ISO 17025 Quality Manual - How elaborate does the quality manual have to be?
shawnann
I'm going to post this here because we are in the process of getting ISO 17025 certified, but I guess the question could go for any certifications that require a quality manual.
We all know that a quality manual is required, as it states in the instructions for the application for accreditation that you need to "Create and implement a Quality Manual and Management System policies and procedures that meet the ISO/IEC 17025:2005 and A2LA requirements."
So my question is, how elaborate does the quality manual have to be? When we got our ISO 9001 certification, we for the most part typed word for word the international standard, with the exception of creating a couple pages at the beginning and this was acceptable. We were also told we could combine the quality manual to our procedures manual and eliminate the part of the quality manual that was word for word of the international standard. Can we just create those "extra pages" and use the international standard (as is) as our quality manual? This would save a lot of time typing something that is already in print and paper that really isn't needed to be printed on.
In other words, create a quality policy (or quality pages), that lists the scope of the laboratory/company, the organizational overview-mission (who we are, etc) and then refer to the international standard for the actual quality manual.
Coury Ferguson
Moderator here to help
Re: Quality Manual
We all know that a quality manual is required, as it states in the instructions for the application for accreditation that you need to "Create and implement a Quality Manual and Managment System policies and procedures that meet the ISO/IEC 17025:2005 and A2LA requirements."
So my question is, how elaborate does the quality manual have to be? When we got our ISO 9001 certification, we for the most part typed word for word the international standard, with the exception of creating a couple pages at the beginning and this was exceptable. We were also told we could combine the quality manual to our procedures manual and eliminate the part of the quality manual that was word for word of the international standard. Can we just create those "extra pages" and use the international stadard (as is) as our quality manual? This would save a lot of time typing something that is already in print and paper that really isn't needed to be printed on.
Does your current manual meet the requirement of 17025? That is what you need to be concerned about.
It appears that you have all the necessary information an established Quality Manual and System.
I am not an expert in the 17025 Standard. So I maybe way of base.
Q
qualityboi
First of all your certification body did not do you justice if you merely parroted the Standard. Your quality manual should describe your company's quality system. Some companies write their quality manual to show how their quality system meets the standard, key word is "how", but that, in my opinion, is a less mature way of documenting the quality system as it is aimed more at passing an audit than describing what the company does. The intent of the standard is to set minimum requirements for a quality system or in your case laboratory and aid in the path of continual improvement resulting in greater customer satisfaction. The intent of the manual is to describe the system so managment and personnel have a common understanding of how the company works. Then they have a baseline to improve upon.
That's an interesting question! It has to be as elaborate as your lab operations demand it to be!
Please, please don't do what you did for ISO 9001! All you've done is please a third party CB auditor. Copying the standard word for word is a recipe for a useless document that your management will never use and, as a result, no one else will. Besides, no-one speaks that 'ISO language' in there. (Oh, BTW - you don't get 17025 registered or certified, it's accredited - a simple but important difference).
Shawann - there are loads of posts around here about the contents of manuals. It's not a stretch to do a good one for 17025. It's not so different. The lab std gives you some ideas as to what might be in there - like an org. chart which shows the lab related to the 'parent' company. Also, who's the QM and the deputies of the lab tech mgr etc. ALso, work in those specific accreditation Body 'tweaks' they prefer, like the correction of data, when there's an error (double cross through, in ink, initialed, etc.)
But, please don't just do that old, waste of time, cut and paste the standard cr*p - your A2LA assessor might not accept it anyways.....
Hershal
Metrologist-Auditor
There are two things going on here based on the original post.....
First, the ANS/ISO/IEC 17025:2005 requirements, and second the requirements for the chosen AB.....
Your manual needs to address both.....needs to address them in terms of what you ACTUALLY do TODAY.....
Now, the manual may not need to be elaborate if the AB accepts that.....
But almost certainly can't simply be a regurgatation of the Standard.....
Hope this helps......
P
Peter West
Do you use your manual? That is to say do you actually intend to be a company who achieve certification/accreditation (subject to the ISO) with the full intent of using what they have learnt and discovered to improve business/operations?
No offence intended but i sort of get the feeling that the efforts are for the external surveillance only, in which case work efficiency would dictate you do the bare minimum to achieve the ISO and then continue as you always did (I question this - especially do not endorse this approach).
If you are not going to reap any operational benefits of gaining this ISO (i.e. improvement in procedures) is it worth getting it???
T ISO 17025 Section 5.9.1 - Assuring Quality of Tests - Requirements ISO 17025 related Discussions 4
M Quality Manual - ISO 17025 required Mandatory and Operational Procedures ISO 17025 related Discussions 7
R ISO 17025 sufficient enough to drop ISO 10005 Quality Plan? ISO 17025 related Discussions 1
S ISO 17025 Quality Manual Preparation ISO 17025 related Discussions 7
suildur Assuring the Quality of Test and Calibration Results - ISO IEC 17025 Clause 5.9 ISO 17025 related Discussions 13
R ISO 17025 section 4.2.2 and Quality Policy Content ISO 17025 related Discussions 4
R ISO 17025 .pdf Example Quality Manual Attached ISO 17025 related Discussions 3
V Seeking ISO 17025 accreditation - How necessary are Quality Control activities? ISO 17025 related Discussions 7
J Quality Manual for an ISO 17025 Chemical Laboratory ISO 17025 related Discussions 3
A ISO 17025 Aligned Quality Manual Examples ISO 17025 related Discussions 1
L Integrated Quality System Manual for ISO 9001 - ISO 17025 ISO 17025 related Discussions 7
P ISO 9001:2000 and ISO 17025 combined Quality Manual needed ISO 17025 related Discussions 9
Ajit Basrur Quality Manual and Audit Checklist for ISO 17025 ISO 17025 related Discussions 1
D Should the average everday Quality Control Manager need a copy of ISO 17025? ISO 17025 related Discussions 5
A Do we need to revise our Quality Policy for ISO/IEC 17025:2005? ISO 17025 related Discussions 2
E Quality Calibration Procedures - Frequency of equipment calibration - ISO 17025 ISO 17025 related Discussions 11
L ISO 17025 Implementation & Quality Manual HELP!! ISO 17025 related Discussions 17
K ISO 17025 Quality Manual and 58 page Checklist - And how many procedures do I need? ISO 17025 related Discussions 5
B RAB/IRCA accredited course for ISO-17025 Quality System Lead Assessor ISO 17025 related Discussions 7
L ISO 17025 - Seeking Example Quality Manual ISO 17025 related Discussions 6
M Example ISO 17025 Quality Manual wanted ISO 17025 related Discussions 17
Marc Quality Manual for ISO 9001 & ISO 17025 ISO 17025 related Discussions 15
R Basic Lab Practices - related to ISO 17025 testing labs ISO 17025 related Discussions 1
D Training for ISO 17025 ISO 17025 related Discussions 2
D How to handle suppliers that are not ISO 17025 certified ISO 17025 related Discussions 5
J What risk to cover when NOT using ISO 17025 accredited/certified labs for calibration ISO 17025 related Discussions 3
Q Quick question on the sequence of ISO 17025 external audits ISO 17025 related Discussions 14
K ISO 17025 Facilities and environmental conditions SOP ISO 17025 related Discussions 6
M ISO 17025:2017 Clause 6.4 - Measuring Equipment Validity ISO 17025 related Discussions 2
B ISO 17025:2017 Clause 7.1.3 - Decision Rule ISO 17025 related Discussions 2
E Organisational Chart-ISO 17025 Laboratory ISO 17025 related Discussions 3
Casana ISO 17025 - Contractor certification? IATF 16949 - Automotive Quality Systems Standard 5
B Sanctioned interpretation #10 - ISO 17025 IATF 16949 - Automotive Quality Systems Standard 2
G Compliance with ISO 9001-2015 for ISO 17025 Accredited Labs? ISO 17025 related Discussions 5
D Management reviews ISO 17025 ISO 17025 related Discussions 3
I ISO 17025:2017 / ANAB 3125 - Articulating / Communicating Risks vis-a-vis Audit Findings ISO 17025 related Discussions 2
W What is okay to use as a reference material for ISO 17025? ISO 17025 related Discussions 4
AllTheThings ISO-17025 accredited TEST lab performing internal calibrations (Yes: Here is how) ISO 17025 related Discussions 8
P Filled in F48/F49 for internal audit ISO 17025:2017 Internal Auditing 2
D Question on Documented Calibration versus ISO 17025 Accredited Calibration ISO 13485:2016 - Medical Device Quality Management Systems 2
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
X ISO 17025 certification for Laboratory for online gambling products ISO 17025 related Discussions 3
R ISO 17025 - ISO Guides 33 & 80 ISO 17025 related Discussions 1
T ISO 17025: Lockout/Tagout Requirement ISO 17025 related Discussions 2
R ISO 17025 vertical audit checklist wanted Document Control Systems, Procedures, Forms and Templates 2
A ISO 17025 - Methods validation and clients ISO 17025 related Discussions 3
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
R Who is the customer in the ISO/IEC 17025:2017? ISO 17025 related Discussions 1
