> Oil is controllable to some extent. There are now small
> relatively inexpensive recycling units that organizations
> can place in facilities. Antifreeze can also be recycled
> onsite. There are machines that crush filters to remove
> the fluids also.
I would look closely at onsite distillers with a doubtful eye unless I was working with a very large company. In part because you may 'cleanse' old oil but there are still particulates which you would have to dispose of including heavy metals. All my clients have just paid to have a recycler haul motor oil and antifreeze away. Oil filters they drain (no need to crush) and the residue is acceptable by the regular trash hauler (yes - we double checked).
> Marc, I believe that Randy and I (if I might place words
> in his mouth) were refering to handling waste oil from
> servicing the trucks. We might not be able to control the
> amount of waste generated without endangering our fleet.
> We can however make intelligent choices on what to do with
> the waste generated.
That's what I'm referring to - used motor oil. As far as having a choice about what to do with it, you don't have much choice. You can recycle it yourself or you can have a recycler pick it up. You can't pour it on roads any more to keep the dust down and you aren't allowed to burn it as was once common. What other choice do you have?
> As far as leaks. The control would be to ensure leakage
> was rare and small.
Yup.
> If an oil cooler is blowing oil, then
> the impact would of course change dramatically.
Well, yes. But this would be a rare, catastrophic event which puts us into the hazardous spill mode.
> I think tires would be rather significant.
Yes - tires are in my list. What I have found is - at least my transportation clients so far - all lease tires. So when they get a new tire the company takes the old one. In addition, while tires are an aspect, can you think of a way to control tire wear (other than preventive maintenance like wheel alignment and balance)? Batteries are also leased/exchange.
> In many places storm
> water runoff might even be regulated. Check with the state
> to find out. Michigan has some pretty exact regulations on
> how storm water runoff is to be handled. I'm can't say
> about other states.
In part that's why I listed truck wash water. The same applies to rain (storm) water runoff. There is also the possibility of flooding and runoff water from that (see how well you've taught me?). With my client we evaluated the property surface aqnd determined the slopes and where water runs. Then we verified that the city checks so that we don't - and they do.
Yup - we're on the same wave length. Gee, this is fun! :thedeal:
