ISO 17025 - Required Procedures and Records
I'm guessing, Ajit, this is one of those things that people have to do, just by reading the standard and highlighting every time it says 'procedure' and 'record'. A pain, I know.
Ajit Basrur
Thanks Andy but was wondering if any one has prepared the list similar to the one we have for ISO 9001, ISO 13485 etc. :tg:
Would save the pain :)
Hershal
Metrologist-Auditor
To my knowledge, no list of that type is prepared, but where the Standard says policy or Procedure, then it is required.
Additionally, there are a number of places where that is not specifically stated as a requirements but really strongly implied.....
Also, many ABs require that everything in the Standard be addressed in the Quality Manual, even if it does not apply, in which case a statement to that effect and why is acceptable.....
And watch for the records that are required.....that is pretty much anything in the Standard.....
Hope this helps.
Q
qualityboi
I'll bite, I am in an auditor class as I write this. This is instructor supplied by an accrediting body who I will not name. Note the documents list is long, and it does not mean that a separate document is needed for each clause just that the particular part of the standard requires a document reference.
I want to piggy back of the OP. 17025 requires a lot of procedures. My question is do they have to be documented? I know ISO 9001 tells you when they have to be documented. But i am not sure about ISO 17025.
Hershal
Metrologist-Auditor
Clauses 4.2 and 4.3 require a documented system. Sometimes that can be easily accomplished in the quality manual, sometimes not. That depends a lot on the size of the lab. Go for the simplest solution that meets all the requirements. That is an application of Occam's Razor to ISO/IEC 17025.
Acchi Larka
Friends I'm really confused - ISO 17025. I have a PE certified push test stand for rollover protective structures used on Agriculture & Construction equipment. I want to sell this service. I'm not calibrating things...I'm breaking things. Also, I do not have a laboratory for this "monster sized" device. Its in a building and portable. I don't know how to apply all of the requirements of ISO 17025 to this. I know this is a hugely general question but any suggestions on how to approach this toward regsitration to 17025? Do I even need ISO registration? is the fact that the test stand is approved by a professional engineer good enough? Can help or not....thanks anyway! Acchi Larka
Hello Acchi,
Do any of your customers require ISO17025 to conduct business with them?
Do you wish to have ISO17025 compliance to sell your business?
Wayne Is a Manufacturer's Certification good enough or is ISO 17025 Certification required ISO 17025 related Discussions 8
M Is ISO 17025 accreditation required under 21 CFR 820? ISO 17025 related Discussions 6
M Quality Manual - ISO 17025 required Mandatory and Operational Procedures ISO 17025 related Discussions 7
T Required ISO 17025 Traceability - The specific ID/SS number of the test weight ISO 17025 related Discussions 6
M ISO 17025 - Recommended or Required and other Calibration questions ISO 17025 related Discussions 5
QMMike TS 16949 - A2LA or ISO/IEC 17025 required for material testing? ISO 17025 related Discussions 6
S ISO 17025 Required for Specialty Testing House? ISO 17025 related Discussions 11
B Is Measurement Uncertainty required for a captive lab according to ISO 17025 ISO 17025 related Discussions 1
M ISO 17025 Certification required by which standards? ISO 17025 related Discussions 13
J Issuing Authority on Forms - Required? ISO 17025 Clause 4.3.2.3 ISO 17025 related Discussions 2
K Is formal Internal Auditor training required for ISO 17025:2004 - Clause 4.14.1 ISO 17025 related Discussions 5
D Alignment to ISO/IEC 17025 as required by TS 16949 ISO 17025 related Discussions 5
D ISO/IEC 17025 required for a calibration lab to be ISO certified? ISO 17025 related Discussions 6
D Who is required to hold ISO 17025 accreditation? ISO 17025 related Discussions 2
D Who is required to comply with Guide 25 / ISO 17025 - Multi-feature variable gaging ISO 17025 related Discussions 3
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
B ISO 17025:2017 risk management Risk Management Principles and Generic Guidelines 0
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
X ISO 17025 certification for Laboratory for online gambling products ISO 17025 related Discussions 3
R ISO 17025 - ISO Guides 33 & 80 ISO 17025 related Discussions 1
T ISO 17025: Lockout/Tagout Requirement ISO 17025 related Discussions 1
R ISO 17025 vertical audit checklist wanted Document Control Systems, Procedures, Forms and Templates 2
A ISO 17025 - Methods validation and clients ISO 17025 related Discussions 3
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
R Who is the customer in the ISO/IEC 17025:2017? ISO 17025 related Discussions 1
C Compliance with ISO 17025 requirement 8.4.2 - Controls - Records recovery ISO 17025 related Discussions 4
G ISO 17025-2017 Management Review reporting items - Inputs ISO 17025 related Discussions 1
S High voltage testing - ISO 17025 - 7.2.2 Validation of methods and 7.3 Sampling ISO 17025 related Discussions 3
S Internal calibrations - Part of an ISO 17025 accredited testing laboratory (Automotive) ISO 17025 related Discussions 16
I Approved Suppliers ISO/IEC 17025:2017 and used test equipment ISO 17025 related Discussions 6
W Issuing reports under ISO 17025:2017 ISO 17025 related Discussions 2
S The (E) in ISO/IEC 17025:2017(E) ISO 17025 related Discussions 3
G ISO 17025:2017 Uninterrupted chain of traceability for test laboratories ISO 17025 related Discussions 6
DuncanGibbons Who are ISO/IEC 17065 and 17025 applicable to? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
V IS/ISO/IEC 17025:2017 Clause 4.1 Impartiality ISO 17025 related Discussions 3
F ISO 17025:2017 Clause 7.7 Ensuring the validity of results - Threshold ISO 17025 related Discussions 9
A ISO 17025 Requirement 6.2 - Department Manager Testing Qualifications ISO 17025 related Discussions 1
F ISO 17025 8.6.2 Customer Feedback Analysis ISO 17025 related Discussions 5
F ISO 17025 8.8 Internal Audits in a segmented company ISO 17025 related Discussions 5
F Faulty Equipment and ISO 17025 General Measurement Device and Calibration Topics 1
F Online courses - Metrology, standardization, calibration and ISO 17025 Training - Internal, External, Online and Distance Learning 3
F Proficiency Testing for ISO 17025: AC Current Ranges ISO 17025 related Discussions 1
F ISO 17025:2017 Format for Procedure and Records Document Control Systems, Procedures, Forms and Templates 3
F ISO 17025:2017 Clause 7.4.1 - Requirements for Procedures ISO 17025 related Discussions 4
F Complying with ISO 17025 by UNIDO ISO 17025 related Discussions 0
F Measurement Audit and ILC for ISO 17025 Clause 7.7.2 - Comparison with results of other laboratories ISO 17025 related Discussions 0
F ISO 17025:2017 mandatory documentation requirements ISO 17025 related Discussions 1
