ISO 14001 Control vs. Influence - Environmental Aspects Identification
N
nimbuszero
Greetings all! Obviously, this is my first post. I've been browsing the forums for about a month taking in as much information as possible before daring to ask any questions. However, I have one issue now that I feel comfortable in requesting some guidance on.
In regards to 4.3.1 and the Environmental Aspects identification procedure, I'm having trouble determining the distinction between "control" and "influence". As this is the case, I certainly have no idea how to work the designating of aspects as one or the other into a documented procedure.
I've looked at countless matrices and have found that unfortunately, they tend to avoid stating whether an aspect is controlled or influenced. Any guidance that could be given in regards to my issue would be greatly appreciated. It may be very obvious, but I'll state anyway that I'm very new to this EMS Coordinator position I am in, and essentially, I am the CFT =/
Sidney Vianna
Post Responsibly
Re: ISO 14001 Control versus Influence
Welcome to The Cove and congrats on posting for the first time. I remember the feeling almost 7,000 posts ago. How "intimidating" that was. As for your question, did you have a chance to read section A.3.1 of ISO 14001:2004? Annex A is an informative guidance section of the standard. Paragraph A.3.1 talks about the control vs. influence issue.
samsung
Enough guidance is given in the Annexure (A.3.1 Environmental aspects) to ISO 14001 standard.
In addition to those environmental aspects an organization can control directly, an organization should also consider aspects that it can influence, e.g. those related to goods and services used by the organization and those related to products and services that it provides. Some guidance to evaluate control and influence is provided below. However, in all circumstances it is the organization that determines the degree of control and also the aspects it can influence.
ISO 14001 only requires you to identify those aspects that you can control and those you can influence (within the defined scope). If they aren't significant (based on the criteria set by the organization), you don't have to do anything. e.g. disposition of packaging material, if you can't control or influence the end users by any means, you don't even need to 'identify' it as an aspect.
N
nimbuszero
Ah, you know, I did read that before, I've just been so overwhelmed with information in my new position that I let it get pushed into the recesses of my mind. Thank you very much for reminding me :) Now I just need to figure out how to work this into a procedure. Thank you again!
Randy
Keep it simple...Read the definitions in Section 3 and study Annex A to help gain some clarity...And don't get all wrapped around the axle trying to identify every aspect in the world, it's a process that once you have in place will mature and get better. Aspect identification is like peeling layers off of an onion...Start big and as you gain in understanding start working inward until you get to the smaller stuff deeper inside the scope (scope means boundaries) of your system (activies, products and services)
N
nimbuszero
Thank you very much for your thoughtful response. I'm beginning, slowly to get the hang of identification. Initially I was feeling overwhelmed, but now I feel as though I'm taking an approach similar to your recommendation of "peeling". Again, thank you for the advice, I really do appreciate it.
Randy
Everybody feels overwhelmed at 1st...Kinda like I was the 1st time I jumped out of an airplane that wasn't broke!
Lok at it this way....There's no way to do it wrong other than the way it don't work for ya.
If it don't work...FIX IT! And you can change the way you do it any time you want...It seems like people forget to tell folks this last bit of information....There isn't any set in concrete, NADA
T Identification and Control of External Documents - 4.4.5 f) of ISO 14001 ISO 14001:2015 Specific Discussions 5
A ISO 14001:2004 Clause 4.4.6 - Operational control (in English) ISO 14001:2015 Specific Discussions 2
D Procedures in Communication, Operational Control, etc. - ISO 14001 Document Control Systems, Procedures, Forms and Templates 12
Q ISO 14001 and Control of Subcontractors - Small engineering company ISO 14001:2015 Specific Discussions 8
A IPPC - Integrated Pollution Prevention and Control and ISO 14001 ISO 14001:2015 Specific Discussions 4
W ISO 14001 SPCC (Spill Prevention, Control and Countermeasure) Miscellaneous Environmental Standards and EMS Related Discussions 6
C ISO 14001 Document and Data Control Corrective Action Request Miscellaneous Environmental Standards and EMS Related Discussions 31
C ISO 14001 Internal Audit - Opportunity for Improvement ISO 14001:2015 Specific Discussions 2
A ISO 14001:2015 clause 4.4 ISO 14001:2015 Specific Discussions 2
A Internal audit plan and processes for ISO 14001:2015 ISO 14001:2015 Specific Discussions 3
Q Audit report template ISO 9001/14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q Process matrix examples of ISO 9001 & 14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C ISO 14001:2015 6.1.3 Compliance Obligations - Legal requirements monitoring ISO 14001:2015 Specific Discussions 0
A Environmental Compliance obligations and risks (ISO 14001:2015 6.1.3) ISO 14001:2015 Specific Discussions 3
Z Auditor Findings ISO 14001:2015 vs. 45001:2015 ISO 14001:2015 Specific Discussions 6
J Audit Checklist for Integrated Management System for ISO 9001:2015, ISO 14001 & OHSAS18001 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
G ISO 14001 - 6.1.3 Compliance Obligations ISO 14001:2015 Specific Discussions 1
A Question on ISO 14001:2015 - Are annual audits required? ISO 14001:2015 Specific Discussions 11
J ISO 14001 revision process ISO 14001:2015 Specific Discussions 1
Raffy ISO 14001 9.2.2 Internal Audit Programme Content Internal Auditing 10
Jacquie Collins 6 Risks and Opportunities ISO 14001:2015 ISO 14001:2015 Specific Discussions 6
M Intention of Planned Arrangments term in ISO 14001 2004 vs 2015 ISO 14001:2015 Specific Discussions 3
S ISO 9001:2015 & ISO 14001 Re-Certification Audit Preparation ISO 14001:2015 Specific Discussions 8
Sidney Vianna Informational ISO 14001 Certificates Top 15 Countries - 1999 to 2017 ISO 14001:2015 Specific Discussions 3
S ISO 9001:2015 & ISO 14001:2015 - I need a format for Design & Development planning ISO 14001:2015 Specific Discussions 2
I Environmental Policy Content - ISO 14001 Clause 5.2 ISO 14001:2015 Specific Discussions 2
Q ISO 14001:2015 accredited but import most product - CB Raised minor NC on Life Cycle Perspective ISO 14001:2015 Specific Discussions 2
Q Internal Auditor competence for ISO 14001 ISO 14001:2015 Specific Discussions 11
S Necessity of Legal Register to conform to ISO 9001, ISO 14001, IATF 16949 ISO 14001:2015 Specific Discussions 6
Q Internal Auditor Training requirements for ISO 14001:2015 ISO 14001:2015 Specific Discussions 5
B Integrated management system - ISO 9001 and ISO 14001 - Is possible to have a joint certificate covering both standards? ISO 14001:2015 Specific Discussions 6
P ISO 14001 - Looking for a Gap Analysis Template ISO 14001:2015 Specific Discussions 3
K ISO 14001:2015 clause 8.1 on outsourced processes ISO 14001:2015 Specific Discussions 1
J Facility Expansion and ISO 14001 ISO 14001:2015 Specific Discussions 1
M PDCA cycle - Process mapping - Environmental ISO 14001 ISO 14001:2015 Specific Discussions 1
A Operating criteria for production processes - ISO 14001 Cl. 8.1 ISO 14001:2015 Specific Discussions 3
Sidney Vianna Support & Guidance Material for ISO 14001:2015 ISO 14001:2015 Specific Discussions 0
C ISO 14001 vs Existing Quality System - How to keep them separate? ISO 14001:2015 Specific Discussions 3
K ISO 14001:2015 certification for two locations required? ISO 14001:2015 Specific Discussions 3
A ISO 14001:2015 transition from the 2004 standard ISO 14001:2015 Specific Discussions 8
Q Risk/Opportunity in a combined ISO 9001 & 14001 System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q Risk & opportunity assessment - ISO 14001 ISO 14001:2015 Specific Discussions 1
Q Correspondence between ISO 14001:2015 & OHSAS 18001:2007 ISO 14001:2015 Specific Discussions 2
R Sequence and Interaction - Combined for both ISO 9001:2015 and EMS 14001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R ISO 14001:2015 Life Cycle Perspective ISO 14001:2015 Specific Discussions 11
R ISO 9001:2015 and EMS 14001:2015 combined audit checklist General Auditing Discussions 5
A ISO 14001:2015 transition audit - Major NC due to the procedure and audit plan ISO 14001:2015 Specific Discussions 10
Q ISO 14001:2015 Clause 6.1: Actions to address Risks & Opportunities ISO 14001:2015 Specific Discussions 2
Sidney Vianna IAF Ruling - No more ISO 9001:2008 nor ISO 14001:2004 audits after 2018-03-15 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A EMS - ISO 14001:2015 Implementation ISO 14001:2015 Specific Discussions 4
