.
Remember the title of ISO 13485 is "Medical devices — Quality management
systems — Requirements for regulatory purposes" and if you are in US, 21 CFR Part 820 is the QMS for medical devices !
5
5johnson
We are in the US and make medical device components. We do not make a finished medical device. We are listed with the FDA as a contract manufacturer.
sagai
If you look into ISO13485 itself, at several places it mentions "national or regional" (check these two keywords if you think) regulations to be considered or to be applied, especially for document management.
I have just double checked and actually I tend to say yes, for a limited scope the ISO13485 audit itself could look into the level of compliance as regard to some of the aspects of 21CFR820 in case you have a binding to it.
Cheers!
S Relationship between IEC 62304 problem resolution and ISO 13485 IEC 62304 - Medical Device Software Life Cycle Processes 8
C ISO9001 and ISO 13485 Relationship? Can we do both effectively? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
shimonv Operator vs. Manufacturer Relationship and ISO 13485 / CE Requirements ISO 13485:2016 - Medical Device Quality Management Systems 5
Ed Panek ISO 13485:2016 Section 5.5.3 ISO 13485:2016 - Medical Device Quality Management Systems 3
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
D ISO 13485 scope (implantable) - Polymers for dental application EU Medical Device Regulations 9
A ISO 13485 procedure change and reflect to legacy manufacture items ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 13485 & CE Certification for Surgical Gloves CE Marking (Conformité Européene) / CB Scheme 0
S Inventory Listing and ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 3
M ISO 13485:2016 Certification Scope ISO 13485:2016 - Medical Device Quality Management Systems 2
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
M Scope for ISO 13485 Certification of a Translation Service Provider ISO 13485:2016 - Medical Device Quality Management Systems 17
Q ISO 13485 7.5.6 Validation - Off the shelf Software ISO 13485:2016 - Medical Device Quality Management Systems 3
A ISO 13485 Certification for Resin Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 4
A ISO 13485 Sterilization Clause Applicability ISO 13485:2016 - Medical Device Quality Management Systems 7
K ISO 13485 and compliance of electronic signature ISO 13485:2016 - Medical Device Quality Management Systems 5
T ISO 13485 - Assembly instructions written vs. online ISO 13485:2016 - Medical Device Quality Management Systems 5
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 5
N 93/42/EEC certification without ISO 13485 EU Medical Device Regulations 3
M How Specific in an ISO 13485:2016 Scope for a Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 9
A ISO 13485 for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 7
0 ISO 13485:2016 Chapter 8 Integration of the subsections ISO 13485:2016 - Medical Device Quality Management Systems 3
M Change in Constitution / Ownership of firm -------ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
E ISO 13485 QMS certification as a Supplier ISO 13485:2016 - Medical Device Quality Management Systems 8
T ISO 13485:2016 Clauses related to process matrix ISO 13485:2016 - Medical Device Quality Management Systems 3
J Can signed agreements over-ride review of every "contract" under ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 2
J Implementing an ISO 13485 QMS Software ISO 13485:2016 - Medical Device Quality Management Systems 6
Q EN ISO 13485:2016/AC:2018 - AC:2018 being stated in the applicable harmonized standard listing Other ISO and International Standards and European Regulations 1
J Leveraging another company's ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
J New Job Position - Achieving ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 5
A Scope of ISO 13485 certificate ISO 13485:2016 - Medical Device Quality Management Systems 1
A ASL requirement when the supplier is certified for ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
M ISO 13485-2016 online certification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
S Supplier Management ISO 13485: 2016- Which supplier needs to fill in a self assessment form? ISO 13485:2016 - Medical Device Quality Management Systems 6
J Possible to get ISO 13485 certified with only OEM Product? ISO 13485:2016 - Medical Device Quality Management Systems 4
D Definition of equipment for ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 1
M ISO 13485:2016 Complaint Definition Clarity Customer Complaints 2
D Rules for Paper Forms outside of an eQMS - 3 Questions (ISO 13485) Document Control Systems, Procedures, Forms and Templates 9
S Qualification question - ISO 13485 - Setting up a small lab Reliability Analysis - Predictions, Testing and Standards 2
K ISO 13485 clause 8.5.2 'Any necessary CA shall be taken without undue delay' ISO 13485:2016 - Medical Device Quality Management Systems 11
J How much to charge for helping a startup company with initial ISO 13485 certification? Consultants and Consulting 3
J ISO 13485 System 'soft start' - How to best reflect this in initial audits, management review minutes and other records? ISO 13485:2016 - Medical Device Quality Management Systems 3
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 5
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
D ISO 13485 8.2.1 and 8.2.2 - Customer Feedback and Customer Complaints ISO 13485:2016 - Medical Device Quality Management Systems 5
Sravan Manchikanti How to interpret '8.3 Control of nonconforming product' for SaMD device while implementing ISO 13485 & MDSAP ISO 13485:2016 - Medical Device Quality Management Systems 7
M Getting started in ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 31
P ISO 13485:2016 MDSAP Certification Fee Survey ISO 13485:2016 - Medical Device Quality Management Systems 6
