ISO 13485 scope (implantable) - Polymers for dental application
Daliane
Hi all
My client is a Virtual Manufacturer of a polymer that is used for dental application with 3D printing technology. The polymer is sold to dental labs to print temporary implants (use up to 1 year) and dental bridges.
They don't manufacture this polymer, but get the ready bottles with content from the OEM. The polymer itself is class I.
I need help to assess whether it falls under following requirement of ISO 13485 section "7.5.9.2 Particular requirements for implantable medical devices"?
Thanks!
Regards
Daliane
planB
Daliane,
as @indubioush pointed out: if your device falls under the definition ISO 13485, section 3.6, then yes, section 7.5.9.2 also applies to your device.
Hope this helps,
Daliane
Ok maybe I should clarify my question: I need help to determine if this resin is applicable to the definition in section 3.6
We declare that this resins can print dental bridges. But we don't sell the dental application, only the resins itself.
Any idea someone?
Thanks a lot!
somashekar
Any idea someone?
Thanks a lot!
NO. It does not.
7.5.9.2 can be your non-application
Your product / service is far from being what is said in 3.6 of terms and definitions.
monoj mon
Although it looks like the resin doesn't fall under the section 3.6, but I feel like it is not that simple. As @Daliane has said and I quote
It is already intended as dental implant, the only difference is the user (dental lab) needs to give it a shape using a 3D Printer! What about "Bone Cement"! Are the ingredients considered to be under Section 3.6! Does anyone has any experience with it! I am just curious.
planB
Daliane,
you originally stated that your resin is a class I medical device. I assume you have an associated biocompatibility report on file? If yes, how did you categorize your device from an ISO 10993-1 perspective in terms of nature and duration of body exposure?
QM_123
Daliane,
Yes it is dental resin, you sell it to labs and they use 3D printers to make a final device (dental bridge). I think this is Class IIa device. Most probably you identified intended use as "dental bridge" in IFU . As planB said, you check your device category in terms of biocompatibility. On the other hand, I suggest you to check any equivalent device's IFU, if you are not sure. In this scope, I think 7.5.9.2 is applicable for your device. Your processes to produce your resin is important for safety and performance of the final device (dental bridges). For example, if you use wrong raw material or wrong mixture rates for resin that may cause non-biocompatible device.
Daliane
Sorry my bad.
The resins for dental applications are class I. The ones for temporary use in the mouth like bridges and implants are definitely class IIa.
Thanks for your feedback guys!
Regards
Daliane
M ISO 13485:2016 Certification Scope ISO 13485:2016 - Medical Device Quality Management Systems 3
M Scope for ISO 13485 Certification of a Translation Service Provider ISO 13485:2016 - Medical Device Quality Management Systems 17
M How Specific in an ISO 13485:2016 Scope for a Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 9
A Scope of ISO 13485 certificate ISO 13485:2016 - Medical Device Quality Management Systems 1
K Medical Device Repairs and ISO 13485 Scope ISO 13485:2016 - Medical Device Quality Management Systems 7
K Restricted Scope of ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 7
R Scope of ISO 13485 certification ISO 13485:2016 - Medical Device Quality Management Systems 6
P Dropping ISO 9001 limits the scope of the ISO 13485 audit? ISO 13485:2016 - Medical Device Quality Management Systems 6
S ISO 13485 scope of certification - We are a virtual manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 1
K MDSAP scope vs ISO 13485 Scope Canada Medical Device Regulations 4
R Scope of Certification for a Design Organization with Outsourced Mfg. - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 10
M OEM-OBL ISO 13485 Certification - Devices mentioned in the product scope ISO 13485:2016 - Medical Device Quality Management Systems 6
chris1price What are the Scope Numbers on ISO 13485 Certificates ISO 13485:2016 - Medical Device Quality Management Systems 2
R ISO 13485 Certificate Scope modified by Notified Body EU Medical Device Regulations 9
S What is the scope of EN ISO 13485 and ISO 13485 ? ISO 13485:2016 - Medical Device Quality Management Systems 3
A Scope of ISO 13485 Registration and Component Makers ISO 13485:2016 - Medical Device Quality Management Systems 7
D Scope of ISO 13485 Certification needs the word Production. ISO 13485:2016 - Medical Device Quality Management Systems 9
V ISO 13485 certification scope in Spanish ISO 13485:2016 - Medical Device Quality Management Systems 5
N Scope of ISO 13485 Certificate for Multiple Devices EU Medical Device Regulations 3
B Class IIb Medical Device using Annex II route - Need to Update ISO 13485 Scope? ISO 13485:2016 - Medical Device Quality Management Systems 2
L Non-medical device is in the ISO 13485 audit scope? ISO 13485:2016 - Medical Device Quality Management Systems 11
Ajit Basrur Scope for ISO 13485 vs. ISO 15378 - Molding Parts for Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
D Question on using audit checklist ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 12
M ISO 13485 and document control for programs ISO 13485:2016 - Medical Device Quality Management Systems 6
M Customer Property - ISO 13485:2016 Clause 7.5.10 ISO 13485:2016 - Medical Device Quality Management Systems 9
pbojsen ISO 13485 Requirements versus FDA product classification and GMP exemptions - Audits ISO 13485:2016 - Medical Device Quality Management Systems 3
D Lead time to schedule an ISO 13485 audit General Auditing Discussions 2
S Does anyone have a checklist to prepare for ISO 13485, Stage I audit? ISO 13485:2016 - Medical Device Quality Management Systems 1
H QMS ISO 13485:2016 - ISO14971 IEC60304 etc ISO 13485:2016 - Medical Device Quality Management Systems 6
B Operational Procedures for ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 7
D ISO 14971 applicability in ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 7
E ISO 13485 in Clinical Trial conduct: Applicable or No ISO 13485:2016 - Medical Device Quality Management Systems 2
G ISO 13485 Certification - Can we get the ISO 13485 certification prior to shipment of the device? ISO 13485:2016 - Medical Device Quality Management Systems 6
N Does anyone use SGS for ISO 13485 / CE certification Registrars and Notified Bodies 0
Ed Panek ISO 13485:2016 Section 5.5.3 ISO 13485:2016 - Medical Device Quality Management Systems 3
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
A ISO 13485 procedure change and reflect to legacy manufacture items ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 13485 & CE Certification for Surgical Gloves CE Marking (Conformité Européene) / CB Scheme 0
S Inventory Listing and ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 3
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
Q ISO 13485 7.5.6 Validation - Off the shelf Software ISO 13485:2016 - Medical Device Quality Management Systems 3
A ISO 13485 Certification for Resin Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 4
A ISO 13485 Sterilization Clause Applicability ISO 13485:2016 - Medical Device Quality Management Systems 7
K ISO 13485 and compliance of electronic signature ISO 13485:2016 - Medical Device Quality Management Systems 5
T ISO 13485 - Assembly instructions written vs. online ISO 13485:2016 - Medical Device Quality Management Systems 5
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 8
N 93/42/EEC certification without ISO 13485 EU Medical Device Regulations 3
A ISO 13485 for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 7
0 ISO 13485:2016 Chapter 8 Integration of the subsections ISO 13485:2016 - Medical Device Quality Management Systems 3
