ISO 17025 8.6.2 Customer Feedback Analysis
fahimk
Hello Friends,
The Clause 8.6.2 of ISO 17025:2017 states:
"the laboratory shall seek feedback, both positive and negative, from its customers. The feedback shall be analysed and used to improve the management system, laboratory activities and customer service."
What can be the recommended options to analyse customer feedback? Analysis is easy when the survey is conducted online but we are using offline paper options..
Thanks in advance...
Please create a format & share with customer to fill as per your survice (attached our form), Check the comment, sub suggestion for improvement. Later make proper action plan with target date & responsibility. Now after evaluation for certain period of time, please submit customer satisfaction form to same customer & get their feedback. Kindly follow like it with customer until you achieve 100% target.
Gus
well if you MUST, use paper media, then you are stuck with having your QA delegate (or whoever you appoint to do so, preferably an impartial party) capture the data onto any media (digital or physical) where you can perform such analysis, this is why most lab's would rather use digital surveys whenever possible.
anyways positive and negative actual comments will help a lot, in my opinion its easier to take on a specific negative comment and improve your system with it, than to perform statistical analysis, pinpoint an issue and "then" improve your system, i guess it depends on the volume of feedback you get and the type of data that you are retrieving from it
optomist1
A Sea of Statistics
Have used a well constructed voice of the customer survey (Survey Monkey is good), At start mid-way and upon completion of services to gauge our/your performance....urge you to use a 1-10 Likert scale to enable better analysis of custoemr feedback. This is a good start, and must be refined as the VOC process progresses. Also is usefull to provide customer a space for verbal comment at end of survey.....
Gus
if you want to use a somewhat more private tool i have found that forms.office.com is a great tool, just in case your organization has that office package, it even gives you a summary for your results.
i have sucessfully used it inside our company with our internal customers but i have read that it can also be sent to external customers even if they dont have "forms"
Tallinec
Hello Friends,
I think, that 99% of your customers have no interest in participation in your survey. They do not see strong (!) correlation between participation in your survey and improvement of your lab service in future. So, make your survey as short and simple as possible. Some questions on one side of a list is enough. I recommend that customers's answers to the questions shall be done in quality points used in schools of your country.
Examples:
1)How do you estimate time of delivery of our lab's reports? Cross the options: A+,A, B, C, D, F, where "A+" is excellent; "A" is ...
2)How do you estimate politeness of our lab's techniсians? Cross the options: A+,A, B, C, D, F, where "A+" is excellent; "A" is ...
3)How do you estimate accuracy of content of our lab's reports? Cross the options: A+,A, B, C, D, F, where "A+" is excellent; "A" is ...
4)How do you estimate time of our lab's response to you urgent orders placed after 05.00 p.m. and in weekends? Cross the options: A+,A, B, C, D, F, where "A+" is excellent; "A" is ...
5)How do you estimate conversational English language knowledge of our lab's techniсians? Cross the options: A+,A, B, C, D, F, where "A+" is excellent; "A" is ...
R Who is the customer in the ISO/IEC 17025:2017? ISO 17025 related Discussions 1
G ISO 17025:2017 7.1.2 - Should I produce a document for the customer? ISO 17025 related Discussions 8
K Customer Address on ISO 17025 Test Report - Is email address okay? ISO 17025 related Discussions 9
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
B ISO 17025:2017 risk management Risk Management Principles and Generic Guidelines 0
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
X ISO 17025 certification for Laboratory for online gambling products ISO 17025 related Discussions 3
R ISO 17025 - ISO Guides 33 & 80 ISO 17025 related Discussions 1
T ISO 17025: Lockout/Tagout Requirement ISO 17025 related Discussions 1
R ISO 17025 vertical audit checklist wanted Document Control Systems, Procedures, Forms and Templates 2
A ISO 17025 - Methods validation and clients ISO 17025 related Discussions 3
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
C Compliance with ISO 17025 requirement 8.4.2 - Controls - Records recovery ISO 17025 related Discussions 4
G ISO 17025-2017 Management Review reporting items - Inputs ISO 17025 related Discussions 1
S High voltage testing - ISO 17025 - 7.2.2 Validation of methods and 7.3 Sampling ISO 17025 related Discussions 3
S Internal calibrations - Part of an ISO 17025 accredited testing laboratory (Automotive) ISO 17025 related Discussions 16
I Approved Suppliers ISO/IEC 17025:2017 and used test equipment ISO 17025 related Discussions 6
W Issuing reports under ISO 17025:2017 ISO 17025 related Discussions 2
S The (E) in ISO/IEC 17025:2017(E) ISO 17025 related Discussions 3
G ISO 17025:2017 Uninterrupted chain of traceability for test laboratories ISO 17025 related Discussions 6
DuncanGibbons Who are ISO/IEC 17065 and 17025 applicable to? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
V IS/ISO/IEC 17025:2017 Clause 4.1 Impartiality ISO 17025 related Discussions 3
F ISO 17025:2017 Clause 7.7 Ensuring the validity of results - Threshold ISO 17025 related Discussions 9
A ISO 17025 Requirement 6.2 - Department Manager Testing Qualifications ISO 17025 related Discussions 1
F ISO 17025 8.8 Internal Audits in a segmented company ISO 17025 related Discussions 5
F Faulty Equipment and ISO 17025 General Measurement Device and Calibration Topics 1
F Online courses - Metrology, standardization, calibration and ISO 17025 Training - Internal, External, Online and Distance Learning 3
F Proficiency Testing for ISO 17025: AC Current Ranges ISO 17025 related Discussions 1
F ISO 17025:2017 Format for Procedure and Records Document Control Systems, Procedures, Forms and Templates 3
F ISO 17025:2017 Clause 7.4.1 - Requirements for Procedures ISO 17025 related Discussions 4
F Complying with ISO 17025 by UNIDO ISO 17025 related Discussions 0
F Measurement Audit and ILC for ISO 17025 Clause 7.7.2 - Comparison with results of other laboratories ISO 17025 related Discussions 0
F ISO 17025:2017 mandatory documentation requirements ISO 17025 related Discussions 1
F Linking an ISO 31000 Risk management SOP to ISO 17025 ISO 17025 related Discussions 2
C ISO 17025 2017, Requirement 6.6.3 - Communicate requirements to external providers ISO 17025 related Discussions 4
D Risk Assessment Procedure in accordance with ISO 17025:2017 ISO 17025 related Discussions 5
A Validation of Calibration Methods and Traceability - ISO 17025 ISO 17025 related Discussions 3
J ISO 17025 - Please share a sample procedure for monitoring the validity of results ISO 17025 related Discussions 1
G ISO 9001 and ISO 17025 - Measuring tools not in calibration system General Measurement Device and Calibration Topics 3
S Can anybody share a sample risk assessment prepared based on ISO 17025:2017? ISO 17025 related Discussions 15
U ISO 17025:2017 Clause 7.7 Ensuring the Validity of Calibration Results ISO 17025 related Discussions 6
G From an ISO 17025 auditor perspective must micrometer calibration check anvil flatness? General Measurement Device and Calibration Topics 4
S ISO 17025 Requirements for Mobile On-site Calibration ISO 17025 related Discussions 2
C Must your reference standard provider be ISO17034 certified to meet your testing lab's ISO 17025 certification requirements? Other ISO and International Standards and European Regulations 2
S The procedure for replicate check in calibration lab as per ISO 17025 General Measurement Device and Calibration Topics 2
