ISO 14001 / 18001 - How to incorporate these two standards - Internal audit checklist
  • Thread starter Casey Cochran - 2009
  • Start date
Hello all,
I have been spending a lot of time traveling through this great forum and it has been a real help in my new job. However, I am now re-creating the 14001/18001 internal audit program. Person before me had a 42 page plantwide get it all checklist but... Auditor did not like it.:confused: It was too vague. Anyway, I was wondering if I could get some advise on how to incorporate these two standards into a checklist?
L
LEADAUDITOR
checklist
My suggestion would to audit each area for these two standards. Take items that you may have had problems with and add them to the checklist under the correct element. This way your auditing the areas that has the most concern.
RoxaneB
I'm curious as to what you mean, Casey, by "It was too vague." Granted, if this is the opinion of your external auditor, you may want more clarification from him/her before continuing any further. :)
That being said, you could always develop a checklist that repeats the shalls from the standard and then select the appropriate clauses for the process being audited. If I was auditing our furnace process, for example, I wouldn't audit on management review, but I would talk about emergency preparedness (and other stuff, too).
Or you create a checklist template and develop a customized checklist each time you audit. Base it upon the standards and the processes so that each audit is specific to the process being audited.
But first, the "It was too vague" statement is to vague. :D
Vague...well, the old way of doing these was to do multible areas, summed together in one checklist. The auditor saw one checklist that was made specificly for our plating / wastewater treatment, due to complexity. (only 14001) He liked that idea and wanted to see each area to have it's own, specific checklist, since there are so many different operations in our facility. (stamping, heat treat, plating, staking, 800 ton press, brazing, bending, etc, etc..) Is a checklist even the way to go?
L
LEADAUDITOR
checklist
not necessarily. If you can audit without a checklist and still meet the intent of the standard, you'll be ok. Alway remember when being audited, it is only the auditor's perception. So if you do not agree with an issue, question motives for the issue. The standards are vague as well. This gives you the advantage. I always worked without a checklist and still got it done by the standards.
I could do it but I have other auditors who need the guidance to ensure a complete audit. I was hoping someone might have a good example I could use to help get me started in the right direction.
Randy
Casey the checklist is just the beginning and not "The Audit". You use it to get to where you need to start. Also conduct your audit the way the work flows..we call this process auditing. Once you've done an audit to the "shalls" you need to get deeper into how the "shalls" are actually being met.
tigerfan51
Audit Checklists vs. Effectiveness
Internal audit checklists tend to repeat the standard and focus on implementation issues - questions like "does the company have have a procedure" , "is the procedure documented" , "does the company have a policy" , "is the policy available to the public", etc. Implementation issues and making sure that all shalls in the standard are met is important for a new system/internal audit program. This makes perfect sence when the system is new - you want to make sure all the bases are covered. However, if your internal audit program continues to ask only these types of questions it will become very repetitive and eventually useless.
The challenge for an internal audit program is to evolve and become more sophisticated as the system matures. The program should place less emphasis on implementation questions and spend more time assessing the effectivness of the area / element being audited. Questions that test effectiveness are much harder to develop and can't be taken directly from the standard. Examples such as "was an EMP conducted/completed as planned" , "what results were achieved by the EMP" , "were the achieved results as expected" , "have policy commitments been achieved" , "how were policy committments achieved" , "has the overall intent of the policy been achieved" are ones that attempt to determine if the company is effective in the areas being audited.
So my advice is to not overly rely on checklists which just test the shalls in the standard. You need to examine/analyze each area/process/element being audited and develop specific questions which will help your auditors make a judgement as to whether or not the system continues to be effective in that particular area/process/element.
Charlie Brown
Does anyone have an editable version of an ISO 14001:2004 Internal Audit Checklist? If so, can you please post. "Need Desperately" Thanks!
Welcome to the Cove, Charlie :bigwave: . I removed your post in the other forum; duplicate posting is frowned upon; you'll most likely get a directed response (like this one) in this forum. Have a look in this thread: Internal Auditor Check List for ISO 14001, and also use the Search function to see what other nuggets you might be able to come up with.
Q Correspondence between ISO 14001:2015 & OHSAS 18001:2007 ISO 14001:2015 Specific Discussions 2
W ISO 9001, ISO 14001 and 18001 Integrated Approach ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Combined Quality Manual for ISO 9001, ISO 14001, ISO 50001 and OHSAS 18001 Document Control Systems, Procedures, Forms and Templates 11
C Integrating ISO 9001, 14001 & OSHAS 18001 - Do you need a Manual & Procedures? Document Control Systems, Procedures, Forms and Templates 5
S Evaluation of legal compliance to ISO 14001 and OHSAS 18001 ISO 14001:2015 Specific Discussions 18
A R2 Certification vs Self Declaration to ISO 14001 and OHSAS 18001 ISO 14001:2015 Specific Discussions 3
A Multi-Site Certification to ISO 9001, 14001 and OHSAS 18001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
D What is required in a combined ISO 9001, ISO 14001 and OHSAS 18001 Audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
C ISO 14001 and OHSAS 18001 Registrar Auditor Credentials Career and Occupation Discussions 8
K Auditing OHSAS 18001, ISO 9001 & ISO 14001 for 4 Business Units General Auditing Discussions 2
E ISO 9001, ISO 14001 and 0HSAS 18001 Procedures Manual Quality Management System (QMS) Manuals 10
S Logo Marking for Marketing purpose - ISO 9001, ISO 14001 and OHSAS 18001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
I ISO 14001 & OHSAS 18001 Questionnaire for Internal Auditor Certificate Other ISO and International Standards and European Regulations 2
D ISO 9001, OHSAS 18001, ISO 14001 Management Review Template Document Control Systems, Procedures, Forms and Templates 5
GStough Integrating 3 System Standards - ISO 9001, ISO 14001, OHSAS 18001 Other ISO and International Standards and European Regulations 20
somashekar OSHAS 18001 and ISO 14001 Combined Survelliance Audit Manday Guidelines Occupational Health & Safety Management Standards 5
J ISO 9001, ISO 14001, OHSAS 18001 Power Plant Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Integration of ISO 14001 & OHSAS 18001 with ISO 9001:2008 REACH and RoHS Conversations 5
A Integrated Manuals that cover ISO 9001, ISO 14001 and OHSAS 18001 Quality Management System (QMS) Manuals 9
D I wish to know about ISO 28000, ISO 14001 and OHSAS 18001 Other ISO and International Standards and European Regulations 7
G Incorporating OHSAS 18001 with ISM and ISO 14001 Occupational Health & Safety Management Standards 13
C OHSAS 18001 vs. ISO 14001 - Differences in Training Occupational Health & Safety Management Standards 5
N Cross-Referencing ISO 9001/ISO 14001/OHSAS 18001 Occupational Health & Safety Management Standards 17
C IMS (ISO 14001/ BS OHSAS 18001) combined Audit Checklist & Schedule ISO 14001:2015 Specific Discussions 1
S Need Integrated Management System Manual (ISO 9001, 14001 & OHSAS 18001) Document Control Systems, Procedures, Forms and Templates 11
D Internal Audit Training Material covering ISO 9001, ISO 14001 & OHSAS 18001 Training - Internal, External, Online and Distance Learning 1
L Value of an integrated system (iso 9001, iso 14001, oshas 18001) Misc. Quality Assurance and Business Systems Related Topics 11
R GAP Analysis for an ISO 9001, ISO 14001 and OHSAS 18001 system ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P Combined ISO 9001, ISO 14001 and OHSAS 18001 Manual and System Quality Management System (QMS) Manuals 8
M Integration of ISO 17025 with TS 16949, ISO 14001 and OHSAS 18001 ISO 17025 related Discussions 8
J Possibility of certifying to IMS (ISO 9001, ISO 14001 & OHSAS 18001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
I Combined ISO 14001 / OHSAS 18001 Implementation ISO 14001:2015 Specific Discussions 16
G Health & Safety Executive - ISO 14001 and OHSAS 18001 Confusion Occupational Health & Safety Management Standards 6
G Hazard Identification Categories - ISO 14001 vs OHSAS 18001 Occupational Health & Safety Management Standards 3
M Integrating ISO 14001 & 9001 into OHSAS 18001 Occupational Health & Safety Management Standards 65
T ISO 9001, ISO 14001, ISO 27001 & ISO 27002 and OHSAS 18001 Standards Gap Analysis General Auditing Discussions 38
L Integrated (ISO 9001 & 14001 and OHSAS 18001) Management Review Meetings Management Review Meetings and related Processes 50
Colin Integrated Systems Assessment for ISO 9001 / ISO 14001 / BS OHSAS 18001 Other ISO and International Standards and European Regulations 19
W Auditing multiple standards - TS 16949, ISO 14001 & OHSAS 18001 General Auditing Discussions 12
Antonio Vieira World Wide Certifed Power Plants study - ISO 9001, ISO 14001 and OHSAS 18001 Registrars and Notified Bodies 10
O Videos on OHSAS 18001 and ISO 14001 EMS either in VHS or DVD format Occupational Health & Safety Management Standards 2
H What are the Current OHSAS 18001 & ISO 14001 Revisions & Combined Systems Various Other Specifications, Standards, and related Requirements 37
S ISO 14001 and OHSAS 18001 powerpoint .ppt presentations Training - Internal, External, Online and Distance Learning 3
S Making an Environmental Park - What it should contain? ISO 14001 & OHSAS 18001 Occupational Health & Safety Management Standards 11
G Examples of Integrated ISO 14001:2004 and OHSAS 18001: 1999 policy manuals Occupational Health & Safety Management Standards 13
C Will OHSAS 18001 will follow the same revision trail as ISO 14001? Occupational Health & Safety Management Standards 5
S OHSAS 18001 Implementation - ISO 14001 Integration - Worker's Comp breaks? Occupational Health & Safety Management Standards 10
C ISO 14001:2015 6.1.3 Compliance Obligations - Legal requirements monitoring ISO 14001:2015 Specific Discussions 0
A Environmental Compliance obligations and risks (ISO 14001:2015 6.1.3) ISO 14001:2015 Specific Discussions 3
Z Auditor Findings ISO 14001:2015 vs. 45001:2015 ISO 14001:2015 Specific Discussions 6
