ISO 17025:2017 Format for Procedure and Records
fahimk
Hello.
ISO 17025:2017 demands various procedures and records. Apart from the footer and header, which need to be customized, what is the recommended format for 'procedure' and 'record'? Normally, procedures need to be in a standard step-by-step form. And, what about the record? Should it be like a list of date and action(s) form?
Any samples?
Benjamin Weber
A procedure may be a process, standard operation procedure or similar. For process descriptions there are several different types of fomrat. You can either describe every step of the process in text one step after the other. Or you can use a flow chart type. In a process it should be clear what is the input and what are the steps to reach the output. Additionally the responsibilities should be clearly described. This starts wiht the responsible person who takes care that the process is being followed and ends with a clear description, who is repsonsible for each process step. It might also be helpful to add other stakeholders, for example who is informed about certain process steps. I personally like the swimlane diagram a lot, because you can easily see, who has to do what and how the relations between different process are.
A process might reference more detailled descriptions, often called standard operation procedure. This may be the description how a certain test or calibration procedure is actually performed. You could look at this like some kind of operation manual for specific tasks. Sometime these can be quite straight forward, sometimes they can be very complicated, depending on the complexity of the procedure they are describing.
The format of records should be individually adapted to the application. I don't think it is possible to prepare such a generic report template. A record may be a checklist that is filled in always before a certain test or calibration is performed. But also a management system review report or an internal audit report is such a record. A signed NDA may be such a record. A calibration certificate of your test equipment may be a record. The records should enable you to show the auditor, that you work according to your procedures.
Marc
Just to add... There is a difference between a requirement for a "documented procedure" and a "procedure" when a requirement is stated in a standard. There are "undocumented procedures".
This is old (circa 1999), but things haven't changed. See: Marc Timothy Smith - Accolades
--> help. You're advice was extremely important. Especially important,
--> at least in my opinion, was your help in determining where we did
--> not need to document every last thing (by using training, etc.). I
--> think that without this input, we would have spent a lot more time
--> writing things that we did not need and wasted a lot of peoples'
--> time. We were able to get the audit done in a year while we are
--> achieving record sales and profits.
John Broomfield
fahimk,
Firstly, your system documents are designed for use by competent employees and should not try to compensate for any lack of competence. Competence comes from recruiting and training; reading procedures not so much!
You need only document to the extent necessary for your system to be effective. Over documentation may lead to as much ineffectiveness as under documenting so you are seeking a balance or optimum (per the process owner’s assessment of risk).
The format of data collection devices (aka forms) and documented procedures and instructions is whatever works effectively for your lab. Please note that some forms can also be instructions.
I recommend that you take the user direct to the action by putting all the document control stuff (in a standardized place) at the bottom or on the last page.
What users find useful is to know is what to expect when their process (or task within a process) is effective. So, at the top of each documented procedure or instruction, just under its title, define the objective of the process (or task) that is specified by that procedure (or instruction).
Those tasks we do only occasionally may need documentation especially designed and posted specifically for that situation such as operating an item of rarely operated equipment or an emergency exit sign.
Best wishes,
John
B ISO 17025:2017 risk management Risk Management Principles and Generic Guidelines 0
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
R Who is the customer in the ISO/IEC 17025:2017? ISO 17025 related Discussions 1
G ISO 17025-2017 Management Review reporting items - Inputs ISO 17025 related Discussions 1
I Approved Suppliers ISO/IEC 17025:2017 and used test equipment ISO 17025 related Discussions 6
W Issuing reports under ISO 17025:2017 ISO 17025 related Discussions 2
S The (E) in ISO/IEC 17025:2017(E) ISO 17025 related Discussions 3
G ISO 17025:2017 Uninterrupted chain of traceability for test laboratories ISO 17025 related Discussions 6
V IS/ISO/IEC 17025:2017 Clause 4.1 Impartiality ISO 17025 related Discussions 3
F ISO 17025:2017 Clause 7.7 Ensuring the validity of results - Threshold ISO 17025 related Discussions 9
F ISO 17025:2017 Clause 7.4.1 - Requirements for Procedures ISO 17025 related Discussions 4
F ISO 17025:2017 mandatory documentation requirements ISO 17025 related Discussions 1
C ISO 17025 2017, Requirement 6.6.3 - Communicate requirements to external providers ISO 17025 related Discussions 4
D Risk Assessment Procedure in accordance with ISO 17025:2017 ISO 17025 related Discussions 5
G ISO 17025:2017 7.1.2 - Should I produce a document for the customer? ISO 17025 related Discussions 8
S Can anybody share a sample risk assessment prepared based on ISO 17025:2017? ISO 17025 related Discussions 15
U ISO 17025:2017 Clause 7.7 Ensuring the Validity of Calibration Results ISO 17025 related Discussions 6
Douglas E. Purdy ISO/IEC 17025:2017 3rd Ed. Changes from 2nd Ed. ISO 17025 related Discussions 6
Douglas E. Purdy ISO/IEC 17025:2017 Clause 8 & Annex B ISO 17025 related Discussions 9
D Looking for PowerPoint presentation for ISO 17025:2017 ISO 17025 related Discussions 1
Ajit Basrur Informational ISO/IEC 17025:2017 Published - November 2017 ISO 17025 related Discussions 8
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
X ISO 17025 certification for Laboratory for online gambling products ISO 17025 related Discussions 3
R ISO 17025 - ISO Guides 33 & 80 ISO 17025 related Discussions 1
T ISO 17025: Lockout/Tagout Requirement ISO 17025 related Discussions 1
R ISO 17025 vertical audit checklist wanted Document Control Systems, Procedures, Forms and Templates 2
A ISO 17025 - Methods validation and clients ISO 17025 related Discussions 3
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
C Compliance with ISO 17025 requirement 8.4.2 - Controls - Records recovery ISO 17025 related Discussions 4
S High voltage testing - ISO 17025 - 7.2.2 Validation of methods and 7.3 Sampling ISO 17025 related Discussions 3
S Internal calibrations - Part of an ISO 17025 accredited testing laboratory (Automotive) ISO 17025 related Discussions 16
DuncanGibbons Who are ISO/IEC 17065 and 17025 applicable to? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A ISO 17025 Requirement 6.2 - Department Manager Testing Qualifications ISO 17025 related Discussions 1
F ISO 17025 8.6.2 Customer Feedback Analysis ISO 17025 related Discussions 5
F ISO 17025 8.8 Internal Audits in a segmented company ISO 17025 related Discussions 5
F Faulty Equipment and ISO 17025 General Measurement Device and Calibration Topics 1
F Online courses - Metrology, standardization, calibration and ISO 17025 Training - Internal, External, Online and Distance Learning 3
F Proficiency Testing for ISO 17025: AC Current Ranges ISO 17025 related Discussions 1
F Complying with ISO 17025 by UNIDO ISO 17025 related Discussions 0
F Measurement Audit and ILC for ISO 17025 Clause 7.7.2 - Comparison with results of other laboratories ISO 17025 related Discussions 0
F Linking an ISO 31000 Risk management SOP to ISO 17025 ISO 17025 related Discussions 2
A Validation of Calibration Methods and Traceability - ISO 17025 ISO 17025 related Discussions 3
J ISO 17025 - Please share a sample procedure for monitoring the validity of results ISO 17025 related Discussions 1
G ISO 9001 and ISO 17025 - Measuring tools not in calibration system General Measurement Device and Calibration Topics 3
G From an ISO 17025 auditor perspective must micrometer calibration check anvil flatness? General Measurement Device and Calibration Topics 4
