ISO 80601-2-56 Laboratory accuracy
Our company develops a medical infrared thermometer. As per standart 80601-2-56:2017, we will perform the "clinical accuracy validation" (§201.102) of our MD by comparing our temperatures values to a RCT (Reference Clinical Thermomter). This clause compells us to "Before and after the tests, confirm the LABORATORY ACCURACY of the RCT with a REFERENCE TEMPERATURE SOURCE" (201.102.1 a)). The LABORATORY ACCURACY (§201.101.2) requires to use very accurate REFERENCE TEMPERATURE SOURCE that "has an expanded measurement uncertainty (covering factor k = 2) of not greater than 0,07 °C."
Here is the problem, where can we find a company that has/sells a compliant REFERENCE TEMPERATURE SOURCE to confirm the LABORATORY ACCURACY of our RCT ? We asked lot of classical metrology companies and they all answered that a blackbody with this expanded measurement uncertainty doesn't exist...
Regards.
Hello Ed,
Thanks for answering.
It's for CE marking of our product. The predicate device (=RCT if I understand well what you're asking) is a "Visiomed ThermoFlash LX 26", that is already CE marked...
Ed Panek
QA RA Small Med Dev Company
We tested our thermometer to ASTM E1112 and argued that this standard is more strict than 80601 and that was accepted under MDD.
Thanks for your answer Ed,
Now that there is MDR, maybe the NBs wil change their minds... What is the company that perform your ASTM test ? I've googled it and there were only links to the ASTM standart. You can PM me if it's not appropriate to write it in the discution thread.
Hello Ed and Crriss,
We are facing the exact same issue here ... such tolerance accuracy does not exist !! Would you be able to share the lab name that was able to perform such test ?
We would be so grateful,
Thank you in advance for your precious help,
Benjamin Weber
You should look for a competent calibration laboratory, ideally accredited to ISO 17025. Each country has a national accreditation body (e.g. in Germany this would be the "DAkkS"), where you can get more information about accredited labs.
I just had a very quick look and found a lab that states an expanded measurement uncertainty down to 0,015 K for the calibration. (Trescal, Braunschweig, Germany, https://www.dakks.de/files/data/as/pdf/D-K-15015-01-10.pdf)
If you have no idea about your national accreditation body you can look at the website of European Accreditation: Search Facility - European Accreditation
I hope this helps!
P Obstruction alarm requirement ISO 80601-2-12 Other Medical Device Related Standards 2
Ahang "DIRECT MODE" or "ADJUSTED MODE" according to ISO 80601-2-56 Other Medical Device Related Standards 1
T Pulse oximeters ISO 80601-2-61, is 0% okay for probe fault? US Food and Drug Administration (FDA) 4
K ISO 9001 Clause 8.3 & 8.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
I ISO 17025:2017 / ANAB 3125 - Articulating / Communicating Risks vis-a-vis Audit Findings ISO 17025 related Discussions 2
A Management of change procedure for ISO 45001 Occupational Health & Safety Management Standards 3
S Transition training for Internal Auditor from ISO 9001: 2008 to the ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Notified Bodies - ISO 13485 & MDR Technical Files ISO 13485:2016 - Medical Device Quality Management Systems 3
E Comparison of Personal Protective Equipment Standards EN 14605 vs GB24539 and ISO 13982 vs GB 24539 Occupational Health & Safety Management Standards 0
H R&D Lab ISO 9001 certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
C Biologic Evaluation based on ISO 10993-1 EU Medical Device Regulations 2
D Deviations - Where in ISO 13485 deviations are covered? ISO 13485:2016 - Medical Device Quality Management Systems 7
B ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 2
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Y ISO 13485:2015 Software Validation IQ/OQ/PQ ISO 13485:2016 - Medical Device Quality Management Systems 12
Ajit Basrur Any ISO standard or guidance documents on barcode and scanning? Other Medical Device Related Standards 1
J ISO 13485 for Metal Finishing Medical Device and FDA Regulations and Standards News 5
S How to calculate Effective Number of People for ISO 13485 Certification? General Auditing Discussions 2
C ISO Question - Do you say "I-S-O" or "I-Soh"? Misc. Quality Assurance and Business Systems Related Topics 14
D Question regarding where "validations" fit according to ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 1
H Asset Inventory - documents and people (ISO 27001) IEC 27001 - Information Security Management Systems (ISMS) 1
A ISO 20417:2021 Country of Manufacture Medical Device and FDA Regulations and Standards News 0
D ISO 26262 functional safety : how to get started Other ISO and International Standards and European Regulations 3
E Any template/ form of Monitoring and Measurement of Processes and product to ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 1
S IATF 16949 - Summary at a glance Clause wise - changes from ISO TS IATF 16949 - Automotive Quality Systems Standard 4
N ISO 22716 - GMP Training for GMP trainer Other ISO and International Standards and European Regulations 2
H ISO 13485-paragraphs for a SaaS SAMD needed or not? ISO 13485:2016 - Medical Device Quality Management Systems 2
M ISO 12944 Understanding the thickness guidlines Oil and Gas Industry Standards and Regulations 0
A Anxiety - ISO Re-registration Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 69
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P ISO 20400:2017 Sustainable Procurement Implementation Sustainability, Green Initiatives and Ecology 0
R ISO 27001 implementation IEC 27001 - Information Security Management Systems (ISMS) 3
D Can an ISO 9001 Certificate have Remote Locations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
W What is okay to use as a reference material for ISO 17025? ISO 17025 related Discussions 4
R ISO 14971 not harmonized ISO 14971 - Medical Device Risk Management 4
A ISO 14001:2015 clause 4.4 ISO 14001:2015 Specific Discussions 2
A Internal audit plan and processes for ISO 14001:2015 ISO 14001:2015 Specific Discussions 3
Moncia Implementing ISO 50001 Sustainability, Green Initiatives and Ecology 17
D Question on using audit checklist ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 20
D ISO 9001 - 8.4.1 Evaluate All Suppliers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 66
M Looking for a copy of ISO 10651 Hospitals, Clinics & other Health Care Providers 6
M ISO 13485 and document control for programs ISO 13485:2016 - Medical Device Quality Management Systems 6
Sidney Vianna ISO 9001 News ISO 9001 Quality Check - spinning facts in LinkedIn ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
AllTheThings ISO-17025 accredited TEST lab performing internal calibrations (Yes: Here is how) ISO 17025 related Discussions 6
P Filled in F48/F49 for internal audit ISO 17025:2017 Internal Auditing 2
A ISO 9001 Internal Audits - No production right now due to furloughs Internal Auditing 5
D Question on Documented Calibration versus ISO 17025 Accredited Calibration ISO 13485:2016 - Medical Device Quality Management Systems 2
M Customer Property - ISO 13485:2016 Clause 7.5.10 ISO 13485:2016 - Medical Device Quality Management Systems 9
pbojsen ISO 13485 Requirements versus FDA product classification and GMP exemptions - Audits ISO 13485:2016 - Medical Device Quality Management Systems 3
D "certified" in ISO 19011, as well as IATF required? IATF 16949 - Automotive Quality Systems Standard 6
