ISO 17025:2017 Clause 7.4.1 - Requirements for Procedures
fahimk
In ISO 17025:2017 clause 7.4.1 it is written that:
"The laboratory shall have a procedure for the transportation, receipt, handling, protection, storage, retention, and disposal or return of test or calibration items, including all provisions necessary to protect the integrity of the test or calibration item, and to protect the interests of the laboratory and the customer. Precautions shall be taken to avoid deterioration, contamination, loss or damage to the item during handling, transporting, storing/waiting, and preparation for testing or calibration. Handling instructions provided with the item shall be followed."
If i am not wrong, the author is asking for SEVEN (07) different procedures? How can i differentiate between the following terms: transportation, receipt, handling, protection, storage, retention, and disposal or return of test or calibration items?
Thanks and looking forward.
Benjamin Weber
I don't think, the author intended to require seven single procedures. The standard requires, that you have one or if necessary multiple procedures, how to deal with test/calibratoin items.
For example:
- Do you offer any transportation services or do the clients just send their stuff to your lab?
- You may have the rule for visual isnpection for any damages after arrival at your lab or do you always perform functional tests?
- What shall happen, if the item is damaged or non-functional?
- Are there special precautions your lab staff has to know with certain items?
- Where and how are the items stored? Just put them all together in a big box without any markings? Or maybe separate boxes, all marked with the corresponding client/order information?
- Are there special storage conditions (temperature, pressure, humidity...)?
- Do you need to retain samples for possible retesting or evidence later on? Maybe due to other obligations (directives, national laws or regulations....)
- What happens with the test items once the test/calibration is finsihed? Do you send them back to the client? Does the client pick it up at your lab? Do you hand it over personally? Do you throw it all just away?
Depending on how your lab internal rules are, write them down, train your people on the rules and make sure they work accordingly.
Maybe not all of the terms apply to your lab. We never dispose anything of the clients test items. Everything is shipped back to the client after the tests are finished. Hence we don't have disposal covered. (But we have written down, that everything is sent back).
fahimk
I think the following six processes are common to all labs:
transportation (how the lab receives?)
receipt (what between receiving and working on it?
handling (how the item is worked on?...forwarded to a particular section...then they assign workload to xyz...so team work...)
protection (from unauthorized use/ unfriendly environmental conditions?)
storage (so that to keep it for a long timer?)
Only, the retention and disposal sub-parts are optional. Any comments?? Thanks.
For example:
Benjamin Weber
I don't think there are mandatory and optional parts. It just depends on the activities applicable to your lab!
What if your lab doesn't even receive test or calibration items, because you perform testing or calibration on-site at the client or maybe with a mobile lab? Than it would be weir to require a description of EUT reception.
Regarding your comments on the activities:
- Transportation may also apply, if you transport the test or calibration item. For instance, we receive items and some of the tests are performed at other labs. Then we have to take care of the transportation to and from this other lab.
- Storage does not onyl refer to longer periods. If you keep a test or cailbration item in your lab only for one day, you have to have rule for storage.
And I would not call these activities single "processes". I would rather call the combination of these activities a process named "DUT handling" (or similar). But how you structure your QM documentation and how you call different doc-types is totally up to you.
dwperron
An auditor is going to look at your handling processes and will compare them to your written procedure. As in all things 17025, the rigor of your process will depend on your lab's requirements. If you are doing biological or isotope testing your disposal process will be far more rigorous that an calibration lab that wants to dispose of a worn thread plug. Do you need to keep your test items in a specific environment or do you just need to keep them dry and out of the sun?
The auditor is going to be sure that you document how your lab needs to handle the items it normally works with, so that the process stays consistent and is repeatable with different staff members.
B ISO 17025:2017 risk management Risk Management Principles and Generic Guidelines 0
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
R Who is the customer in the ISO/IEC 17025:2017? ISO 17025 related Discussions 1
G ISO 17025-2017 Management Review reporting items - Inputs ISO 17025 related Discussions 1
I Approved Suppliers ISO/IEC 17025:2017 and used test equipment ISO 17025 related Discussions 6
W Issuing reports under ISO 17025:2017 ISO 17025 related Discussions 2
S The (E) in ISO/IEC 17025:2017(E) ISO 17025 related Discussions 3
G ISO 17025:2017 Uninterrupted chain of traceability for test laboratories ISO 17025 related Discussions 6
V IS/ISO/IEC 17025:2017 Clause 4.1 Impartiality ISO 17025 related Discussions 3
F ISO 17025:2017 Clause 7.7 Ensuring the validity of results - Threshold ISO 17025 related Discussions 9
F ISO 17025:2017 Format for Procedure and Records Document Control Systems, Procedures, Forms and Templates 3
F ISO 17025:2017 mandatory documentation requirements ISO 17025 related Discussions 1
C ISO 17025 2017, Requirement 6.6.3 - Communicate requirements to external providers ISO 17025 related Discussions 4
D Risk Assessment Procedure in accordance with ISO 17025:2017 ISO 17025 related Discussions 5
G ISO 17025:2017 7.1.2 - Should I produce a document for the customer? ISO 17025 related Discussions 8
S Can anybody share a sample risk assessment prepared based on ISO 17025:2017? ISO 17025 related Discussions 15
U ISO 17025:2017 Clause 7.7 Ensuring the Validity of Calibration Results ISO 17025 related Discussions 6
Douglas E. Purdy ISO/IEC 17025:2017 3rd Ed. Changes from 2nd Ed. ISO 17025 related Discussions 6
Douglas E. Purdy ISO/IEC 17025:2017 Clause 8 & Annex B ISO 17025 related Discussions 9
D Looking for PowerPoint presentation for ISO 17025:2017 ISO 17025 related Discussions 1
Ajit Basrur Informational ISO/IEC 17025:2017 Published - November 2017 ISO 17025 related Discussions 8
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
X ISO 17025 certification for Laboratory for online gambling products ISO 17025 related Discussions 3
R ISO 17025 - ISO Guides 33 & 80 ISO 17025 related Discussions 1
T ISO 17025: Lockout/Tagout Requirement ISO 17025 related Discussions 1
R ISO 17025 vertical audit checklist wanted Document Control Systems, Procedures, Forms and Templates 2
A ISO 17025 - Methods validation and clients ISO 17025 related Discussions 3
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
C Compliance with ISO 17025 requirement 8.4.2 - Controls - Records recovery ISO 17025 related Discussions 4
S High voltage testing - ISO 17025 - 7.2.2 Validation of methods and 7.3 Sampling ISO 17025 related Discussions 3
S Internal calibrations - Part of an ISO 17025 accredited testing laboratory (Automotive) ISO 17025 related Discussions 16
DuncanGibbons Who are ISO/IEC 17065 and 17025 applicable to? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A ISO 17025 Requirement 6.2 - Department Manager Testing Qualifications ISO 17025 related Discussions 1
F ISO 17025 8.6.2 Customer Feedback Analysis ISO 17025 related Discussions 5
F ISO 17025 8.8 Internal Audits in a segmented company ISO 17025 related Discussions 5
F Faulty Equipment and ISO 17025 General Measurement Device and Calibration Topics 1
F Online courses - Metrology, standardization, calibration and ISO 17025 Training - Internal, External, Online and Distance Learning 3
F Proficiency Testing for ISO 17025: AC Current Ranges ISO 17025 related Discussions 1
F Complying with ISO 17025 by UNIDO ISO 17025 related Discussions 0
F Measurement Audit and ILC for ISO 17025 Clause 7.7.2 - Comparison with results of other laboratories ISO 17025 related Discussions 0
F Linking an ISO 31000 Risk management SOP to ISO 17025 ISO 17025 related Discussions 2
A Validation of Calibration Methods and Traceability - ISO 17025 ISO 17025 related Discussions 3
J ISO 17025 - Please share a sample procedure for monitoring the validity of results ISO 17025 related Discussions 1
G ISO 9001 and ISO 17025 - Measuring tools not in calibration system General Measurement Device and Calibration Topics 3
G From an ISO 17025 auditor perspective must micrometer calibration check anvil flatness? General Measurement Device and Calibration Topics 4
