ISO 17025 External Calibration Laboratory Requirements within ISO/TS 16949
#21
Agree with Jim.
Some additional questions: which kind of tool is it? what is your usage?
Do you other situations like this that could jeopardize your calibration system?
Bottom line, I do not understand yet the reduce service you have from this supplier. If they are ISO 17025 certified, they shoul follow the procedure to give you the right service and not reduced service of which I do not undestand the differences.:bigwave:
Unfortunately, it's common practice in the US for accredited calibration services to provide two different types of certificates--one that attests to the calibration being performed in accordance with ISO 17025, and for a lesser price, a certificate that does not. It doesn't necessarily mean that the calibration itself is performed any differently, or is inherently less reliable.
qusys
#22
Ok, I did not know.
It seems if an organization chooses this looks like to make an own goal, offering the side to a non conformity as it happened.
It confirms that the cost saving never means earning!:(
Hershal
Metrologist-Auditor
#23
Jim is correct, and the levels of certificate may not be limited to two. Each level of certificate comes in such instances with additional cost. However, if you do not have the traceability path and uncertainty you do not have traceability and that may be the heart of the non-conformance.
BradM
#24
:agree1:
Although... I have seen a few instances where a calibration provider has multiple sites. They will have the "low cost" calibrations performed at the non-accredited site. They then run this site with significantly lower training and documentation costs, and sometimes, less trained (and thus, less expensive) personnel.
howste
Thaumaturge
#25
:agree1:
I believe that the key is whether they did the calibration at an accredited site using the process that is accredited. The company is apparently accredited to ISO 17025, and their scope includes the calibration that was performed. However, if the calibration was performed at another site that isn't accredited, then it's a nonconformity. If the lab followed a different process to calibrate than they would for an accredited certificate, then it's a nonconformity. If the calibration was done at an accredited site with the same procedure that's accredited, and the calibration record contains all that's required in TS 16949 clause 7.6.2, then I don't see a problem.
#26
How can we determine objectively if the calibration was performed "using the process that is accredited" if the lab doesn't provide a certificate to that effect? The whole idea of the two-tier certificate thing is that evidence of accredited calibration is being held for ransom, and the lab won't certify to using an accredited process unless you pay for it.
qusys
#27
Agree with Jim.
We asked to justdavew32 in many posts if his organization showed some evidence such as the calibration certification, but we did not clear response.
The risk is also that the organziation could have lots of situation like the one where they took the non conformity.:bigwave:
LUV-d-4UM
#28
We had the same nonconformity because the external calibrator did not have our instrument being calibrated in their scope of calibration. Apparently ISO17025 certified calibrators must have the specific equipment calibrated listedin the scope.
BradM
#29
:agree1::yes:
Absolutely. Their scope defines what they have demonstrated proficiency doing.
Imagine you have some pressure devices in your facility. You send it to a lab that has : 0-150 PSIG in their scope. However, you have a differential room pressure gauge (0-2 Inches W.C.)
While it is still pressure, the low pressure range encompasses a fairly different set of test equipment and processes, whereas an uncertainty analysis may not have been performed. And... how much training/ experience does that technician have calibrating low pressure equipment?
So, when they return a "Fail" as the as-found, one might be left wondering if the device failed solely on it's own error, or if the process contributed significantly to the error.
C ISO 17025 2017, Requirement 6.6.3 - Communicate requirements to external providers ISO 17025 related Discussions 4
S What is the ISO 17025 Certified Laboratory Requirement for External Calibration? ISO 17025 related Discussions 8
T ISO 17025 - 4.1.5b Internal/External commercial, financial, and other pressures ISO 17025 related Discussions 3
J ISO/IEC 17025 - Which External Documents require control? ISO 17025 related Discussions 6
L Acceptable use of a non accredited external ISO/IEC 17025 laboratory ISO 17025 related Discussions 5
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
B ISO 17025:2017 risk management Risk Management Principles and Generic Guidelines 0
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
X ISO 17025 certification for Laboratory for online gambling products ISO 17025 related Discussions 3
R ISO 17025 - ISO Guides 33 & 80 ISO 17025 related Discussions 1
T ISO 17025: Lockout/Tagout Requirement ISO 17025 related Discussions 1
R ISO 17025 vertical audit checklist wanted Document Control Systems, Procedures, Forms and Templates 2
A ISO 17025 - Methods validation and clients ISO 17025 related Discussions 3
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
R Who is the customer in the ISO/IEC 17025:2017? ISO 17025 related Discussions 1
C Compliance with ISO 17025 requirement 8.4.2 - Controls - Records recovery ISO 17025 related Discussions 4
G ISO 17025-2017 Management Review reporting items - Inputs ISO 17025 related Discussions 1
S High voltage testing - ISO 17025 - 7.2.2 Validation of methods and 7.3 Sampling ISO 17025 related Discussions 3
S Internal calibrations - Part of an ISO 17025 accredited testing laboratory (Automotive) ISO 17025 related Discussions 16
I Approved Suppliers ISO/IEC 17025:2017 and used test equipment ISO 17025 related Discussions 6
W Issuing reports under ISO 17025:2017 ISO 17025 related Discussions 2
S The (E) in ISO/IEC 17025:2017(E) ISO 17025 related Discussions 3
G ISO 17025:2017 Uninterrupted chain of traceability for test laboratories ISO 17025 related Discussions 6
DuncanGibbons Who are ISO/IEC 17065 and 17025 applicable to? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
V IS/ISO/IEC 17025:2017 Clause 4.1 Impartiality ISO 17025 related Discussions 3
F ISO 17025:2017 Clause 7.7 Ensuring the validity of results - Threshold ISO 17025 related Discussions 9
A ISO 17025 Requirement 6.2 - Department Manager Testing Qualifications ISO 17025 related Discussions 1
F ISO 17025 8.6.2 Customer Feedback Analysis ISO 17025 related Discussions 5
F ISO 17025 8.8 Internal Audits in a segmented company ISO 17025 related Discussions 5
F Faulty Equipment and ISO 17025 General Measurement Device and Calibration Topics 1
F Online courses - Metrology, standardization, calibration and ISO 17025 Training - Internal, External, Online and Distance Learning 3
F Proficiency Testing for ISO 17025: AC Current Ranges ISO 17025 related Discussions 1
F ISO 17025:2017 Format for Procedure and Records Document Control Systems, Procedures, Forms and Templates 3
F ISO 17025:2017 Clause 7.4.1 - Requirements for Procedures ISO 17025 related Discussions 4
F Complying with ISO 17025 by UNIDO ISO 17025 related Discussions 0
F Measurement Audit and ILC for ISO 17025 Clause 7.7.2 - Comparison with results of other laboratories ISO 17025 related Discussions 0
F ISO 17025:2017 mandatory documentation requirements ISO 17025 related Discussions 1
F Linking an ISO 31000 Risk management SOP to ISO 17025 ISO 17025 related Discussions 2
D Risk Assessment Procedure in accordance with ISO 17025:2017 ISO 17025 related Discussions 5
A Validation of Calibration Methods and Traceability - ISO 17025 ISO 17025 related Discussions 3
J ISO 17025 - Please share a sample procedure for monitoring the validity of results ISO 17025 related Discussions 1
G ISO 17025:2017 7.1.2 - Should I produce a document for the customer? ISO 17025 related Discussions 8
G ISO 9001 and ISO 17025 - Measuring tools not in calibration system General Measurement Device and Calibration Topics 3
S Can anybody share a sample risk assessment prepared based on ISO 17025:2017? ISO 17025 related Discussions 15
U ISO 17025:2017 Clause 7.7 Ensuring the Validity of Calibration Results ISO 17025 related Discussions 6
