ISO 14971 becomes mandatory in Brazil - ANVISA Normative Instruction 13/2009
Marcelo
FYI....
Recently ANVISA, the Brazilian medical devices regulatory body, published Normative Instruction 13/2009, which aims to facilitate the medical devices registration process by requiring that less documents be sent to the agency. In the other hand, the document also defines the documentation which needs to be compiled and withheld, and which Anvisa request if needed (and the manufacturer/distributor/etc will have 30 days to show them).
One of the practical changes is that the technical file won´t be sent, unless the device is a new technology or have a new indication for use.
Also, the contents of the technical file are better defined, and they include the risk management file based on ABNT NBR ISO 14971 (the Brazilian versions of ISO 14971).
In practice, as the risk management files details the process implemented based on the whole standard, what it means is that ABNT NBR ISO 14971 is now mandatory in Brazil.
Although i´m always worried whena standard becomes mandatory, i think that´s in this case it will be beneficial...but let´s see what happens.
Michael Malis
FYI....
Marcelo,
I am with you.
ANVISA asked us about Risk Management process and accepted our example. However, what does this mean when they say - this is Mandatory?
Moving forward with the new product development this should be fine.
However, what do they want us to do with the Legacy products?
Regards,
Mike
Marcelo
Mandatory means that manufacturers are obliged to be in conformance with ISo 14971 as a whole. Note that in the past a lot of faulty "risk management processes" were accepted, but now, if Anvisa wishes, she can deny registration due to the manufacturer not comlying with the standard 9also, please note that it´s the WHOLE standard, not only portions of the standard, as some manufacturers are used to use).
Also, with IN 13, there´s no need to forward the design dossier to Anvisa (unles the product is a new tech), but the manufacturer still have to comply with the requirements for the technical dossier, and Anvisa can at any moment request the documentation.
This is for new registrations, but re-registrations will also need to be in compliance (brazil has a 5 year reg period).
P
Paramedic
I have recently seen a form (provided by ANVISA ?) which has to be filled out by the applicant (distributor / manufacturer) to show compliance with ISO14971. Is this correct that such a form exists ? If yes, where can I get it ?
Marcelo
Not that i know. Some people confuses the checklist for essential requirements with what you said (form to show compliance with ISO 14971). maybe that´s the case.
Michael Malis
So the bottom line, for re-registrations we will also need to show compliance...
Correct?
Marcelo
Correct?
That´s what should be expected, but knowing Anvisa, there might be some interpretation on this.
Anyway, this is nothing new, manufacturers always had to implement risk management to show conformance with the essential principles. What is happening now is that it´s explictly required, and also, that a process (the ISO 14971 process) is defined.
recruit
Hi, Marcelo, could you give the link of IN 13/2009? I can not find it by google.
Marcelo
It´s here:
http ://www .anvisa.gov.br/produtosaude/reg/in_13_09.pdf - OBSOLETE BROKEN 404 LINK(s) UNLINKED - PLEASE HELP - REPORT POSTS WITH BROKEN LINKS
P
Paramedic
- So I assume that a Risk Management Report would be sufficient ?
Regarding the IN13:
- Does it only apply for electromedical devices (equipamentos médicos) or for ALL medical devices ?
- IN 13 has in scoope products of risk classes I and II. What about class III and IV products ?
M ISO 14971 Determination of Competent Persons ISO 14971 - Medical Device Risk Management 4
M ISO 14971:2019: Criteria for overall residual risk ISO 14971 - Medical Device Risk Management 6
R Risk control measures as per ISO 14971 ISO 14971 - Medical Device Risk Management 6
B Timeframe for updating QMS / transitioning from ISO 14971:2012 to ISO 14971:2019 ISO 14971 - Medical Device Risk Management 10
D ISO 14971:2019 vs MDR Annex 1, Requirement #4 - "Manufacturers shall inform users of any residual risks" ISO 14971 - Medical Device Risk Management 5
S Practical Implementation of ISO 14971 ISO 14971 - Medical Device Risk Management 6
R Identify Medical Device characterstics as Annex C of ISO 14971 Risk Management ISO 14971 - Medical Device Risk Management 5
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
K Overall residual risk according to ISO 14971:2019 ISO 14971 - Medical Device Risk Management 5
M Gap analysis on ISO 14971:2019 with previous revision ISO 14971 - Medical Device Risk Management 8
Bill Hansen New ISO 14971:2019 Harm: unreasonable psychological stress, and cybersecurity ISO 14971 - Medical Device Risk Management 13
M Risk Analysis Flow - Confusion between ISO 14971 and IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
B ISO 14971 Applied to Software ISO 14971 - Medical Device Risk Management 2
D Recent changes to ISO 14971 - SOP required for managing standard revisions ISO 13485:2016 - Medical Device Quality Management Systems 1
A EN ISO 14971:2019 does not include the Annex Zs ISO 14971 - Medical Device Risk Management 4
J ISO 14971 applied to ISO 13485? Low risk class 1 devices ISO 13485:2016 - Medical Device Quality Management Systems 5
Ronen E Informational What's new in ISO 14971:2019 ISO 14971 - Medical Device Risk Management 2
T ISO 14971-2019 doubt - Evaluate if estimated risks are acceptable ISO 14971 - Medical Device Risk Management 9
A We are ISO 13485:2016 should we be audited to ISO 14971 ISO 13485:2016 - Medical Device Quality Management Systems 16
Y When will Notified Bodies require MedDev manufacturers to fully implement ISO 14971:2019? ISO 14971 - Medical Device Risk Management 1
P Risk acceptability alignment between ISO 14971 and IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 6
S ISO 14971 Risk Management - Questions for Hazard identification ISO 14971 - Medical Device Risk Management 2
M Informational ISO 14971 / ISO TR 24971 revision update – atualizações sobre a revisão Medical Device and FDA Regulations and Standards News 1
R The difference b/w FMEA & Risk analysis as per iso 14971 ISO 14971 - Medical Device Risk Management 8
D Risk management according to ISO 14971 - When to document risk controls? ISO 14971 - Medical Device Risk Management 10
D Where does FMEA fit in your ISO 14971 Risk Management process? ISO 14971 - Medical Device Risk Management 13
Q Information for safety EN ISO 14971:2012 - Customer Risk Reduction ISO 14971 - Medical Device Risk Management 6
M Informational ISO TC 210 JWG 1 meeting in São Paulo – Revision of ISO 14971 and ISO TR 24971 – Medical Device Risk Management Medical Device and FDA Regulations and Standards News 0
A Our auditor requires us to attend a training on EN ISO 14971:2012 Other ISO and International Standards and European Regulations 3
S In a risk analysis, how can we tie mobile app security breach to ISO 14971? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
F IMDRF opened a Consultation on Annex E & F and the link to ISO 14971 ISO 14971 - Medical Device Risk Management 4
M Updates to EN 62366 & ISO 14971? Other Medical Device Related Standards 3
D IEC 60601-1 and ISO 14971 Assessment IEC 60601 - Medical Electrical Equipment Safety Standards Series 25
M Example ISO 14971 policy and risk criteria ISO 14971 - Medical Device Risk Management 0
P ISO 13485 and ISO 14971 - one mandates the other? ISO 13485:2016 - Medical Device Quality Management Systems 8
D Rationale for Risk Acceptability Matrix - ISO 14971 ISO 14971 - Medical Device Risk Management 9
H Task analysis and ISO 14971 ISO 14971 - Medical Device Risk Management 9
M ISO 14971 and Stand-Alone Diagnostic Software ISO 14971 - Medical Device Risk Management 4
dgrainger Benefit - What is the definition of Benefit in ISO 14971? ISO 14971 - Medical Device Risk Management 7
Y Training as a risk control for ISO 14971 ISO 14971 - Medical Device Risk Management 13
W Risk Benefit Analysis - ISO 14971:2012 Requirements ISO 14971 - Medical Device Risk Management 27
thisby_ ISO 14971 - ALARP and P2 - New ISO 14971 does not allow the concept of ALARP? ISO 14971 - Medical Device Risk Management 3
C What is the difference between "Overall Risk" and "Risk"? (ISO 14971) ISO 14971 - Medical Device Risk Management 10
B New EU Medical Device Regulation & Reconciling with EN ISO 14971 EU Medical Device Regulations 41
B IFU and deviation 7 in ISO 14971 Annex ZA ISO 14971 - Medical Device Risk Management 1
B Interpreting Deviations 5 & 6 in Annex ZA in ISO 14971:2012 ISO 14971 - Medical Device Risk Management 1
B Our NB says that IEC 62304 is an ISO 14971 Requirement ISO 14971 - Medical Device Risk Management 1
B Clarification on interpretation of some EN ISO 14971:2012 & IEC 62304:2006 req's ISO 14971 - Medical Device Risk Management 46
H ISO 14971 vs. IEC 62304 vs. 98/79/EC vs. ISO 13485 (Software Medical Device) ISO 14971 - Medical Device Risk Management 1
M ISO 14971 and ISO TR 24971 revision ISO 14971 - Medical Device Risk Management 32
