ISO 14644-3 - Testing Air for Particle Counts
ISOsandy
Can anyone help me get a copy of ISO14644-3? Any help, advice or anything would be helpful!
We are trying to test air for particle counts... not sure on the testing methods, formula's ect (new to clean rooms) so I am completly lost!! :mg:
Thanks,
Sandy
Marc
You'll probably have to buy a copy because we can't post copyrighted documents such as ISO standards here, but do you have a specific question?
For reference:
ISO 14644, Cleanrooms and associated controlled environments - Part 3: Test Methods
Scope
This part of ISO 14644 specifies test methods for designated classification of airborne particulate cleanliness and for characterizing the performance of cleanrooms and clean zones. Performance tests are specified for two types of cleanrooms and clean zones: those with unidirectional flow and those with non-unidirectional flow, in three possible occupancy states: as-built, at-rest and operational. The test methods recommend test apparatus and test procedures for determining performance parameters. Where the test method is affected by the type of cleanroom or clean zone, alternative procedures are suggested. For some of the tests, several different methods and apparatus are recommended to accommodate different end-use considerations. Alternative methods not included in this part of ISO 14644 may be used if based on agreement between customer and supplier. Alternative methods do not necessarily provide equivalent measurements. This part of ISO 14644 is not applicable to the measurement of products or of processes in cleanrooms or separative devices.
Background
The first meeting of WG 3 was held in 1994 in Tokyo. Initial questions faced by the working group were: what was to be included in the standard and what was to be the structure of the standard. During brainstorming sessions in the first meeting, measurements and tests related to cleanrooms were classified into three categories:
1. Measurement and test methods inherent to cleanrooms.
2. Measurement and test methods often used in cleanroom but not limited to cleanrooms.
3. Measurement and test methods of a general nature.
As cleanrooms include all phases of the engineering sciences, the measurement and test methods related to cleanrooms were numerous. WG 3 was requested by ISO/TC 209 to use the following policy to decide which items to include in the document:
1. If there are any previously established standards on the subject, refer to them.
2. Include items according to the requests or needs of other Working Groups.
The most important objectives of this document are to provide an internationally common basis of measurement and evaluation of cleanrooms and, at the same time, not to prevent the introduction of new technologies. The latter is the reason that the part of this Standard related to instrumentation is Informative. The document was submitted as an American National Standard and has been adopted as ANSI/IEST/ISO 14644-3:2005 in the United States.
ISOsandy
Well, let's see... Like I said, this is all new to me, I have a particle counter and am unsure how to evaluate and take my readings. I also have the microbiological counter... but particle counter first.
We will be a class 100,000 (ISO Class 8) clean room.
I am unsure how to perform the calculations, how many samples to take per area, the sample time/length, and how to interpret it all. I know I need to find the air exchange rates, cubic meters, etc... not sure how to tie it all in and report it correctly.
I hope that made sense... It is Monday and this is driving me batty!
Jen Kirley
Quality and Auditing Expert
ISOsandy, do you have a manual for your particle counter?
If not, I've tried to find them online but I expect you'd have better results by contacting the manufacturer or supplier for a copy. They might also have other materials for you to use. Please take your unit in hand (with its model number and serial number) and call them so you can get direct help that can be imported to work instructions or kept in your files.
If you can give us the make and model number of your tester maybe we can help find your formulas.
ISOsandy
I have the manual, know how to operate the unit. However, how do you perform the calculations? What are the sample sizes (qty of readings taken at each designated area) and how long should the readings be (2 min, 5 min)...
I know I need the exchange rate, however for ISO CLass 8, in given so many cubic meters of area, what is the sample size? Proximity of samples and qty at each location? Testing time? And then finally, calculation?
It is not as simple as take your particle counter, get some readings, and go with it, at least not as far as I have researched so far.
The counter has multiple settings, and you can place it anywhere, take any number of readings. The manual doesn't get into requirements/methods/calcualtions, just how to operate the equipment.
Thanks for the advice though!
Sandy
Jen Kirley
Sandy, I did a Google search using words "procedure particle count clean room class 8" and found these sources for you:
http://www.pmeasuring.com/support/papers/particlemonitoring/pharmaceutical/app41/viewHtml
http://www.particlecounters.org/blog/iso-14644-cleanroom-validating-to-iso-class-8/
http://www1.va.gov/vhapublications/ViewPublication.asp?pub_ID=1455
If my links do not give you what you need, please perform the Google search again (might want to include the term "ISO" in your search words) and open the links until you access the needed process guidance.
I hope this helps!
BradM
Hello!
Have you considered having a contract service come in a perform this? That is their business, and they are usually quite familar with the classifications and the documentation. That may give you a start. This is NOT to suggest that you are not competent, or you can't do your own test. It just sounds like you may be getting down to 'crunch time'. The money spent (given you pick a good certification company) will be well worth it to give you a start. Too, if you are seeking some industry approval, using a reputable certification organization may be a plus.
1. Are you just testing the room for particle classification, or do you have HEPA filters you are also going to test? Filters are another fun ballgame.
2. Did you build your own cleanroom, or did someone build it for you? If someone built it for you, they should have given you some documentation to support the classification.
3. If you built it yourself... NOTE: Without making modifications, the room will be what it is. It may or may not meet your specifications.
As far as the calculations, most of the more current particle counters already have printouts/algorithms to present the criteria for the classifications. As Marc pointed out, you really should purchase the copy of the specification.
Also, particle testing should occur while activity is being conducted in the room, to simulate the actual generation of particles.
Just some thoughts. Good luck, and repost if there are more questions.
ISOsandy
Thanks for all of the information!
The situation is, this company was purchased and moved to Ohio. So we are re-doing everything in the new facility. We have all of the equipment to perform the tests, I am just not familiar with all of this.
I am trying to go back through the old files, SOP's and documents to see exactly what was done prior, but of course it is a mess and the few employees that stayed with the move are not cooperative.:mad:
The company has already made the decision to handle this with our team. We had the room designed and built from a contractor and I am waiting for all of the information on that. Just wanted to get my head straight and on the right path before I really have to get this completed.
We do have the HEPA filters, plus like 4 additional filter types... so it is a bit much.
Thanks again!
Sandy
BradM
Good luck to you!
Please do repost and let us know how your progress goes. It is such a good learning experience to read about the initial challenge, how you dealt with it, lessons learned, etc. It takes great humility to do that, but all benefit from it.
I hope that your particle count readings get you two classes better than what you need!:bigwave:
M ISO 14644 Airborne Particle Count Testing Requirements Miscellaneous Environmental Standards and EMS Related Discussions 6
P ISO 14644 Class 8 Cleanroom Air Filter Requirements Other Medical Device Related Standards 4
Ajit Basrur Why is ISO 14644-3:2019 not approved by US? Other Medical Device Related Standards 1
A Construction of an ISO 8 Clean Room - ISO 14644-1 Manufacturing and Related Processes 2
O Which part of ISO 14644 describe how can I classify cleanrooms between them? Other ISO and International Standards and European Regulations 0
S Cleanrooms - Particle Measuring - ISO 14644 Other Medical Device and Orthopedic Related Topics 3
D What should an ISO 14644 Clean Room PQ (Performance Qualification) look like? Manufacturing and Related Processes 3
N ISO 14644-1 Clean Room Occupancy State Validation Requirements Manufacturing and Related Processes 3
M ISO 14644 - Cleanrooms and associated controlled environments -Recovery Test Other ISO and International Standards and European Regulations 0
V Not using gloves in Clean Room Class 8 (ISO 14644) Manufacturing and Related Processes 21
A Is ISO 14644 harmonized for US? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A ISO 14644 training in Austria, Germany and Switzerland ISO 13485:2016 - Medical Device Quality Management Systems 2
S Why is Microbiological (viable) monitoring not part of ISO 14644 ? Manufacturing and Related Processes 5
W ISO 14644 Cleanroom Validation - "Operational" Other Medical Device Related Standards 3
R ISO 14644-1 maximum particulate concentration limits concern Other ISO and International Standards and European Regulations 2
L ISO 14644 Class 7 Clean Room Requirements Training Presentation Training - Internal, External, Online and Distance Learning 2
J ISO 14644-5 section C3 - ISO Class 7 question Other Medical Device Related Standards 4
V Updated Clean Room Classification Table of ISO 14644 Other ISO and International Standards and European Regulations 2
J ISO 14644 - Monitoring Clean Room Particulates (Class 8 Cleanroom) Other ISO and International Standards and European Regulations 4
L ISO 14644 Result Sheets for Particle monitoring and related monitoring? Other ISO and International Standards and European Regulations 2
S The requirements of an ISO 14644 Class 8 Clean Room Manufacturing and Related Processes 1
R Standard on Clean room - Where can I buy ISO 14644-1 and ISO 14644-4 US Food and Drug Administration (FDA) 3
L Can anyone help me with ISO 14644? Other Medical Device Related Standards 17
I Non-sterile device - Rapid Test Kits - ISO 14644 Clean Room required? ISO 13485:2016 - Medical Device Quality Management Systems 12
I Building a new cleanroom - ISO 14644-3 or ISO 14644-4 ISO 13485:2016 - Medical Device Quality Management Systems 4
Marc Federal Standard 209E Replaced by ISO 14644 Various Other Specifications, Standards, and related Requirements 1
A ISO 14644 - Contamination Control Standards ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Need ISO 15189:2012 Documentation toolkit. Document Control Systems, Procedures, Forms and Templates 0
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 4
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
B ISO 17025:2017 risk management Risk Management Principles and Generic Guidelines 0
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Label Making & Printing Standards ISO / ASTM ISO 13485:2016 - Medical Device Quality Management Systems 5
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Ed Panek ISO 13485:2016 Section 5.5.3 ISO 13485:2016 - Medical Device Quality Management Systems 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
S ISO 2768-mk print call out Other ISO and International Standards and European Regulations 11
T ISO 17024, clauses 4.3.8. and 5.1.1. Other ISO and International Standards and European Regulations 4
C ISO 14001:2015 6.1.3 Compliance Obligations - Legal requirements monitoring ISO 14001:2015 Specific Discussions 0
D ISO 13485 scope (implantable) - Polymers for dental application EU Medical Device Regulations 9
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
John C. Abnet ISO 26262 ISO 26262 - Road vehicles – Functional safety 3
Marc ISO 26262- Road vehicles – Functional safety ISO 26262 - Road vehicles – Functional safety 0
John C. Abnet ISO 26262 IATF 16949 - Automotive Quality Systems Standard 0
A ISO/DIS 15223-1:2020 - Country of manufacture label (IEC 60417 No. 6049) - Which national law requires this symbol? Other Medical Device Related Standards 0
