ISO 22000 combined with ISO 9001 - Implement both or only one of them?
blueicecube
#51
Re: ISO 22000 combined with ISO 9001 - Do both or only 1 of the two?
I am quite overwhelmed knowing there are THAT many standards around in food. Alas, food is a basic necessesity, hence its not surprising that so is the case.
In addition to JaneB reply, I would also like to add : ISO training/information are more spread throughout the world and so does their certification body. Not to mention, lack of expertise in certain region of the world to do so....
Improvement oh improvement, I call upon you.. ;-)
F
frawat
#52
I'd still contend that ISO Standards are far more widely understood and known than the rest.
I really like ISO standards and try to use them as much as possible. However, my perception is that, in the food industry, customers (or buyers) value most more detailed standards, like BRC, etc. In fact, these standards are usually an essential requirement while ISO standards may be rather optional. Maybe this could change. But the trend is to have more and more integrated standards (comprising both management and more technical requirements), so gradually all are getting more similar.
Of course ISO 22000 is sort of another thing because it tackles just food safety. Also, by itself is not enough. Not only because of other quality issues, but because if your company is not too experienced or young, there is no detailed guidance to implement pre-requisite programs, etc.
tsmith7858
#53
The ISO 22000 standard is fairly new compared to many of the others. Most of the others were developed because there was a lack of a food safety standard and each country or company started to create their own. That means each country/company has a tie to it and therefore thinks what they have is the best.
Once you sort through them as Jane suggests you will start to see common threads.
Best bet is to put in a solid Food Safety System and forget about names.
The different names are just a way for CBs to make more money... :2cents:
Sidney Vianna
Post Responsibly
#54
Keep in mind that the CB's are not responsible for the myriad of competing standards and schemes. CB's provide a way for organizations that have to demonstrate conformity to a standard.
Actually, the diversity of food safety related standards and the associated auditor qualification requirements make it for a very difficult and costly auditor competence management process.
If the Food & Beverage Sector could coalesce around an universal set of Food Safety Standards, which would also be endorsed by regulatory bodies, we would all benefit.
JaneB
#55
You took the words right out of my mouth!
Let's not assign blame where it doesn't belong, but lay the responsibility at the feet of those it belongs to: all the different organisations and bodies and associations that each decided they needed their own special standard / system/ scheme, whatever! And that's notthe CBs!
As Sidney says, it's difficult and costly for the various CBs to deal with, also. THere's a good reason why having a single jointly agreed Standard (eg, ISO) faciliates a whole lot of things.
Amen to that. :applause:
Tony C
#56
Our quality management system is based on an ISO 9001:2000, however some of upper management have decided to look into becoming ISO 22000 certified since we store frozen food. Can I implement both system together, or do I abandon the 9001 program, if not the I would assume that one quality manual would be able to cover both standards. Please advise
Of the food safety standards available ISO 22000 will be the easiest to integrate into your current management system. ISO 22000 is a little weak in the area of prerequisite requirements. For peace of mind and in order develop a comprehensive system you should consider prerequisites requirements from other sources such as CODEX/PAS220 etc.
Regards,
Tony
Sidney Vianna
Post Responsibly
#57
Isn't that exactly what FSSC 22000 aims at?
Tony C
#58
It is but I was answering Damon's question and would suggest a bit OTT for frozen food storage.
From the FSSC website:
The Foundation developed FSSC 22000, the ISO 22000 and PAS 220 based certification scheme for certification of food manufacturers.
Regards,
Tony
JaneB
#59
Yes, me too. My preference would be for ISO 22000 (because it's a good management system standard, and as you say, good to integrate), and then consider other more detailed requirements as well, & if necessary.
mliburd
#60
We are currently implementing ISO 22000. 22000 covers most of ISO 9001 but not all requirements. So you will still need to maintain both as individual systems.
I ISO 22000:2018 - Operational Prerequisite Program Examples Food Safety - ISO 22000, HACCP (21 CFR 120) 2
E ISO TC 34 and ISO 22000:2018 Gap Analysis and the principles of Codex Alimentarius Food Safety - ISO 22000, HACCP (21 CFR 120) 1
B Approaches to Documenting an ISO 22000 FSMA Food Safety - ISO 22000, HACCP (21 CFR 120) 3
R Still confused on OPRP and CCP in an ISO 22000 Catering Business Food Safety - ISO 22000, HACCP (21 CFR 120) 3
C What is the best ISO 22000 template pack to purchase? Food Safety - ISO 22000, HACCP (21 CFR 120) 2
E ISO 22000 new release in 2016? Food Safety - ISO 22000, HACCP (21 CFR 120) 1
M ISO 22000 7.3.5.2 Description of Process Steps and Control Measures Food Safety - ISO 22000, HACCP (21 CFR 120) 1
0 Standard that is the equivalent to ISO 22000 but for the non-food industry Food Safety - ISO 22000, HACCP (21 CFR 120) 7
Q Implementing ISO 9001 and ISO 22000 systems at the same time Document Control Systems, Procedures, Forms and Templates 2
F ISO 22000 Disadvantages - Student Exam Question Food Safety - ISO 22000, HACCP (21 CFR 120) 4
R ISO 22000:2005 Clause 7.10.4 Withdrawal - Applicability and documentation required? Food Safety - ISO 22000, HACCP (21 CFR 120) 3
T Food Safety Manual for ISO 22000:2005 - Please critique Food Safety - ISO 22000, HACCP (21 CFR 120) 2
C Consultancy for ISO 22000 Career and Occupation Discussions 4
M HACCP vs. ISO 22000 Documented Procedure requirements Food Safety - ISO 22000, HACCP (21 CFR 120) 1
F ISO 22000 Clause 7.4.4 to determine whether a control is a CCP or and OPRP Food Safety - ISO 22000, HACCP (21 CFR 120) 2
C ISO 22000 Stage 1 NC's - PRPs not approved and Objectives not inline with Policy Food Safety - ISO 22000, HACCP (21 CFR 120) 3
D Food Services Hygiene - ISO 22000 Certificate or HACCP Certificate Food Safety - ISO 22000, HACCP (21 CFR 120) 1
D Implement ISO 22000 or E-Cristal System. Food Safety - ISO 22000, HACCP (21 CFR 120) 2
P CCP Monitoring Sheet/Record in ISO 22000 Food Safety - ISO 22000, HACCP (21 CFR 120) 3
P ISO 22000 and ISO 9001:2008 Manual and Procedures Integration Food Safety - ISO 22000, HACCP (21 CFR 120) 9
P ISO 22000 Documentation Requirements Food Safety - ISO 22000, HACCP (21 CFR 120) 8
P Flower Packing House Certification for ISO 22000 Food Safety - ISO 22000, HACCP (21 CFR 120) 4
C Continual Improvement in the context of ISO 22000:2005 Preventive Action and Continuous Improvement 2
P Is it necessary to consider ISO 22002-1 for the implementation of ISO 22000 Food Safety - ISO 22000, HACCP (21 CFR 120) 3
P What is Validation, Verification and Improvement of FSMS in ISO 22000 Clause 8? Food Safety - ISO 22000, HACCP (21 CFR 120) 2
S ISO 22000 Lead Auditor (IRCA registration) General Auditing Discussions 7
D Auditing ISO 22000 - 8.4.3 Records of analysis by Food Safety Team Food Safety - ISO 22000, HACCP (21 CFR 120) 4
Moncia Supplier Audit Requirements for ISO 22000 - Is a schedule required? Food Safety - ISO 22000, HACCP (21 CFR 120) 5
J ISO 22000 Food Contact Materials Issue and Requirements Food Safety - ISO 22000, HACCP (21 CFR 120) 1
K Why folks prefer ISO 22000 instead of BRC or SQF? Food Safety - ISO 22000, HACCP (21 CFR 120) 9
S OPRP in ISO 22000 vs. CP in BRC - Food Food Safety - ISO 22000, HACCP (21 CFR 120) 6
K Can tobacco companies be certified against HACCP/ISO 22000? Food Safety - ISO 22000, HACCP (21 CFR 120) 12
S Lead Auditor ISO 22000:2005 Example Exam Questions Food Safety - ISO 22000, HACCP (21 CFR 120) 3
G Question about OPRP and PRP with regards to HACCP and ISO 22000 Food Safety - ISO 22000, HACCP (21 CFR 120) 4
M ISO 22000 - HACCP plan for ingredients like Egg Powder, Strawberry Flavour and Butter Food Safety - ISO 22000, HACCP (21 CFR 120) 2
J ISO 22000, PAS 220 and HACCP Combination. Food Safety - ISO 22000, HACCP (21 CFR 120) 10
M Emergency Preparedness for Bioterrorism in a Catering Business (ISO 22000 Audit) Food Safety - ISO 22000, HACCP (21 CFR 120) 11
M Integrating ISO 22000 and ISO 9001 - Food Safety Presentation for ISO Conference Food Safety - ISO 22000, HACCP (21 CFR 120) 1
6 Description of Outsourced Processes in ISO 22000 Manual Food Safety - ISO 22000, HACCP (21 CFR 120) 4
K Nonconforming Products in the context of ISO 22000 Food Safety - ISO 22000, HACCP (21 CFR 120) 6
K Does ISO 22000 make sense for a Custom Injection Molder? Food Safety - ISO 22000, HACCP (21 CFR 120) 7
K Is it a requirement of ISO 9001 or ISO 22000 that a document is reviewed? Food Safety - ISO 22000, HACCP (21 CFR 120) 9
K When should validation be carried out in the context of ISO 22000? Food Safety - ISO 22000, HACCP (21 CFR 120) 2
K Compliance with ISO 22000 Clauses 8.4.2 and 8.4.3 Food Safety - ISO 22000, HACCP (21 CFR 120) 1
K ISO 22000 Audit Checklist wanted Food Safety - ISO 22000, HACCP (21 CFR 120) 6
K Food Safety Manual Policy Statements on some sections of ISO 22000 Food Safety - ISO 22000, HACCP (21 CFR 120) 6
K 6 Mandatory procedures of ISO 9001 to meet ISO 22000 Food Safety - ISO 22000, HACCP (21 CFR 120) 1
K ISO 22000 requirement to write a Food Safety Manual Food Safety - ISO 22000, HACCP (21 CFR 120) 2
K Differences between "Hazard" and "Risk" in ISO 22000 Food Safety - ISO 22000, HACCP (21 CFR 120) 4
K What Records are required by ISO 22000? Food Safety - ISO 22000, HACCP (21 CFR 120) 4
