ISO 17025:2017 mandatory documentation requirements
fahimk
Dear Fellows:
I got confused after giving the ISO 17025:2017 document a quick look. Can anybody give me an idea about the documentation requirements of ISO 17025:2017 )? Is it that one is required to prepare a separate document (policy/procedure/form etc) to address each of the 130 (or perhaps more) clauses? Is it mandatory to furnish all documentation stated in SAC's checklist (google 'LAFM03_ISO 17025-2017 Chklist')?
I understand that documentation has to be customized to a particular Calibration Laboratory. But, for an idea, is there sample list of document to be prepared? Any additional information will be much appreciated.
Thanks and looking forward. Cheers!
Benjamin Weber
Dear Fellows:
Of course you don't need one separate document for each single requirement. But using the checklist you should be able to find the implementation of each single requirement somewhere in your documentation. Here is aonther thread that might help:
My company is looking to start a materials testing lab that conforms to ISO17025:2017
Usually you find one major document, where you describe the way how you are fulfilling major requirement. This is called the quality management handbook (though it is not formally required any longer to have this QMH, it is a well proven tool). Such requirements might be for example commitments such as to impartiality. And handbook is really a good description. Ideally this is the first document a new staff member gets to read, in order to know, how your lab works.
These general descriptions of your work are usually supported by more detailled process descriptions that are referred to in the QMH, for example how to perform management system review or how to handle calibration of your own equipment. And there may be an additional more detailled level of standard operation procedures which are refered to in the QMH or in the process descriptions, for example instructions how to perform a certain calibration or test in detail. Additionally you may also need different forms, which you use to generate your records (e.g. management system review records, personell qualification records, equipment calibration records, checklists used during a calibration/test...). These records are essentially the only way an auditor can check, if you follow your own rules (commitments, processes and maybe standard operation procedures)! Keep that in mind: An auditor wants to see, that your QMS enables you to meet the 17025 requirements and that you actually work according to your own rules!
The SAC checklist hepls you a lot, by not just citing the requirements. But is also gives you advice, how to implement!
Important: The structure described above is only one possible way of implementation. There are as many different structures as there are test and calibration labs. You have to find a structure, that fits your situation regarding structure of staff and their qualification, your infrastructure, your customers...
P Filled in F48/F49 for internal audit ISO 17025:2017 Internal Auditing 1
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
R Who is the customer in the ISO/IEC 17025:2017? ISO 17025 related Discussions 1
G ISO 17025-2017 Management Review reporting items - Inputs ISO 17025 related Discussions 1
I Approved Suppliers ISO/IEC 17025:2017 and used test equipment ISO 17025 related Discussions 6
W Issuing reports under ISO 17025:2017 ISO 17025 related Discussions 2
S The (E) in ISO/IEC 17025:2017(E) ISO 17025 related Discussions 3
G ISO 17025:2017 Uninterrupted chain of traceability for test laboratories ISO 17025 related Discussions 6
V IS/ISO/IEC 17025:2017 Clause 4.1 Impartiality ISO 17025 related Discussions 3
F ISO 17025:2017 Clause 7.7 Ensuring the validity of results - Threshold ISO 17025 related Discussions 9
F ISO 17025:2017 Format for Procedure and Records Document Control Systems, Procedures, Forms and Templates 3
F ISO 17025:2017 Clause 7.4.1 - Requirements for Procedures ISO 17025 related Discussions 4
C ISO 17025 2017, Requirement 6.6.3 - Communicate requirements to external providers ISO 17025 related Discussions 4
D Risk Assessment Procedure in accordance with ISO 17025:2017 ISO 17025 related Discussions 5
G ISO 17025:2017 7.1.2 - Should I produce a document for the customer? ISO 17025 related Discussions 8
S Can anybody share a sample risk assessment prepared based on ISO 17025:2017? ISO 17025 related Discussions 15
U ISO 17025:2017 Clause 7.7 Ensuring the Validity of Calibration Results ISO 17025 related Discussions 6
Douglas E. Purdy ISO/IEC 17025:2017 3rd Ed. Changes from 2nd Ed. ISO 17025 related Discussions 6
Douglas E. Purdy ISO/IEC 17025:2017 Clause 8 & Annex B ISO 17025 related Discussions 9
D Looking for PowerPoint presentation for ISO 17025:2017 ISO 17025 related Discussions 1
Ajit Basrur Informational ISO/IEC 17025:2017 Published - November 2017 ISO 17025 related Discussions 8
W What is okay to use as a reference material for ISO 17025? ISO 17025 related Discussions 2
AllTheThings ISO-17025 accredited TEST lab performing internal calibrations (Yes: Here is how) ISO 17025 related Discussions 6
D Question on Documented Calibration versus ISO 17025 Accredited Calibration ISO 13485:2016 - Medical Device Quality Management Systems 2
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
X ISO 17025 certification for Laboratory for online gambling products ISO 17025 related Discussions 3
R ISO 17025 - ISO Guides 33 & 80 ISO 17025 related Discussions 1
T ISO 17025: Lockout/Tagout Requirement ISO 17025 related Discussions 1
R ISO 17025 vertical audit checklist wanted Document Control Systems, Procedures, Forms and Templates 2
A ISO 17025 - Methods validation and clients ISO 17025 related Discussions 3
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
C Compliance with ISO 17025 requirement 8.4.2 - Controls - Records recovery ISO 17025 related Discussions 4
S High voltage testing - ISO 17025 - 7.2.2 Validation of methods and 7.3 Sampling ISO 17025 related Discussions 3
S Internal calibrations - Part of an ISO 17025 accredited testing laboratory (Automotive) ISO 17025 related Discussions 16
DuncanGibbons Who are ISO/IEC 17065 and 17025 applicable to? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A ISO 17025 Requirement 6.2 - Department Manager Testing Qualifications ISO 17025 related Discussions 1
F ISO 17025 8.6.2 Customer Feedback Analysis ISO 17025 related Discussions 5
F ISO 17025 8.8 Internal Audits in a segmented company ISO 17025 related Discussions 5
F Faulty Equipment and ISO 17025 General Measurement Device and Calibration Topics 1
F Online courses - Metrology, standardization, calibration and ISO 17025 Training - Internal, External, Online and Distance Learning 3
F Proficiency Testing for ISO 17025: AC Current Ranges ISO 17025 related Discussions 1
F Complying with ISO 17025 by UNIDO ISO 17025 related Discussions 0
F Measurement Audit and ILC for ISO 17025 Clause 7.7.2 - Comparison with results of other laboratories ISO 17025 related Discussions 0
F Linking an ISO 31000 Risk management SOP to ISO 17025 ISO 17025 related Discussions 2
A Validation of Calibration Methods and Traceability - ISO 17025 ISO 17025 related Discussions 3
J ISO 17025 - Please share a sample procedure for monitoring the validity of results ISO 17025 related Discussions 1
