ISO 17025 External Calibration Laboratory Requirements within ISO/TS 16949
N
ntrprizxile
#11
Dave, for you to be TS16949 compliant, the calibration house must be ISO17025 accredited (or national equivalent) for all work you have them perform for you (7.6.3.2). The lab scope must include the capability they perform for you. So if you have them calibrate a multimeter, capability to measure voltage, current, and resistance within the ranges required must be on the lab scope.
The one exception is if your customer (who requires you to be TS) has approved the service provider.
If you are not TS, then ISO17025 is not required.
justdavew32
#12
The company is ISI 17025 accredited for the test carried out and it IS on their scope. My MNC was for them supplying an ISO9001 cert.
TS says:- - there shall be evidence that the external laboratory is accpetable to the customer or
- the laboratory shall be accredited to ISO/IEC 17025 or national equivalent.
My interpritation of this is the company has to be accredited to do the test. It does not however say that it has to be a 17025 test.
Thanks,
#13
Thanks,
I think you asked a variation of this question in another thread. I surmise from your question that the calibration house gave you a choice between accredited and non-accredited services. This is common these days. If this is correct and you chose non-accredited service, your calibration results are not valid for TS16949 purposes because the calibration provider won't stipulate that the calibration was carried out under conditions compliant with ISO 17025.
qusys
#14
Thanks,
Could you please write the exact statement of the non conformity and the related violeted clause?
I am assuming that this was a non conformity from a registrar audit vs ISO TS.
We are waiting for additional details , because, based upon what you said I did not understand well or prabably it is not a non conformity vs ISO TS standard.:bigwave:
justdavew32
#15
MNC Below.
The management of calibration of weigh scales has not been effective.
The requirement (standard clause or procedural reference) not followed:
TS 16949:2009 clause no. 7.6, 7.5.2 and/or Company system reference number
Objective evidence observed that supports the statement of nonconformity:
Potting process weigh scales have not been calibrated by a UKAS/17025 accredited system.
The company is accredited to 17025 and this test is on their scope of testing.
qusys
#16
MNC Below.
I do not know.
I think the violeted clause should have been 7.6.3.2 if you are using an external service.
I did not understand why this is a ncn if this calibration service company is 17025 certified and measurement
Fell in their scope, as you stated.
Did they provide you a certificate of calibration with the accuracy, measurement, reference standard attesting they are ISO 17025 certified? Which kind of evidence did not satisfy the auditor?
I would tend to agree with Jim in the previous post.
Pls, give us other details describing the situation during the audit.:bigwave:
#17
MNC Below.
Do you have a calibration certificate that says that the calibration was carried out under accredited conditions? If not, the NC is probably valid. It doesn't matter if the calibration provider is accredited if your company made a choice to have non-accredited service performed. See my previous response.
justdavew32
#18
So we are saying that every calibration must be an ISO/17025 calibration? Our disagreement with this NC is that the item calibrated does not affect the goodness of the product( the auditor agrees with that) however the auditor says that because we say it should be calibrated it must be an ISO/17025 calibration. We used an accredited lab but got the reduced service.
#19
It sounds to me like the auditor is correct, and you're suffering from a self-inflicted wound. If there really is no need to have the scale(s) calibrated (which is a different discussion) you should remove the requirement from your system and be mindful of the fact that if you do have something calibrated with an outside service, and the calibration is relevant to TS16949 requirements, the calibration must be of the accredited variety.
qusys
#20
Agree with Jim.
Some additional questions: which kind of tool is it? what is your usage?
Do you other situations like this that could jeopardize your calibration system?
Bottom line, I do not understand yet the reduce service you have from this supplier. If they are ISO 17025 certified, they shoul follow the procedure to give you the right service and not reduced service of which I do not undestand the differences.:bigwave:
C ISO 17025 2017, Requirement 6.6.3 - Communicate requirements to external providers ISO 17025 related Discussions 4
S What is the ISO 17025 Certified Laboratory Requirement for External Calibration? ISO 17025 related Discussions 8
T ISO 17025 - 4.1.5b Internal/External commercial, financial, and other pressures ISO 17025 related Discussions 3
J ISO/IEC 17025 - Which External Documents require control? ISO 17025 related Discussions 6
L Acceptable use of a non accredited external ISO/IEC 17025 laboratory ISO 17025 related Discussions 5
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
B ISO 17025:2017 risk management Risk Management Principles and Generic Guidelines 0
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
X ISO 17025 certification for Laboratory for online gambling products ISO 17025 related Discussions 3
R ISO 17025 - ISO Guides 33 & 80 ISO 17025 related Discussions 1
T ISO 17025: Lockout/Tagout Requirement ISO 17025 related Discussions 1
R ISO 17025 vertical audit checklist wanted Document Control Systems, Procedures, Forms and Templates 2
A ISO 17025 - Methods validation and clients ISO 17025 related Discussions 3
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
R Who is the customer in the ISO/IEC 17025:2017? ISO 17025 related Discussions 1
C Compliance with ISO 17025 requirement 8.4.2 - Controls - Records recovery ISO 17025 related Discussions 4
G ISO 17025-2017 Management Review reporting items - Inputs ISO 17025 related Discussions 1
S High voltage testing - ISO 17025 - 7.2.2 Validation of methods and 7.3 Sampling ISO 17025 related Discussions 3
S Internal calibrations - Part of an ISO 17025 accredited testing laboratory (Automotive) ISO 17025 related Discussions 16
I Approved Suppliers ISO/IEC 17025:2017 and used test equipment ISO 17025 related Discussions 6
W Issuing reports under ISO 17025:2017 ISO 17025 related Discussions 2
S The (E) in ISO/IEC 17025:2017(E) ISO 17025 related Discussions 3
G ISO 17025:2017 Uninterrupted chain of traceability for test laboratories ISO 17025 related Discussions 6
DuncanGibbons Who are ISO/IEC 17065 and 17025 applicable to? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
V IS/ISO/IEC 17025:2017 Clause 4.1 Impartiality ISO 17025 related Discussions 3
F ISO 17025:2017 Clause 7.7 Ensuring the validity of results - Threshold ISO 17025 related Discussions 9
A ISO 17025 Requirement 6.2 - Department Manager Testing Qualifications ISO 17025 related Discussions 1
F ISO 17025 8.6.2 Customer Feedback Analysis ISO 17025 related Discussions 5
F ISO 17025 8.8 Internal Audits in a segmented company ISO 17025 related Discussions 5
F Faulty Equipment and ISO 17025 General Measurement Device and Calibration Topics 1
F Online courses - Metrology, standardization, calibration and ISO 17025 Training - Internal, External, Online and Distance Learning 3
F Proficiency Testing for ISO 17025: AC Current Ranges ISO 17025 related Discussions 1
F ISO 17025:2017 Format for Procedure and Records Document Control Systems, Procedures, Forms and Templates 3
F ISO 17025:2017 Clause 7.4.1 - Requirements for Procedures ISO 17025 related Discussions 4
F Complying with ISO 17025 by UNIDO ISO 17025 related Discussions 0
F Measurement Audit and ILC for ISO 17025 Clause 7.7.2 - Comparison with results of other laboratories ISO 17025 related Discussions 0
F ISO 17025:2017 mandatory documentation requirements ISO 17025 related Discussions 1
F Linking an ISO 31000 Risk management SOP to ISO 17025 ISO 17025 related Discussions 2
D Risk Assessment Procedure in accordance with ISO 17025:2017 ISO 17025 related Discussions 5
A Validation of Calibration Methods and Traceability - ISO 17025 ISO 17025 related Discussions 3
J ISO 17025 - Please share a sample procedure for monitoring the validity of results ISO 17025 related Discussions 1
G ISO 17025:2017 7.1.2 - Should I produce a document for the customer? ISO 17025 related Discussions 8
G ISO 9001 and ISO 17025 - Measuring tools not in calibration system General Measurement Device and Calibration Topics 3
S Can anybody share a sample risk assessment prepared based on ISO 17025:2017? ISO 17025 related Discussions 15
U ISO 17025:2017 Clause 7.7 Ensuring the Validity of Calibration Results ISO 17025 related Discussions 6
