ISO 14001:2004 requires organizations to determine how environmental regulations and other requirements apply to its environmental aspects. I am interested in thoughts on the level of detail the standard expects the aspect-to-requirement linkage to be. Is it ok just to say “used oil is regulated aspect” or does the standard expect greater detail (40 CFR Part 279)? Does the linkage need to actually describe the requirement such as 40 CFR Part 279.22 (c) Labels (1) Containers and aboveground tanks used to store oil at generators facilities must be labeled or marked clearly with the words “Used Oil”.
How much detail does the standard expect? What about state regulations? Here in WI we have NR 590 Subchapter II Standards for Used Oil Generators that also specifies labeling requirements. Is aspect linkage needed to those requirements also?
There are probably thousands of state federal and local environmental regulations and other requirements that apply to a large complex manufacturing facility. Does an organizations need to list them all and in what format? If so where is the value in doing so? Why not just reference the entire code?
