ISO 17025 or A2LA, what?s this??
W
Walle
ISO 17025 or A2LA, what´s this??
I need help!!!!!!
In which cases should the quality lab be certificated on ISO 17025??? And when by the A2LA? ??? what's the difference?
MIL GRACIAS
Walle said:
I need help!!!!!!
MIL GRACIAS
ISO 17025 is an international standard; A2LA is an accreditiation source. A2LA can confirm that a lab meets the standard and issue accreditiation credentials to that effect.
Craig H.
Walle:
If you look at the bottom of this page there is a list of related threads, including one where I asked a very similar question a few years ago.
Oh, and JSW correctly confirms the answer I got in my thread. No surprise there.
Hershal
Metrologist-Auditor
Walle said:
I need help!!!!!!
MIL GRACIAS
Each lab needs to determine if it requires accreditation under ISO/IEC 17025, and in many cases it may.....if a testing or calibration, almost certainly.
A2LA is one of six, I repeat, six accrediting bodies currently recognized in North America. The six are: IAS, NVLAP, SCC/CLAS, L-A-B, A2LA, and ACLASS.
Since you are in Mexico, I recommend contacting EMA, the Mexican accrediting body. Unless you have a pressing reason to use one of the other six, then EMA is likely your best option.
Hope this helps.
Hershal
Hershal
Metrologist-Auditor
Oh, one last note.....if you have a pressing reason to use one of the six recognized accrediting bodies outside Mexico, then talk to ALL SIX.....not just to A2LA.
Hershal
G A2LA's ISO/IEC 17025 and Accreditation Training - Opinions from previous attendees ISO 17025 related Discussions 2
QMMike TS 16949 - A2LA or ISO/IEC 17025 required for material testing? ISO 17025 related Discussions 6
O When do we need to be A2LA/ISO 17025 certified? ISO 17025 related Discussions 6
gard2372 A2LA & ISO/IEC 17025:1999 vs. European Requirements ISO 17025 related Discussions 7
V Is A2LA the US National equivalent to ISO 17025? ISO 17025 related Discussions 9
Q Seeking: A2LA to ISO 17025 Audit Template ISO 17025 related Discussions 2
C Differences and similarities between ISO 17025 and A2LA certification? ISO 17025 related Discussions 2
Marc APLAC - A2LA - ISO/IEC Guide 43-1 (1997) - 17025 - Laboratory Proficiency Testing ISO 17025 related Discussions 0
G ISO 17025.2017 Clause 7.8.4.3 Certificate of Calibration Label ISO 17025 related Discussions 5
GStough ISO 17025 Lead Auditor Training - Punyam Academy ISO 17025 related Discussions 6
K ISO 17025 Query Relating to Monitoring of Equipment ISO 17025 related Discussions 3
A Help required in establishing Laboratory Information Management System as per ISO 17025, Cl.7.11.2 ISO 17025 related Discussions 0
R Do I need to get calibration certificate from ISO 17025 for IATF Audit IATF 16949 - Automotive Quality Systems Standard 8
V ISO 17025 Accreditation Consulting Needed ISO 17025 related Discussions 1
D Is Good Laboratory Practice (GLP) Required in ISO 17025? ISO 17025 related Discussions 4
W Looking for IATF 16949 (and ISO 17025) QMS software Suggestions Quality Tools, Improvement and Analysis 8
R Process Maps for ISO 17025 ISO 17025 related Discussions 2
K ISO 17025 Method Validation and Verification for Test Lab ISO 17025 related Discussions 5
R ISO 17025 Lead Assessor Training ISO 17025 related Discussions 0
J ISO 17025 Calibration Other Medical Device Related Standards 2
E ISO 17025 Key Performance Indicators (KPIs) ISO 17025 related Discussions 5
R Basic Lab Practices - related to ISO 17025 testing labs ISO 17025 related Discussions 1
D Training for ISO 17025 ISO 17025 related Discussions 2
D How to handle suppliers that are not ISO 17025 certified ISO 17025 related Discussions 5
J What risk to cover when NOT using ISO 17025 accredited/certified labs for calibration ISO 17025 related Discussions 3
Quality Specialist Quick question on the sequence of ISO 17025 external audits ISO 17025 related Discussions 14
K ISO 17025 Facilities and environmental conditions SOP ISO 17025 related Discussions 6
M ISO 17025:2017 Clause 6.4 - Measuring Equipment Validity ISO 17025 related Discussions 2
B ISO 17025:2017 Clause 7.1.3 - Decision Rule ISO 17025 related Discussions 2
E Organisational Chart-ISO 17025 Laboratory ISO 17025 related Discussions 3
Casana ISO 17025 - Contractor certification? IATF 16949 - Automotive Quality Systems Standard 5
B Sanctioned interpretation #10 - ISO 17025 IATF 16949 - Automotive Quality Systems Standard 2
G Compliance with ISO 9001-2015 for ISO 17025 Accredited Labs? ISO 17025 related Discussions 8
D Management reviews ISO 17025 ISO 17025 related Discussions 3
I ISO 17025:2017 / ANAB 3125 - Articulating / Communicating Risks vis-a-vis Audit Findings ISO 17025 related Discussions 2
W What is okay to use as a reference material for ISO 17025? ISO 17025 related Discussions 4
AllTheThings ISO-17025 accredited TEST lab performing internal calibrations (Yes: Here is how) ISO 17025 related Discussions 8
P Filled in F48/F49 for internal audit ISO 17025:2017 Internal Auditing 2
D Question on Documented Calibration versus ISO 17025 Accredited Calibration ISO 13485:2016 - Medical Device Quality Management Systems 2
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
X ISO 17025 certification for Laboratory for online gambling products ISO 17025 related Discussions 3
R ISO 17025 - ISO Guides 33 & 80 ISO 17025 related Discussions 1
T ISO 17025: Lockout/Tagout Requirement ISO 17025 related Discussions 4
R ISO 17025 vertical audit checklist wanted Document Control Systems, Procedures, Forms and Templates 2
A ISO 17025 - Methods validation and clients ISO 17025 related Discussions 3
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
R Who is the customer in the ISO/IEC 17025:2017? ISO 17025 related Discussions 1
C Compliance with ISO 17025 requirement 8.4.2 - Controls - Records recovery ISO 17025 related Discussions 4
